AMD Piledriver
AMD Piledriver
Isotropic ::
pri minanju recimo primecoinov se elektrika orenk pozna, pri recimo gamingu 2h dnevno pa ne.
vseeno je pa bolje manj kot vec, sploh pri streznikih in hpc. tut na racun par % hitrosti (ce je amd res boljsi pri streznikih)
Isotropic je izjavil:
Govorimo o CPU ne o GPU.
x45 ::
resonsnt mesh se pozna pr navitju in porabi - manjša od intelove kljub močnejši grafi in 32 nm vs 22 nm:
http://www.pcaxe.com/hardver/procesori/...
AMD x4 965 BE, 8 gb ddr3 1600, SSD Samsung, 960 GT
Xeon x3430, 8 GB DDR3, Matrox grafa
Ma kje si se ti zdaj našel s tem. Pusti to in pusti Intelov marketinški 22nm, ki je v bistvu 26nm.
In se drži teme.
D3m je izjavil:
In se drži teme.
od kje teb ideja, da je 26nm ?
x45 je izjavil:
še vedno mi nisi odgovoril na vprašanje, ali je v testu bil uporabljen C7. Brez te informacije, kot sem že povedal, ta test brezpredmeten.
Ni ideja. Imaš artikle na internetu glede "njihovega" procesa proti industrijskemu procesu. :)
D3m je izjavil:
Ne vem, kje si to bral, a zadnje generacije Intelovih CPU-jev se lepo dela v 22 nm načinu.
D3m se pač obeša na dejstvo, da Intel svojga procesa ne meri po "industrijskih" standardih. Čeprav, ko pa greš gledat velikost sram celice, pa vidiš, da je celica isto velika kot na pravem 22nm procesu :)
I'll repeat some useful numbers I've given before at our events. As can be seen for SRAM the Intel 22nm is almost but not quite twice as dense as their 32nm process, whilst TSMC and GF processes fit in roughly to the Intel densities as given by the names of their nodes.
Once upon a time half the metal M1 pitch defined the node but in recent years metal pitch reduction has not kept pace with other features so fabs have tended to reference the node as the ratio to the density of SRAM at 65 or 90nm.
Certainly there is a LOT of market BS taking place as well (Intel included) but in reality Intel does lead the way in density at least.
Of course SRAM density isn't everything but with BEOL limited by the desire to stay with single patterning, for logic the metal routing now begins to dominate over transistor size.
The drawn gate length is not really a relevant measure any more and in any case has never been the official definition of the node. It is generally used to set the performance of the transistor, shorter is faster whilst longer is slower but less leakage. The move to FinFETs allowed the performance and density of the next node to be achieved without going to shorter gate lengths which would have excessive leakage.
The additional complication of FD-SOI as a competing process technology will prove interesting. Despite the hype, FD-SOI SRAM densities won't match the densest FinFET SRAMs at the same node, but leakage will be noticeably better, causing a definite process branch applicable to numerous applications.
The stats are :
SRAMs
(HP and special low power versions are larger for all fabs)
Intel 45nm SRAM cell - 0.346um^2
Intel 32nm SRAM cell - 0.171um^2
Intel 22nm SRAM cell - 0.092um^2
TSMC 40nm SRAM cell - 0.290um^2
TSMC 28nm SRAM cell - 0.127um^2
TSMC 20nm SRAM cell - 0.090um^2
GF 28nm SRAM cell - 0.120um^2
ST 28nm FD-SOI SRAM cell - 0.120um^2 (this is believed to be the version with no back-gate and uncompetitive leakage - 0.152um^2 for back-gate and lowest power/leakage but of course LP versions of other processes are also larger)
Metal pitch
(once upon a time half this was the node size but as can be seen the transistors have shrunk a lot more than the metal)
Intel 22nm metal pitch - 64nm
Intel 14nm metal pitch - 48nm
TSMC 28nm metal pitch - 64nm
TSMC 20nm metal pitch - 64nm
GF 14nm metal pitch - 48nm (predicted)
Contacted gate pitch
(this is a key dimension in that it is no point making transistor gates shorter unless you can reduce this number to match)
Intel 32nm contacted gate pitch - 112nm
Intel 22nm contacted gate pitch - 90nm (80nm with special processing)
Intel 14nm contacted gate pitch - unknown
TSMC 40nm contacted gate pitch - 160nm
TSMC 28nm contacted gate pitch - 118nm
TSMC 20nm contacted gate pitch - unknown
TSMC 14nm contacted gate pitch - unknown
GF 28nm contacted gate pitch - 113nm
GF 20nm contacted gate pitch - 80nm
GF 14nm contacted gate pitch - not relevant as BEOL is stated as being the same as 20nm. However this may change in due course. - See more at: http://www.electronicsweekly.com/manner...
Zdaj se morajo izjasniti tako eni kot drugi kaj bo "standard" ali Intelov zasnova ali druga, če se bojo sploh zjasnili.
Ker potem je vse samo marketing.
Ampak pustimo zdaj to.
  • spremenil: D3m ()
D3m je izjavil:
vedno je vse marketing.
Vse kar šteje je, kako se dejanski produkt obnese v praksi, kakšno porabo ima, performance.. itd.. Pa naj bo 90nm proces ali 5nm proces.
Se strinjam. Kaveri je 12 core BTW. :D
D3m je izjavil:
Sure thing :)
Itak, da je. Kar poglej zasnovo.
Povej to 99% aplikacijam :)
In stvar ni 12 jederna v pravem pomenu besede. GPU in CPU sta še vedno ločeni zadevi, le dostop do pomnilnika ni ekskluziven eni enoti.
Jaz ne morem. Nisem programer. Bojo drugi :)
boolsheat ::
Evo, tu se vidi, kako je AMD pred Intelom... :D
filip007 ::
Ja, če bi pa pristavil neko močnejšo grafično zraven bi pa bil spet Intel boljši.
Zero games, zero talk.
bu-bu-but AMD has 12 cores :))
boolsheat ::
Kakšna pa pride potem poraba (Intel + GPU), da pride recimo podoben performance kot AMD A10? Je potem boljši AMD ali ima še vedno Intel manjšo porabo?
klkkkkkkkkkk ::
iloveboobz je izjavil:
"up to 12 compute cores"
Ne AMD ima boljši P/W če gledaš GPU+i5 vs 7850K
klkkkkkkkkkk je izjavil:
kaj ko bi to izjavo podkrepil z kakimi viri...
boolsheat je izjavil:
Potlej pa ni več boljši, ker mu cena zleti v nebo.
klkkkkkkkkkk ::
A10 6800K
140 W ima pri full loadu z iGPU oz. 40-45W več kot i5 brez iGPU - kakor vemo bo 7850K samo še bolj eff.
Najbolj eff. je A10 6700 kateri bo imel okoli 120-125W
i5 3570K ima 112W z GPU
vir:
http://www.guru3d.com/articles_pages/am...
Najdi GPu ki, bo uporabljala samo 40-50W
z i3 bi se pa že dalo nekakšen GPU da bi imel enako porabo ampak boljši šerformance
klkkkkkkkkkk ::
Če se ti gre res samo za porabo.
Na hitro primerjajte Voltažo 6800K in 6700... tu se vidi razlika...
Tole ti je nabolj P/W sistem
najbolje pa je, da "undervoltaš" A10 6800K
A10 6800K
vir:
7750. S tem da ima zadeva gddr5 za razliko od kaverija, ki ima samo ddr3 :)
klkkkkkkkkkk ::
Ima že malo preveliko porabo (6700)... i3 + 7750 bi pa blo
4670T+7750 je najbol efficient combo, kar jo lahko kupiš. 100W maximalne porabe, praktično pa precej manj, saj i5 nima aktivnega gpuja. Torej zadeva porabi manj kot topend kaveri in je hitrejša overall.
Cena? Aja tukaj se ustavi. Thx anyway. ;)
klkkkkkkkkkk ::
zelo težko... moral bi narediti test glede nato, da ima A10 6700 CPU porabo enako kot i5....
ti veš, kaj efficiency pomeni ?
In ja, tisti i5 ima 45W porabe :)
D3m je izjavil:
Sj ni govora o ceni, ampak efficiency :)
Če pa gledaš ceno, porabo in zmogljivost, potem je pa kaveri kr na vrhu :)
NightHawk ::
On misli, da efficiency pomeni PORABA, kot je razvidno.
Cena za naprednješo tehnologijo bo vedno višja. Tako pač je.
klkkkkkkkkkk ::
Hojnikb dobro vem kaj je eff. .. vendar če ti govorim, da ima 6700 enako porabo kot i5 v prime 95 (mogoče 5W več).
In če smo že pri tem
Najboljši eff. ima ali i3/i7 + R9 270/GTX 650ti/GTx 690 - to ti je nabolj eff. sistem ne pa i5 in 7750...
Se pogovarjama o isti I5ki, torej 4670T ?
7750 je bolj učinkovita kartica. Če ne verjameš, pa izračunaj :)
klkkkkkkkkkk ::
No... jaz sem mislil za normalen haswell i5 "povprečen"....
http://www.silentpcreview.com/article13...
čeprav so čudni benchmarki...
če se pogovarjama o učinkovitosti, normaln proc pač nebo pršu v poštev, ker ti nikol niso najbolj učinkoviti :)
Radeon 7750 tako z DDR3 kot z DDR5, pa še orenk hitrejši je od vseh integriranih, kar trenutno obstaja plus verjetno še tudi v tem letu ne bo dosežena, presežena ta hitrost.
opeter je izjavil:
exactly. In tak gpu v kombinaciji z lowpower i5ko preseže po učinkovitosti APUje, torej je izjava flyingbee odvržena, kar se tiče učinkovistosti APUjev :)
klkkkkkkkkkk ::
glede 7750 ddr3 se nebi tako strinjal glede 7750 ddr5 pa ja...
sj je govora o gddr5 verziji :)
klkkkkkkkkkk ::
opereter je omenil obe
Zaenkrat velja tudi za DDR3. Kaveri ga bo pogojno morda dosegel. Vprašanje.
klkkkkkkkkkk ::
Že overclockan A10 6800K dobi 30-40% boosta tako, da je že na ravni 7750 DDR3
NightHawk ::
kaj ma veze kaj overclockan naredi? Sej lahko tudi 7750 ddr3 ocjas
sploh, ker si grafika še vedno deli spomin (res pa je, da bo zdaj prisotena tudi huma), pa tudi clock je nižji pri kvari. Upoštevaj še to, da grafika še dodatno zgubi frekvenco, če je na polno obremenjen proc in ta efficiency hitro pade.
klkkkkkkkkkk ::
Amm to se še neve... kolk bo dejansko povzročil "bottlenecka"...
pri 40% overclocku (če upoštevamo linearno rast performanca, kar pač ni praksa pri apujih, ampak vseeno) bo efficiency padu in tak apu hitro pade iz te debate :)
ve se zagotovo, da nebo hitrejši od 7750DDR3.
klkkkkkkkkkk ::
kaveri naj bi imeš še 2 jedra več.
http://www.tomshardware.com/reviews/rad...
kaka 2 jedra več ? 8-O
Isotropic ::
D3m je izjavil:
cena se ti obrestuje takoj, ko zberes denar za kaksno boljso kartico. ceprav se ti niti ni treba skeširat za T. mantle je zaenkrat se en velik vprasaj, poleg tega tut MS ne bo lih spal in bo DX12 verjetno bolj optimiziran.
O kakšnem DX12 sanjaš? Mantle bo v tem mesecu, če se ne motim.
  • spremenil: D3m ()
15 / 18
AMD ali Intel CPU (strani: 1 2 )
6413182 (12036) Napajalc
AMD vs Intel v gamingu (strani: 1 2 3 4 )
18130956 (27157) PredatorX
