Detonator 41.80 ''Hidden'' options
kuglvinkl ::
This I believe we covered before with past 40.xx drivers but I thought I'll jog your memory and let you know how to enable some options in latest 41.80 drivers that are not enabled by default. Click on Read More for more info.
The screenshots below show some of the options that the coolbits+.reg will enable for you. That's just apart from all the usual functions enabled via the famous "coolbits" setting ;). You can download the coolbits+ file HERE. (Note, only tested on Windows XP)
The 2 screenshots below show what's coming soon to nvidia detonator drivers near you... ;)
Tu.
speed machine ::
Če mene vprašaš ni to nič dobrega.
kuglvinkl ::
Bolj mi je zanimivo zaradi tega, kar bodo, zelo verjetno, nove verzije Detonatorjev omogočale.
VSI Gamerji NUJNO prosim za pomoč pri odrezani sliki
131032 (925) reto88
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187273 (7132) ManDriver
CATALYST 3.6
Oddelek: Programska oprema
168993 (8478) freejack
gf2
Oddelek: Navijanje
51200 (1088) kuglvinkl
OC MX-a z 12.41
Oddelek: Zvok in slika
51146 (1058) Dalmatinc
