[MySql]Sintaksa poizvedbe
KernelPanic ::
Spostovani!
Zgubljam zivce z sledecim enostavnim stavkom:
SELECT id_customer, lastname, firstname FROM 'ps_customer' WHERE 'email=user@gmail.com' AND 'passwd=geslo'
Namrec, na server strani imam skripto za logiranje uporabnika v bazo. Uporabnisko ime in geslo pa dobim iz Android aplikacije iz telefona. Debugiral sem in php skripta vrne namesto resource boolean vrednost (false), kar pomeni, da se stavek ni izvedel. Identicen stavek sem probal pognati direktno na mysql serverju in mi javi sledeco napako:
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ''ps_customer' WHERE 'email=user@gmail.com' AND 'geslo' at line 1
Kaj je narobe z sintakso? Vem, da je ena enostavna stvar, ampak enostavno ne najdem.
Lp,
M.
darkolord ::
SELECT id_customer, lastname, firstname FROM 'ps_customer' WHERE email='user@gmail.com' AND passwd='geslo'
KernelPanic ::
darkolord je izjavil:
Ista napaka v /var/log/apache2/error.log. Tukaj je skripta:
<?php
        session_start();
        if($_SERVER["REQUEST_METHOD"]=="POST")
                $hostname_localhost ="localhost";
                $database_localhost ="test";
                $username_localhost ="test";
                $password_localhost ="test";
                $localhost=mysql_connect($hostname_localhost,
                                         $username_localhost,
                                         $password_localhost) or die(mysql_error());
                echo "Connected to Server.<br/>";
                mysql_select_db($database_localhost) or die(mysql_error());
                echo "Connected to Database.<br/>";
                $username=mysql_real_escape_string($_POST['username']);
                $password=mysql_real_escape_string($_POST['password']);
                $query_user=mysql_query("SELECT id_customer, lastname, firstname
                                         FROM 'ps_customer'
                                         WHERE email='$username' AND passwd='$password'");
                $number_of_users=mysql_num_rows($query_user);
                if($number_of_users==1)
                        echo "User found.<br/>";
                        $output=mysql_fetch_assoc($query_user);
                        print(json_encode($output));
                        mysql_close();
                else
                        echo "User not found.<br/>";
                }       // if
        }       // if
Tukaj je Android koda:
    private void loginToDatabase(final String strUsername,
                                 final String strPassword)
        HttpClient client=new DefaultHttpClient();
        HttpPost post=new HttpPost("http://moja-domena.com/php/login.php");
        HttpResponse response=null;
        HttpEntity entity=null;
        InputStream is=null;
        String result=null;
        try
            List<NameValuePair> loginInfo=new ArrayList<NameValuePair>(2);
            loginInfo.add(new BasicNameValuePair("username",
                                                 strUsername));
            loginInfo.add
                    (new BasicNameValuePair("password",
                                                 strPassword));
            post.setEntity(new UrlEncodedFormEntity(loginInfo));
            response=client.execute(post);
            entity=response.getEntity();
            is=entity.getContent();
            try
                BufferedReader reader=new BufferedReader(new InputStreamReader(is,
        ("iso-8859-1")),
        8);
                StringBuilder sb=new StringBuilder();
                String line=null;
                while((line = reader.readLine())!=null)
                    sb.append(line).append("\n");
                is.close();
                result=sb.toString();
                int i=0;    // test breakpoint code
            catch(Exception e)
            finally
            }   // try-catch-finally
        catch(Exception e)
        finally
    }   // loginToDatabase
Spremenljivka result vsebuje poleg ostalih echo-jev iz php skripte tudi "User not found", kar pomeni, da uporabnika preko tega sql stavka ne najde. Zakaj?
darkolord ::
Aha, pa ime tabele je brez narekovajev.
KernelPanic ::
DELAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA STARI HVALAAAAAAAAAAAAAAA, TI SI MI PA ZE TOKRAT POMAGU, KDAJ TE LOHKA PELEM NA PIR, CE SI PA BABA TE BOM PA KR KUSNU (BREZ VEDNOSTI ZENE)!!!! :D:))
Spura ::
Prazni catch in finally stavki?
KernelPanic ::
Spura je izjavil:
Ravno sedaj saniram tvojo pripombo. :D Drugace pa hvala za kritiko.
Rabim pomoč pri PHP-ju.
Oddelek: Šola
51017 (854) Stari89
[SQL] Unikatni izpisi
Oddelek: Programiranje
212859 (2246) 111111111111
[PHP]Zajem podatkov iz baze
355408 (5045) cobrica
MySQL Query Vprašanje
Oddelek: Izdelava spletišč
154218 (3983) overlord_tm
SQL problem
91948 (1785) Bossek
