Forum » Konzole » PS4
PS4
Jerry000 ::
A je player base za COD večji na PS4 kot PC? Bo kdo kupil nov COD?
Player base bo ziher večji na PS, ampak letošnji COD bo itak omogočal crossplay tako da je vseeno. Jaz imam prednaročeno, ja.
Torej se da po 1 letu še normalno igrat MP al se čuti že velik upad?
scipascapa ::
1. imaš US račun
2. kupiš US vrednostnice na ckdeys.com https://www.cdkeys.com/playstation-netw...
včasih imajo akcije https://www.pcgamesupply.com/buygames/s...
3. kupiš igro
3. kupiš igro
- spremenil: scipascapa ()
z3ro ::
Na PS zagotovo, ampak kot receno - zdaj ko bo crossplay to ne bo vec tako hud problem. Upad je bolj zaradi tega ker pride po enem letu nov COD in vecina neha igrat starega.
dolenc ::
Verjem da fps competitive špile vsi špilajo na miša in tipkovnico na konzolah. Ali native ali xim itd...
z3ro ::
Competitive CODa noben ne igra na miški in tipkovnici (ne na konzoli, ne na PCju). Uradno noben COD do sedaj niti ni tega podpiral, razni XIMi in ostale reči so bolj tako tako. Vsa COD competitive scena se dogaja na konzoli (PS4) in to z kontrolerji.
scipascapa ::
SHOPTO:
Hello,
My apologies for the delay in response, we are currently experiencing a high volume of queries and calls, so we are behind with our responses.
The reason for the raise in price is due to the fact we have changed the method of shipping for overseas orders.
The old method was very difficult to track, meaning that customers were left waiting a long time for an order to arrive with no updates or if a package went missing, there was no way to find what had happened. Where as the new method does. Unfortunately, however, it mean we have to charge a little more.
Hello,
scipascapa ::
THE GAME COLLECTION
"5% OFF ALL ITEMS INCLUDING PRE-ORDERS WHEN YOU SPEND GBP50+ AT THE BASKET!"
Offer starts tonight at 12 mindnight. No code is required.
filip007 ::
A je God of War težja od Horizon Zero Dawn sem dal na Story in mi kar gre.
Zero games, zero talk.
kitl76 ::
GOV sem preigral medtem ko horizon mi ni potegnil.
- spremenilo: kitl76 ()
YesMan ::
Noben FPS se na competitive ravni ne igra s XIM in podobnim sranjem, saj je to cheatanje (razen če igra podpira tipkovnico in miško, kar pa za veliko večino ne drži). XIM se zelo kritizira na konzolah in velja dejstvo, da si pač pička, če ga uporabljaš. Ponavadi jih itak uporabljajo samo kaki froci, ki nimajo za burek na PC-ju.
Polek tega pa niti ne nudi take prednosti (definitivno ni tako, kot igrati native z miško in tipkovnico). Ogromno nastavljanja je potrebno, povrh vsega pa se s XIMom občutno podaljša odzivni čas.
LiamSem ::
Je ze kdo preizkusil ps4 remote play app na telefonu? Je mogoče, da bi se nekako povezal na svoj wifi takrat ko me ni doma (preko telefona) in bi remote play deloval? Saj je mozno samo preko domačega wifija v katerega je ps4 povezan in prav tako telefon, dejansko uporabljat aplikacijo :P
naslonjach ::
ravno prejle preizkusil in deluje na drugem omrežju wifi. Ob prvi prijavi, sem imel nekaj problemov za katere ne morem potrditi kaj je bil razlog. Ko sem izključil mobile dato, samo preko wifija sem lahko dostopil do ps4. S tem da mora biti v stanju spanja ps4.
LiamSem ::
Aha. Ne vem kaj je smisel take aplikacije, ki jo lahko uporabljas samo doma,preko domačega wifija. Brezveze. To bi moralo biti,da se lahko povezes kjerkoli si :/
naslonjach ::
Mogoče sem za kompliciral. Dela lepo in prav na drugem WiFi omrežju ne glede kje si.
Probaj. Naloži app, greš na konzoli v nastavitve remote izbereš dodaj napravo in se ti izpiše koda. Ko kodo vpišeš v aplikacijo na telefonu in voila
- spremenil: naslonjach ()
LiamSem ::
Aha hvala, sem probal. Preko drugega wifi bi šlo, da bi pa preko mobilnih podatkov povezal,pa mi ni ratalo. Sem probal vpn. Bi rabu vpn ki simulira wifi:P
rs1975 ::
A kdo uporablja PS Now? A ob tem rabiš tudi PS+ za multiplayer ali je to že všteto v PS Now?
alexslo93 ::
PS+ 1 leto za 30€, če si nov uporabnik na nemškem psn store https://store.playstation.com/de-de/pro.... Našel sem tudi na UK https://store.playstation.com/en-gb/pro... . Ne morem pa najti za slovenski psn store, če kdo ve mi naj sporoči.
filip007 ::
Zadnjo tako, ki sem jo igral je bila Killzone Shadow Fall ali je Infinite Warfare podobna?
Ne preko mreže ne igram.
Jerry000 ::
Jaz trenutno igram COD WW2 na PC pa mi je všečna. COD MW pa tudi hvalijo tako da mogoče vzami kaj od tega (odvidno od budgeta)
scipascapa ::
This month Plus subscribers will get Nioh and Outlast 2, plus there's access to the Nioh 2 beta!
filip007 ::
Trapasta je GOW, najprej ubiješ velikana, potem pride 2 manjši od mene in ne gre.
filip007 ::
Ja sem prišel naprej, očitno začetek težak potem pa gre, podobno kot jaguar v Tomb Raider.
rs1975 ::
Drevesce ::
Drevesce ::
COD omogoča igranje na konzoli z miško in tipkovnico. Samo priklopiš in igraš.
Je kje kakšen list, kateri COD je možno igrati s tipkovnico in miško?
Call of duty modern warfare remastered mi namreč ne deluje.
Malce sem prečekiral... dejansko rabiš tale adapter?
https://www.amazon.de/dp/B079SS1CCR/ref...
Morda kdo ima to, deluje na vseh igrah?
z3ro ::
Miško in tipkovnico podpira samo letošnji COD Modern warfare, starejši ne. Ne rabiš pa nobenega adapterja
naslonjach ::
Imam in delo opravi odlično! je občutiti razliko med mišjo na računalniku in ps4 seveda, toda precej bolje, kot na kontrolerju, če ga nisi vajen in prihajaš iz PCja. Bi pa opozoril, da tudi če si največji stručko, vzame instalacija in nastavitve kar precej časa in živcev. Jaz sem nastavitve uredil za prvo igro, da je delalo tekoče, tri dni. Skozi popravljal, dokler nisem našel pametnega navodila kako pravilno nastaviti miško in vse tipke.
Tukaj pa link, za vse igre, ki jih xim apex podpira: https://community.xim.tech/index.php?to...
Zvezdica27 ::
živjo,
a če se kupi rabljen ps4 pro, so kake nevarnosti, da je banan itd?
Kako se potem to preveri?
tnx,
zz
tnx,
zz
z3ro ::
Fizično konzola mislim da ne more biti blokirana, lahko je samo PSN račun katerega imaš itak svojega. Tako da ni straha.
Trupl0 ::
za hujše kršitve so bile benane tudi same konzole
If you are going through Hell, keep going !
