Forum » Konzole » Save Game iz PSX Emulator-ja na PC na PSP
Sandi1987 ::
Ali je možno, da prenesem Save Game iz PSX Emulator-ja na PC na Sony PSP, da ne bom od začetka igral?
Sandi1987 ::
http://www.pspmod.com/forums/psp-emulat...
If anyone is curious all you need to do is:
-download CWcheat 0.2.3
-open in winrar/winzip goto INSTALL_371 and extract seplugins
-move seplugins to your PSP's main folder
-restart the PSP and hold R1 to boot the recovery menu
-goto plugins and enable everything
-now put your emulator's mcr save file into seplugins/cwcheat/mc
-rename that file to something like SCUS_94584-0.mcr (the _ and - position is very important, remember to type .mcr at the end too)
*note*
The name of that file will depend on what game save you plan on loading, you will need to look up the propper number for that specific game.
-start up the game and at it's main menu hold 'select' for a few seconds until a menu screen pops up
-goto manage memory cards
-load memcard 1 and if you renamed the file correctly it should say 'Ok!' (if it gives you an error message or freezes, it is not named correctly)
Napiše Ok! in ne dela Save Game v Medal of Honor.
*note*
- spremenil: Sandi1987 ()
| » | Gothic 2 Gold editionOddelek: Igre | 4623 (2622) | LINKO |
| » | Ali se splača kupiti Sony PSP?Oddelek: Kaj kupiti | 3628 (3105) | Sandi1987 |
| » | PSP Odklep OFW 6.10Oddelek: Konzole | 3048 (2925) | -THX- |
| » | Gears of War problemOddelek: Igre | 1893 (1727) | opeter |
| » | Carmageddon 2 in težave na xpOddelek: Igre | 1860 (1679) | A. Smith |
