Forum » Programska oprema » Excel uvoz slik
Excel uvoz slik
foofighter ::
Zdravo,
ima kdo kakšno idejo na kakšen način bi v excel uvažal slike glede na njihovo ime.
V stolpcu A bi imel napisane šifre. Recimo:
2
3
4
5
6
Nekje na disku bi imel mapo, v kateri bi bile slike, imenovane z šiframi iz stolpca A.
Kako bi najlažje naredil da mi v stolec B uvozi slike tako, da se bom ime slike ujemalo z šifro, ki je že v excelu?
Hvala za pomoč.
2
3
4
5
6
Hvala za pomoč.
milc ::
V perlu takole:
use 5.012;
use strict;
use warnings;
use Spreadsheet::WriteExcel;
use Spreadsheet::ParseExcel;
use Spreadsheet::ParseExcel::SaveParser;
# Create a new Excel workbook - add some test image names
my $wb = Spreadsheet::WriteExcel->new('perl-test.xls');
# Add a worksheet
my $ws = $wb->add_worksheet('Sheet1');
# Write a formatted and unformatted string, row and column notation.
my $col = my $row = 0;
for (1..3) {
$ws->write($row++, $col, 'pic1.jpg');
$ws->write($row++, $col, 'pic2.jpg');
$ws->write($row++, $col, 'pic3.jpg');
$wb->close();
# Create a new Excel workbook - RESULT
my $wbn = Spreadsheet::WriteExcel->new('perl-test-img.xls');
# Add a worksheet
my $wsn = $wbn->add_worksheet('Sheet1');
# Open the template with SaveParser
my $parser = new Spreadsheet::ParseExcel::SaveParser;
my $template = $parser->Parse('perl-test.xls');
my $sheet = 0;
my $row = 0;
my $col = 0;
# Get the format from the cell
my $frmt = $template->{Worksheet}[$sheet]
->{Cells}[$row][$col]
->{FormatNo};
my $worksheet = $template->worksheet(0);
my $value;
my $cell = $worksheet->get_cell($row, $col);
while (defined $cell && $cell->value()) {
my $filename = $value = $cell->value();
#insert_image($row, $col, $filename, $x, $y, $scale_x, $scale_y)
if (-f $filename) {
say "$row: $value; added";
$wsn->write($row, $col, $filename, $frmt);
$wsn->insert_image($row, $col+1, $filename);
} else {
my $error= "Picture: $filename does not exists";
say $error;
$wsn->write($row, $col+1, $error, $frmt);
} #if
$cell = $worksheet->get_cell(++$row, $col);
} # while
$wbn->close();
| » | [Java] Urejanje baze z JTableOddelek: Programiranje | 1424 (1208) | vonNeumann |
| » | button v image buttonOddelek: Izdelava spletišč | 1499 (1404) | R33D3M33R |
| » | Excel vprašanje...printanje n-krat...vsakič se avtomatsko poveča ena številkaOddelek: Programska oprema | 1556 (1439) | Tutankhamun |
| » | Prosim za pomoč pri VBAOddelek: Programiranje | 2496 (2299) | apachee |
| » | Visual Basic in ExcelOddelek: Programiranje | 3201 (2767) | Vesoljc |
