Forum » Pomoč in nasveti » wrt3600 - brikan, kaj narediti?
tiran2000 ::
Torej flashal sm WRT3600 z gargoyle firmwirom. Flashanje je bilo uspešno. Nato sem želel iti nazaj na stock in naredil hudo napako, ker sem uporabil FIRMWIRE z uradne strani. Upgrade mi s stockom ni pustil, zato sem to izvedel preko BACKUP/RESTORE.
Router je sedaj neodziven oz. nemogoče je dobiti IP številko. Probal sem 30/30/30 reset in OpenWrt failsafe mode... idej nimam več...
je samo še fizičen poseg opcija?
pozna koga ki bi mi to naredil za normalno ceno?
mzakelj ::
Jaz ti nardim zastonj, samo pošlji mi ga. Kaj dosti nisi mogel zajebat. Mi je zakon popravljat take hece
BlaY0 ::
Naredim za 6-pack Heinekena. Pa še razložim ti vse skupaj, da ga ne boš drugič takole sral...
Hayabusa ::
http://wiki.openwrt.org/toh/tp-link/tl-...
Back to original firmware
With the WDR3600 router, there is a catch: the stock firmware is obtained from the OEM: http://www.tplink.com/en/support/downlo...
The most easy way to revert the WDR3600 back to stock firmware is by flashing the original firmware version TL-WDR3600_V1_130129. With this firmware version there is no need to cut off some pieces before flashing.
//Serijski kabel povezava pride prav http://www.ebay.com/itm/New-1PCS-PL2303...
RTFM drugič in prihranil si boš veliko muk !
Lahko spraviš router v http://wiki.openwrt.org/doc/howto/gener... ?
- spremenilo: Hayabusa ()
Hayabusa ::
An example of an image file with the word "boot" in it is wdr4300v1_en_3_13_17_up_boot(120426).bin. (Note: As of yet I only saw one firmware on their page and that was with boot)
Cut the first 0x20200 (that is 131,584 = 257*512) Bytes from original firmware: (1*512 Vendor-info + 256*512 U-Boot)
clancy ::
Da ne bom odpiral nove teme, bom kar tukaj napisal problem, saj gre skoraj za identično težavo, le router je Tp-Link Archer C5.
Kake štiri mesece imam naloženo gor zadnjo vezijo Gargoyle-a in je ves ta čas delalo brez najmanjših težav. Včeraj pridem domov, vklopim prenosnik, brskam normalno po spletu kakšno minuto, do dve, nakar naenkrat ni več hotelo odpirati strani. Wifi signal je bil, vendar ni hotelo spusti prometa skozi. Prav tako internet ni delal na domačem namiznem računalniku, ki je preko kabla vezan direktno na router.
Potem se s svojim Android telefonom prijavim v nastavitve routerja in izberem restore default configuration, ali nekaj takega. Od takrat router ni več dostopen.
Sem že probal 30/30/30, vendar nič. Nekaj sem se tudi igral z Puttyem in Tftpd, vendar imam premlo znanja pa tudi časa, da bi se lahko bolj poglobil.
Ali obstaja še kakšna lažja opcija, ali ga je treba odpreti in lotati?
BorutK-73 ::
Da ti ni IP spremenil nazaj na default? http://192.168.0.1/ ali http://192.168.1.1/
Pa priklopi se z kablom na router (seveda ne z telefonom
- spremenil: BorutK-73 ()
clancy ::
Ni dostopen na nobenem IPju. Tudi preko kabla ne.
Ko ga prižgem je takole:
https://mega.nz/#!HAlTCCSR!KfvU9JRKW9SYLjD-w3HcLnkKOU0YGtRQzxYs-JDUFzo
Po eni minuti, zvezdica neha utripati in samo sveti.
clancy ::
Glej, saj sta avtorju te teme že dva oddgovorila, da to delata za zabavo.
Mi je vseeno, lahko mi ga tudi kateri odbrika za normalno ceno in ga bom imel naprej, ker je drugače to zakon router. Samo se do sedaj še ni noben javil in sem mislil, da bi ga mogoče kateri imel. Meni se enostavno več neda ubadati s tem.
clancy ::
Problem solved
... Router sploh ni bil brikan. Kot je domneval BorutK-73, nisem takoj zadel pravega IPja, oziroma nisem počakal dovolj dolgo, da bi se router povezal z računalnikom.
In zakaj je sploh internet v petek kar naenkrat nehal delati?
Ker so mi na Telekomu izklopili drugo sejo. Jaz sem pa fural obe. Eno na modemu, drugo pa na routerju, saj sem imel nastavljeno na PPPoe. In to so mi brez opozorila ugasnili. OK, saj so imeli pravico, ker je menda po pogodbi, že kar nekaj časa le ena seja, vendar so jo šele sedaj izklopili.
Ampak to izvem šele po tretjem klicu na helpdesk in po treh dneh drk..ja
To bi mi lahko povedali že pri prvem klicu in mi prihranili kar nekaj živcev.
Aja? Meni se vedno delata oba routerja bp. A so to na splosno zacel ukinjat, ali samo posameznikom?
clancy ::
Mi ni povedal po katerem ključu ukinjajo drugo sejo. Sem pa med prvimi v sloveniji dobil TS optiko. Morda grejo po vrsti. Ali pa tiste, ki ogromno DL/UL torrente
Tako da veste, če imate na routerju nastavljeno na PPPoe in vpisano geslo in vam kar naenkrat več skozi ne spusti prometa, si enostavno nastavite na dynamic IP.
BorutK-73 ::
A niso imeli v petek na Siolu probleme z internetom?
Pa da ne boš mislil da je drugje kaj boljše, meni so na Telesmehu prestavili iz statičnega na dinamični IP brez da bi me obvestili, po eni uri sem sam ugotovil kaj so naredil.
konspirator ::
Pri TK so bile dosedaj možne 4 pppoe seje hkrati.
Kot kaže jih za fizične osebe "zmanjkuje" ip v4 naslovov.
Majkl ::
Jaz ti nardim zastonj, samo pošlji mi ga. Kaj dosti nisi mogel zajebat. Mi je zakon popravljat take hece![]()
A Linksysov se tudi lotevas? Enega imam napol mrtvega...
Wrt54gl
FMPOV
| » | WIFI router + diskOddelek: Kaj kupiti | 5445 (4701) | GenZNPC |
| » | Gargoyle firmwareOddelek: Omrežja in internet | 1034 (936) | BlaY0 |
| » | Linksys WRT54G menjava LAN-WANOddelek: Omrežja in internet | 3347 (3068) | 111111111111 |
| » | Boljši routerOddelek: Kaj kupiti | 5410 (4948) | cordoba |
| » | Kateri ruter?Oddelek: Pomoč in nasveti | 3528 (3040) | RuskiSnajper |
