Forum » Strojna oprema » Ivy bridge
Ivy bridge
win64 ::
Kar se ve o ivy bridge(vir wikipedia):
Ivy Bridge is the codename for the yet-to-be released 22 nm die shrink of Sandy Bridge. Ivy Bridge processors will be backwards-compatible with the Sandy Bridge platform, but requires a bios/firmware update. Intel will also release a new 7-series Panther Point chipset with Ivy Bridge,it will come with integrated USB 3.0.
Due to having no significant obstacles during the new 3D gate development, Intel plans to begin sale of the processors to its customers in Q4 of 2011, with actual retail availability from March 2012 onwards[10]. Intel has been producing Ivy Bridge chips in volume, in preparation for the product launch, starting in the third quarter of 2011.
Thermal design power (TDP), according to a leaked Intel roadmap, will come in 77/65/55/45/35W options for desktop processors, while Intel says that mobile processors will use variable TDP (for example normal at 15W TDP, which automatically rises to 35W TDP when the laptop is plugged into a docking bay; with a corresponding rise in performance).
Expected Ivy Bridge feature improvements from Sandy Bridge:
Intel's performance targets (compared to Sandy Bridge):
- Intel's tri-gate transistor technology (up to 50% less power consumption)
- PCI Express 3.0 support.
- Max CPU multiplier of 63 (57 for Sandy Bridge)
- RAM support up to 2800MT/s in 200MHz increments
- Next Generation Intel HD Graphics with DirectX 11, OpenGL 3.1, and OpenCL 1.1 support.
- The built-in GPU is believed to have up to 16 execution units (EUs), compared to Sandy Bridge's maximum of 12.
- The new random number generator and the RdRand instruction, which is codenamed Bull Mountain.
- Next Generation Intel Quick Sync Video.
- DDR3 low voltage for mobile processors
- Multiple 4k video playback
- 20% increase in CPU performance.
- Up to 60% increase in integrated graphics performance
Jinto ::
Pomoje bo tako kot piše Anand, torej 4-6% hitrejši od sb (ob nižjem tdpju), ker drugače sb-e nima smisla.
Jinto ::
Ivy Bridge is considered a tick from the CPU perspective but a tock from the GPU perspective. On the CPU core side that means you can expect clock-for-clock performance improvements in the 4 - 6% range.
Ne vidim kje piše, da je to bilo včasih, oziroma kje piše sploh 20% (to piše na wiki, vir pa je zelo sumljiv in star).
- spremenilo: Jinto ()
Ubistvu nimajo kej, gre se za rahlo evolucijo SB arhitekture.
Anand je lepo napisal kaksen je namen die shrinka.
Despite the limited improvement in core-level performance there's a lot of cleanup that went into the design.
1. manjsi proizvodnji proces, torej se zmanjsa poraba in zvisajo frekvence,
2. optimizacija jedra, dodajo se kaksne funkcionalne malenkosti in to je to. Se najvec sprememb bo v GPUju.
Nov bo tudi chipset, koncno z native USB 3. Najbolj bosta zanimiva Z75 in Z77.
win64 ::
Predvsem je intel delal na zmanjšanju porabe cpu-ja kot pa na neki veliki pohitritvi. Tako bo največji TDP 77W, kar je velik napredek(če napovedi veljajo).
_IKE_ ::
Nekje sem zasledil da naj sedanje plošče 1155 ne bojo podpirale IVY bridge, oziroma samo z modifikacijo katero bi opravili v tovarni, kar v praksi pomeni nove plošče za IVY bridge
Evo tu je novica: http://www.guru3d.com/news/upgrading-to...
Svasta. To bi blo res veliko razocaranje, ampak tudi pri intelu to ni nic novega.
Ja in?
Mas edino se starejse, ki pravijo, da naj bi IB delal na P67,H67 in Z68 platah.
JC Denton ::
OP zmaga :) Sicer pa precej pričakijem od IB, kje so meje velikosti (majhnosti) tranzistorjev. KOlikor sem videl neke slike, imajo napovedane 10nm čez 5 ali 6 let. Kaj pa potem, 7nm, 8nm?
Webeg ::
Dejte me popravit prosim ce se motim.
Kolk jst razumem naj bi se Intel pri IB minimalno izboljsal clocking pa naj bi se bolj posvecal VGAju pa zmanjsanju porabe?
Torej bi se mi trenutno splacal pocakat, da releasajo IB pa da spustijo cene SBju ter ubavt SB po nizki ceni in z malo nizjim performancom clock-wise?
Za VGA te pa tko boli ce mas grafo?
Nevem od kje imate te ideje,da bo zaradi nove serije, cena starim padla. Cene sicer ves cas padajo, ampak velikih pocenitev zaradi nove serije ne bo, nikoli jih ni bilo, tko da nehite sanjarit.
Rippy ::
Definitivno ne bo nekakšne ogromne pospešitve v primerjavi z SB. Nekje sem bral, da arhitektura omogoča 37% višjo zmogljivost ali 50% nižjo porabo v primerjavi z SB. In glede na razne prezentacije (in verjetno AMD BD) večino truda usmerjajo v ekonomičnost na strani CPU (in višjo zmogljivost na strani GPU).
Izjemno zanimiva informacija pa bo kako 3D tranzistorji delujejo pri višjih frekvencah (overlock). Lahko bomo imeli izjemno dober scaling frekvence (in zmogljivosti) ter nizko porabo pri tem.
trnvpeti ::
Vse zgleda da ne bo nic kaj napredka proti sandy.
Sej je logicno, ni konkurence, in zakaj bi.
Skoda da je amd zajebal z bd.
M-XXXX ::
kmetek ::
Isotropic ::
je pa beda, da bo tudi socket 1567 al neki takega, za xeone. skoda, ker ne morejo met tega poslihtanega - samo 1155 in 2011 pa je stvar resena.
a bo ivy bridge imela memory on board?
http://semiaccurate.com/2010/12/29/inte...
glede na anandtech sicer ne, razen ce je to surprise feature. bi bilo pa super, ce nebi bil samo gpu-only, magar vsaj v sb-e.
zakaj IB (ali SB oz. vsaj sb-e) se nimata FMADD instrukcij? clovek bi rekel, da je to no-brainer za HPC aplikacije...
- spremenil: Isotropic ()
Mitja358 ::
Intel Fakes the Ivy Bridge DirectX 11 demo at CES 2012 Press Conference
V čem je fora? Če so res toliko izboljšali SB GPU (in verjamem da so), zakaj potem tega tudi ne prikažejo?
Heh, dobra
Verjetno jih jebejao kaksni gonilniki, tako kot pri Atomih.
tt2 ::
Kdaj pa bodo sploh na voljo tile laptopi z ivy bridge. Ker zdajle na CES-u firme kar ena za drugo prestavljalo laptope z iva bridge, ampak če se ne motim sem nekje bral, da naj bi ivy bridge bil na voljo šele proti poletju.
Ocitno tudi Intel ni imun na tezave. Je pa ze rahlo bedno, da se toliko prestavlja. Takole je lani AMD mutil z bulldozerjem.
http://www.fudzilla.com/home/item/26087...
RC14 ::
Očitno se bo zavleklo v poletje,takrat se tudi ponavadi ne kupujejo računalniki, pač dopusti, morje, lepo vreme...
Dolgo prihaja ta Ivy bridge
Sam imam počasi namen zamenjat sistem, pač ga bom očitno šele jeseni, hvala bogu, da se mi ne mudi
:4770K@4.5GHz @ BeQuiet!Dark Rock Pro2; MSI Z87 GD65 Gaming; 16GB RAM:
::GTX 1060 6GB; SSD Samsung 840 EVO 250GB; SEAGATE 3TB+3TB+1TB; LG 27"IPS::
:::: XFX 850W Black Edition; X-Fi Titanium; Fractal Design ARC R2 ::::
filip007 ::
Kaj naj pa pokažejo, da je Phenom II X4 hitrejši z neko HD4850 kot pa Ivy Bridge na Intel HD za precej manj keša. No vem niso vse igre, samo kaj pa sploh še ostane velikim.
Zero games, zero talk.
- spremenil: filip007 ()
Mene mal skrbi, da bo imel ivy bolj kratko zivljensko dobo.
Ce pride haswell prej kot konec nasledjhega leta, je to prst v rit kupcem iyvja.
RC14 ::
Ivy bridge bo res imel kratko življensko dobo, kakšno leto.
Drugo leto okoli marec-jinij naj bi izdali haswell, seveda če napovedi držijo in če ne bo zamud.
To me malo jezi, računalnik bom verjetno kupoval jeseni in takrat se bo počasi približeval haswell in glede na to,da se mi ne mudi za nakup, bom mel dve možnosti:
1. ali takrat kupit ivy bridge
2. ali pa malo počakat in vztrajat na starmu compu , pa pol nabavit haswell in novi LGA 1150 socket.
Tako pač je v računalništvu, če čakaš, potem nikoli ne kupiš, ker vsake pol leta al leto pride kej novega in hitrejšega ven.
Je pa vprašanje, kolikšne izboljšave bo prinesel Haswell?
- spremenil: RC14 ()
RC14 ::
Sj pravim, če ne bo. Predvidevamo pa tk verjetno vsi, da bo zamujal in se bo premaknil izid v jesen 2013.
Pa tudi vprašanje, kolikšno pohitritev bo sploh doprinesel, to bo "tock", torej enaka 22nm tehnologija kot Ivy bridge, izboljšave predvsem pričakujem na grafičnem področju in večji potencial "varčevanja z energijo". Kakšne posebne pohitritve v primerjavi z Ivy bridge procesorji v vsakdanjih opravilih pa jaz osebno ne pričakujem.
RC14 ::
Glede na njihov plan (napoved izida), torej marec/junij 2013.
Sicer je pa to še tako daleč, da še sami intelovci ugibajo te stvari.
modicr ::
Intel 'Ivy Bridge':Everyone Please Calm Down
http://www.forbes.com/sites/patrickmoor...
"Jon Carvill, at Intel Media Relations, reiterated via email that the reports of an eight week delay were inaccurate and that the schedule had only been impacted a few weeks. He went on to say that they were on track with their launch guidance to be in-market for spring and they expected to ship 50% more units of Ivy Bridge in the first two quarter of production as compared to Sandy Bridge parts.
So Intel and my industry ecosystem contacts are aligned here. Ivy Bridge systems will hit the back to school selling season."
(c) nisem patentiran
- spremenil: modicr ()
Janac ::
mislim da se intel lga 2011 socket bolje splaca oz sandy bridge extreme!
imas podpora za velikooooooooooooo RAM-a, quad chanell!
imas cpuje na socketu 2011, ki so sestjederni!
je pa res da so maticne drazje...
eieieie1 ::
Pa kaj ti bo VELIKOOOOOOOOOOOOOO rama, če pa ga več kot 4GB ne rabiš, medtem ko ga lahko imaš 16GB na lga 1155 plati. Pa kaj ti bodo šetjederni 700/1000€ procesorji, če pa jih 95% ljudi ne rabi in jim je čist dost kak i3 ali i5 procesor za 100-200€.
A si pripravljen dat 500e za cpu in 250e za eno vsaj priblizno dobro plato?
mayne ::
Janac ::
ja sej ce rabis sestjedernika pa pac vzames, ane?
ne nisem, sem pa 290e za cpu in 250e za plato
- spremenil: Janac ()
eieieie1 ::
Ampak ta ni 6 jedern
Kaj pa pol sanjas z 6 jedrnih procesorjih?
In kaj tocno ti pomaga quad chanell, ce je pa pocasnejsi, kot dual na 1155?
Na LGA1155 lahko tudi 32GB rama utaknes not, ce je res sila.
| » | Mnenje o Matični Plošči in Procesorju (strani: 1 2 )Oddelek: Kaj kupiti | 14692 (14000) | touchspeed |
| ⊘ | nov pc gaming (strani: 1 2 )Oddelek: Strojna oprema | 11785 (10870) | fr4nc |
