Forum » Kaj kupiti » Katero tablico izbrati?
krneki0001 ::
Zanimivo. Sem jo probal kupit, pa mi je javilo, da me bodo obvestili, kdaj bo naprodaj. Jih še ni. Očitno še kradejo načrte za procesorje.
Nesta ::
krneki0001 je izjavil:
Zanimivo. Sem jo probal kupit, pa mi je javilo, da me bodo obvestili, kdaj bo naprodaj. Jih še ni. Očitno še kradejo načrte za procesorje.![]()
Se zame prosim naroci :)
matobeli ::
Ampak zaenkrat keep your panties on, 8300 proc, ki ga obljubljajo, ne podpira 4gb rama. Glede na povpraševanje pa bodo verjetno upgrejdali in bo 8500 not.
Če pomislim, kar čimveč naročil please :-)
Upam da se isto zgodi na 8" tablici.
Bo pa 8" imekb verjetno usb-c
krneki0001 ::
Na bannggoodu imam kr nekaj pik, ki jih lahko ptetvorim v popuste in imam še nekje 25 izzdelkov za dobiti v prihodnjih tednih, tako da bo pik še več. Upam na 10% popusta pri naročilu.
krneki0001 ::
Z8300 podpira 4GB rama. Ker tablico z Z8300 in 4GB rama prodaja tudi toshiba.
http://www.techfresh.net/toshiba-dynabo...
Here we have another newly unveiled Windows 10 tablet from Toshiba, the dynabook Tab S60. Measuring 9.1mm thick and weighing 552 grams, this thin and lightweight tablet comes with a 10.1-inch 1920 x 1080 Full HD Clear SuperView touchscreen display, a 1.44GHz Intel Atom x5-Z8300 processor, an Intel HD Graphics, a 2GB/4GB DDR3 RAM and a 32GB/64GB eMMC.
Furthermore, the tablet is built with a 2MP front-facing camera, an 8MP rear-facing camera, a microSD card slot, 1x micro-USB 2.0 port, 1x micro-HDMI port, 2x USB 2.0 ports, built-in stereo speakers and a built-in lithium-polymer battery (up to 7 hours of operating time). Running on Windows 10 Pro OS, the dynabook Tab S60 provides WiFi 802.11 a/b/g/n and Bluetooth 4.0 for connectivity.
SumTingWong ::
"Update: The seller claims it's going to be released on the 15th of November, but you can order it now. They also put the price up!"
Chuwi Hi10. Se bomo še kar malo načakali ...
Nesta ::
Pre-orders are available only for a few days:
http://www.geekbuying.com/item/CHUWI-Hi...
gclid=Cj0KEQjwtaexBRCohZOAoOPL88oBEiQAr96eSDcTO2CmjHsNwaES6V0JTJGTyHcPmGlZWJzV6p96bOMaAnIg8P8HAQ
http://www.everbuying.net/product110264...
http://www.banggood.com/Chuwi-Hi10-64GB...
- spremenil: Nesta ()
krneki0001 ::
SumTingWong je izjavil:
Jaz imam še vedno ceno 169€ (188 dolarjev).
SumTingWong ::
Cena že, ampak je pre-order do takrat torej. Tri tedne čakanja še. Plus dodatek za shipping.
PS : Kaj bi vi raje izbrali. Tablico z MT8783 (octa core 1.3GHz) ali INTEL 3735F (quad core 1.3 do 1.8 GHz)? Ostale specs dokaj podobne. Android.
- spremenil: SumTingWong ()
Mare2 ::
Piše: Support external 3G module
Če slučajno kdo ve, kateri modul lahko dokupim, da bi delalo še 3g?
http://bit.ly/Navodilo123 Podpora za N26 Mastercard za Slovenijo
CyberPunk ::
V cem je fora, da vsi eMMC, ki naj bi bili 64 GB, niso enako veliki (na Windows tablicah)? Dve sem si ogledal v zadnjem casu, prva je dejansko imela dobrih 58 GB (eMMC je bil SanDisk), druga pa dobrih 53 GB (Hynix). Na obeh je bil sicer enak razpored particij (tista sprednja, potem glavna in potem recovery).
Gledal si velikost sistemske particije in ne velikost diska najbrž, poleg tega moraš vedeti da Microsoft uporablja enoto GiB. Torej prva ti je kazala 58GiB = 62GB, torej 2GB za ostale particije(zagonske recovery,itd), druga pa 53GiB = 57GB, torej okoli 7GB za ostale particije.
Pri prvi torej ne bi mogel kaj dosti narediti, pri drugi bi se ti recovery particijo izplačalo izbrisati za dodatnih 5GB.
CyberPunk ::
Ne, gledal sem v Disk Managementu na levi strani, kjer pise celotno skupno kapaciteto... Ravno zato mi je bilo cudno, da je taka razlika. Edina razlaga po moje bi bila, da je Hynix ze imel kaksne rezervne sektorje pokurjene, ali pa da je imel poleg vseh treh se kaksno skrito particijo, ki je od Windowsov Disk Management ne kaze.
Mare2 ::
A je android + win na tablici?
Na tisti ne. Tudi ni tipkovnice zraven. Tipkovnica je edino na aliexpress za 288 EUR.
krneki0001 ::
Mare, spraševal sem Cyberpunka, če je na njegovi tablici android in windows skupaj.
Drugače je pa 25€ tipkovnica z dockingom. Verjetno paše ta iz VI10 na HI10
http://www.banggood.com/Folding-Stand-P...
CyberPunk ::
Samo Windows.
Očitno kitajci goljufajo, jaz še nikoli nisem videl neokrogle stevilke diskov. Očitno so to diski, ki so imeli preveč okvarjenih sektorjev, ki so jih preprosto odrezali z firmwerom. Ni dvakrat za reči da so morda tudi počasnejši...
Mare2 ::
Tako nekako bo, ja.
chrispy ::
Kaj vam je bolje windows 10 tablica ali android tablica?
Zdaj pa že zadnji čas, da opravim nakup ampak se še vedno nisem odločil kaj mi bolj ustreza. Po eni strani sem gledal Microsoftov surface 3, pri katerem dobil "polne" windowse in s tem praktično neomejeno število programov, po drugi strani pa sem razmišljal da tega ne rabim, oziroma je vrjetno nebi do konca izkoriščal.
Android tablice mi izgledajo kar kul, dodatna prednost je vrjetno tudi to, da uporabljam gmail in ostale googlove storitve, ki so bolj integrirane v androidu kot na windows 10. Zdaj se mi pa ustavi pri sami izbiri tablice. Iščem nekaj v velikosti 7-9". Razmerje stranic naj bi bilo 4:3. Uporabljal pa bi tablico za pregledovanje pdf dokumentov, brskanje po spletu, kakšen word/powerpoint vsake toliko, youtube itd...
Tukaj bi bila logična izbira nexus 9, ki pa je nekoliko izven mojega denarnega dosega. Tako, da sem odprt za ostale predloge :)
Tablico z Windowsi vzameš, če jo nameravaš vsaj občasno uporabljati skupaj s tipkovnico, kot nadomestek prenosnika, za "pisarniška" opravila. In ne sme biti manjša od 10".
Manjšo tablico, ki je nikoli ne nameravaš uporabljati s tipkovnico, vzameš Android.
O.
O.
chrispy ::
No saj te mu se mi zacikla okapi, ker nevem kaj je boljše. Trenutno že imam laptopa, ki ga vzamem s sabo na faks in ga občasno uporabljam da kaj napišem / sprogramiram notri. Če zadevo prodam in kupim surface 3, bo zadeva manj zmogljiva kot moj trenutni laptop, ampak zraven dobim še tablico.
Lahko pa kupim neko 8" android tablico, in laptop obdržim. Ta spodnja varianta, mi je veliko bolj všeč... kaj pa vem no. Mogoče pa 8" android tablico z neko mini wirelesstipkovnico, če bom tipkovnico slučajno kdaj potreboval. Maš kak predlog katera android tablica je trenutno najboljša v price/performance razmerju. Cena je tam nekje do 250€ več pa za tako igračko ne mislim dajati.
Dobro, če rabiš win32 programe je itak no brainer, jaz recimo jih rabim tudi na 8" tablici za seafile(sihronizacija). Tablica, ki nima vseh mojih osebnih filov je zame precej manj uporabna, Seafila pa ne dam.
V primeru da jih ne rabiš pa bi jaz osebno vseeno izbral Win zaradi boljšega tablet vmesnika, kdo drug bo izbral Android zaradi vmesnika, tretji bo izbral Android zaradi več iger, ni tle nobenega "pravila".
Aja še en razlog zakaj bi DEFINITIVNO izbral Windows tablico. Kar zmrazi me(lastne izkušnje) kaj za en star ali pa sicer novejši ampak že slabše podprti neuradni rom bi imel na svoji 3 leta stari tablici, če ne bi imel Windowsa, ki se upgrada vedno na najnovejšo verzijo vključno nedavno na novo major verzijo Windows 10.
krneki0001 ::
Imam 2 8" (oziroma 7.85") tablici in BT tipkovnico. Obe imata polno verzijo windows 10 home. Pa ni nobenega problema napisat dokumenta v wordu.
Fairplay ::
Mene pa zanima, če je Lenovo TAB 2 A7-10, ki se dobi ob podaljšanju siol trio paketa, solidna za uporabo. Glede na to da ima samo 1GB RAM-a malo dvomim v to. Zanima me predvsem odzivnost.
Sprašujem, ker androida že nisem uporabljal odkar sem prvič poskusil Windows Phone.
matobeli ::
Za silo bo zih, če pa jo misliš zlorabljat z Chromom ali drugimi napornimi operacijami pa raje ne.
Če je še vedno obstoječ tisti bon za 200€ raje tist vzemi
drzni86 ::
Živjo!
Razmišljam o nakupu ene cenejše tablice do okoli 150€. Kaj se mi splača izbrati... Uporabljalo se bo predvsem za surfanje, branje dokumentov (PDF). Pomembno mi je da te osnovne aplikacije delujejo tekoče in, da ima tablica solidno avtonomijo baterije.
Hvala za predloge!
Hvala za predloge!
Killermode ::
Živjo!
Hvala za predloge!
+1 iščem podobno vendar je želja, da ima GPS in cca 8"... Kupiti sem pripravljen iz tujine, ali doma.
Mare2 ::
Oboje (Dual boot), Win 10 je za resno delo, Android pa za kamero, spletno mobilno banko, ... :)
Nesta ::
DualBoot je malo preveč komplikacije za 21. stoletje, ko mora zadeva instantno delat. Uporabnost DualBoota vidim v tem da lahko zamenjaš/izbereš OS, ne v tem da bi oba hkrati uporabljal.
Mare2 ::
Chuwi HI10 zmaga, samo ocitno ne bo dual boot kot je bilo sprva receno :\
Zmaga v čem? Ima fotoaparat zelo slab, nima bliskavice, nima 3G, nima kompasa, nima GPS, vprašanje, kako dela wireless... :)
Mare2 ::
Izgleda da so povsod spremenili naziv, funkcijo in res ni več dual botov. Škoda.
- spremenil: Mare2 ()
Android načeloma sam inštaliraš na x86, sicer ni uradno od Googla pa kokr maš srečo z driverji...
Mare2 ::
Verjetno moraš imeti še eno aplikacijo kot dual boot. Kje pa se najde android? :)
No, če ne rabiš fensi menija za izbrati dual boot lahko pač vsakič preko BIOSa izbereš v kaj bootaš. Home stran od projekta je pa kr lepo na prvem googlovem zadevku ko vtipkaš "android x86". Trenutno so na stabilni beti za 5.1.
Ampak ponavljam še enkrat, če nimaš pravega modela da delajo vsi driverji si prečen in to je v 90%. Dokler Google ne sreča pamet in začne zahtevat user-space driverje(taki ki delajo neodvisno od verziije androida/kernela) bo pač tako sranje. In dokler ga ne sreča pamet tudi mene več ne bo srečala Android tablica.
- spremenil: Lonsarg ()
