mod_rewrite
mod_rewrite
Hair ::
Lep pozdrav!
Imam problem in upam na rešitev :)
Cilj:
preusmeriti sinergija-mci.si/* na www.sinergija-mci.si/*
(wild card)
Problem v cPannel:
You cannot redirect "" to "http://www.sinergija-mci.si" as this will cause a redirection loop because "/home/public_html/" is at the same place as "/home/public_html/".
Ne vem, če je kaj povezano - stran teče na multisite Wordpress, na strežniku pa so gostovane tudi druge domene (/home/public_html/druga_domena), za katere sicer nisem imel tovrstenga problema - je šel redirect normalno čez.
Izvorni problem je pa ta, da mi sinergija-mci.si/* preusmeri na http://www.sinergija-mci.si/wp-signup.p...
www.sinergija-mci.si/* dela normalno.
Našel sem to kodo, ampak menda dela ravno obratno - iz www.domena.com preusmeri na domena.com
Options +FollowSymLinks -MultiViews
RewriteEngine on
# if requested hostname is non-blank
RewriteCond %{HTTP_HOST} .
# and if requested hostname is NOT "www.example.com"
RewriteCond %{HTTP_HOST} !^www\.example\.com
# redirect to same object in correct domain
RewriteRule (.*) http://www.example.com/$1 [R=301,L]
Zna kdo obrnit zadevo?
Help plz :)
Whenever people agree with me, I feel I must be wrong.
  • poskusil klonirati: Hair ()
301 redirect
Oddelek: Izdelava spletišč
374969 (3744) Netrunner
mod_rewrite - prosim za nasvet
Oddelek: Programiranje
71960 (1836) carota
.si domena in redirect na Google apps (App Engine)
Oddelek: Omrežja in internet
103016 (2626) nkprimorje
.htaccess rewrite za poddomeno
71773 (1693) 3dice
Mod rewrite
61711 (1505) bluefish
