Forum » Konzole » PS4
PS4
Tedex23 ::
Kateri položaj za PS4 je boljši, stoječi ali ležeči? Oziroma ali je kaj narobe če ga imam v ležečem položaju?
Lp.
Lp.
Lp.
Ležeči položaj:
Dobro:
Quiet Disc Drive
Gamers who prefer a quiet disc drive when playing games, placing your PS4 in the horizontal position will give you that. Just think about the laws of gravity when placing the disc. You put less stress to the disc drive when placed horizontally opposed to the vertical position.
Provides More Cooling
Now that every game console produces more heat than previous ones, it’s important for the PS4 to stay cool at all times to prevent the internal parts from frying or melting. If you want your console to get as much air to the inside, putting it horizontally will give the PS4 cool air as both sides of the PS4 have an intake vent.
Slabo:
Slightly Wobbly
If you decide to put the PS4 in horizontal position, you will notice that it doesn’t that if you push down the side where the Sony logo is, it will slightly wobble. It looks like the side where the Sony logo is placed doesn’t have much of rubber to put it in a stationery position. The wobbly problem isn’t really a big deal, but can get annoying if you have OCD. To fix this problem, simply get a stack of thin paper/index cards/or post it notes and put it under the side where the Sony logo is.
Takes a lot space
The amount of space the PS4 takes when placed horizontally has always been a problem by everyone who doesn’t have a wide entertainment shelf. IF you have small space to put your PS4, your best bet is to really put in a vertical position.
Stoječi položaj :
Dobro:
Saves Space
If you don’t have enough space to put your PlayStation 4, putting the console in vertically is something you will need to consider.
Stylish
Putting your PlayStation 4 in a vertical position makes your console look very stylish due to its design. If you want to show off your console to your friends and that led light that lights up when powered on, then put it in vertical position.
Slabo:
Risk of Tipping Over
One risk that everyone needs to consider when putting your console in vertical position is tipping it down. If you have a dog, cat, or a little kid who loves playing around, there’s a risk that you will tip over the console and break something.
Not as Quiet
When I put my PS4 in a vertical position, I noticed that the console isn’t as quiet as Sony promised it to be. The noise coming out from the console is from the fan that kicks in very hard and the disc drive when reading discs.
Can get very warm
Comparing the temperature from the horizontal and vertical position, I noticed that the vertical position runs a little bit warmer. Remember, when you put the PS4 in a vertical position, you are taking one in-take vent out since you have to put a stand on its side to make your PS4 more secure. When this happens, you are only allowing one in-take vent to get as much cold air from the outside to the inside, making your console run a little warmer. Well, this will result in fans kicking at high speed, making your console run louder.
http://www.justpushstart.com/2013/11/pl...
Danes sem dobil reklamo od Eleclerka pa imajo tudi tam PS4 -20% za 319 eur na njihovo Eleclerc kartico.
wired ::
Trupl0 ::
Me prav zanima po kakšni ceni dobi Merkator Playstation 4
verjemi, da delajo bulo na vsaki prodani konzoli...in to orng bulo :)
If you are going through Hell, keep going !
A ni potem to slaba poslovna praksa, da dela namenoma minus ?
Za sony recimo štekam, da delajo minus z samo konzolo, ker si potem drugje noter pridejo. Kje pa trgovina dobi noter tisti minus, ki ga naredi z konzolo =
paliskic ::
Saj to ni niti toliko važno, ni ga čez trenutne akcije mercatorja z 20% popusta. PS4 je za 320€ skoraj zastonj, za tistega ki je pa preveč, pa lahko kupi tudi na obroke z pika kartico, brez stroškov odobritve, itd.
Mah, konzole se praviloma vedno splača kupit nekje v mid lifeciklu. V štartu se ne splača, ker ni iger in je vseskupi drago (da o porodnih težavah ne govorim). Počakaš da stvar pade pod 300€ MSRP in da pridejo ven igre, ki jih maš res namen preigrat.
kratos ::
Zakaj bi bila trgovina v minusu če konzolo prodaja za 320EUR ko pa je sama konzola 400$ ? V najslabšem primeru je tam-tam, če bi šli v minus bi kaj hitro napisali na kupon "kupon ne velja pri nakupu playstation 4 konzole", recimo. Tako zabiti pa spet niso v marketingu menda.
- spremenil: kratos ()
St235 ::
Odvisno od dobavitelja, ni nujno, da imajo iste pogoje kot ti:)
drugače pa teh 30 € na konzoli prinesejo noter z ostalimi nakupi. Teh par 10 ps3, ki se tako prodajo jih ne bo pobralo.
medenko ::
kratos in ostali: v minus se gre, marže na ps4 je cca 10-11% tops. v minus gredo, ker imajo pri hrani 100%+.
Verjetno je res tako. Zalogo majo minimalno, dajo pa ven take akcije, da folk potem še kej druga kup (kjer so marže absurdne) in si potem noter pridejo. Tako kot si sony noter pride z igrami in storitvami
Pesimist ::
NejcSSD ::
Velja ampak ne v Mercator tehniki!!
Če pa majo v živilski prodajalni tehniko (Mercator Šiška) pa to ni Mercator Tehnika
St235 ::
hdmi ::
zassx ::
Prosil bi vas za en nasvet.
Imam EU PS+ ter US brez +. Ker je Driveclub preorder po nizji ceni na US razmisljam, da bi oddal tam preorder. Ali bo zadeva lepo delovala ce ga mislim igrati na EU accountu? Kako je pa z dodajanjem kreditov na US acc?
Hvala za pomoc
Hvala za pomoc
McClane ::
Meni vse US igre delujejo brez problema na EU accountu. Kredite pa dodajam preko PSN kartic, ki pa morajo obvezno biti za US store, saj evropske kode ne delujejo.
\"You want us to build WHAT??\" - Ancient Chinese Wall Engineer
Pesimist ::
Hvala za pomoc
Ja samo bos moral us account aktivirat kot primarni za čas igranja.
Luka321 ::
Je kakšna razlika med hdmi kablom, ki ga dobiš zravn konzole in kakšnim drugim, ker imam doma še en hdmi od sonyja pa me zanima če bo kaka razlika v grafiki, če ga uporabljam tudi za ps4 namesto tistega, ki ga dobiš zraven konzole.
- spremenilo: Luka321 ()
Luka321 ::
Roksij ::
Kateri se bolj splača, UK ali US account? Namreč kolikor sem gledal na PSN, so vse igre cenejše za US, gledal cem recimo fifo, nba, ufc, madden itd, recimo preračunano v Evre, nekje v povprečju:
- 47 eur za novo igro preko US načina (60 dollarjev)
- 70 eur preko UK (cca 55 funtov)
Prvič sem naročil konzolo, pa zbiram informacije, da se odločim kako je bolje. Recimo za poizkus sem se registriral kot US resident, ampak recimo zdaj ne morem koristit kartice, ker nima US naslova. Vidim da je mogoče kupiti PlayStation Network Card v dolarjih na goblinu, da imaš kredit na računu, a na Goblinu očitno ne poznajo menjalnega razmerja Euro-USD, po njihovem je le-to kar 1:1, kar potem eliminira vso prednost, ki jo pridobiš zaradi cenejšega dolarja.
Lahko kdo pove kaj in kako me bodo igre prišle najceneje? Oz kako naj se spravim k zadevi? Bi bil zelo hvaležen, vsak prišparan evro se pozna. :)
Kje pa kupuješ PSN kartice za US store?
- spremenilo: Roksij ()
St235 ::
Kartice ne kupuješ pri slovenskih oderuhih ampak na bestbuy in amazon. Pri slednjem je vse kar rabiš je random naslov v ZDA (daš recimo nek hotel) in pa pazit moraš da naročiš digital verzijo, ki jo potem dobiš po emailu.
