Forum » Kaj kupiti » MSI + AMD XP2100?
MSI + AMD XP2100?
PICASSO ::
Kolko je vredna tale plata in ali je dobra?
http://www.msi.com.tw/program/products/...
rab bi kupo računalnik. to plato in AMD XP 2100+ a bo to ql? kolko rama priporocate.. ?
Mal me še zanima kako to laufa s temi vgrajenimi nforce 2 64 ddr graficnimi..
hvala
hvala
PICASSO ::
ne... pa nforce je tuki vgrajen.. zato vprasam. poleg tega:
CPU
• Supports Socket A for AMDŽ Athlon™/Athlon™ XP/Duron™
processors @FSB 100/133/166
• Supports 600MHz up to Athlon™ XP 2700+ processor or higher
Chipset
• nVIDIAŽ nForce2 IGP Chipset
- Integrated TV encoder
- Supports DDR266/333 with internal graphic core,
DDR266/333/400 with external add-on card
- AGP 3.0 8x interface at 533MHz
• nVIDIAŽ nForce2 MCP2 or MCP2-T Chipset
- AC97 Interface supporting up to two concurrent codecs
- Ultra ATA133 for the fastest hard disk throughput
- USB 2.0 EHCI/1.1 OHCI controller
- FireWireŽ and USB 2.0 for the fastest digital connectivity
(MCP2-T only)
- Audio Processing Unit(APU) encodes audio in DolbyŽ Digital 5.1
format for full surround sound effects (MCP2-T only)
itdLINK
CPU
Chipset
(MCP2-T only)
itdLINK
| » | 2x256 ali 1x512 ramaOddelek: Kaj kupiti | 1747 (1584) | boštjan |
| » | Nforce Control Panel na NF7 rev 1.0 ne delaOddelek: Programska oprema | 1535 (1377) | jurer |
| » | KT400A VS nForce2 SPP VS nForce2 IGPOddelek: Kaj kupiti | 1171 (1068) | GUFY |
| » | Nova "verzija" Nforce2Oddelek: Strojna oprema | 1409 (1171) | Jux |
