AMD Radeon HD 7900
AMD Radeon HD 7900
16 / 50
klinker ::
Gigahertz je izjavil:
PrimozR je izjavil:
x45 je izjavil:
N vidi bi morala mal spustit cene:
http://www.agt.si/racunalniska-oprema/g...
N vidi? Kdo je N in kaj točno vidi??
lol, ni stavka da ga kdo nebi napadu;((
Se cudis :D
JC Denton ::
haha
AMD Pulls Hysterical Cape Verde Marketing Stunt
Reviewers who have probably received their AMD Radeon HD 7700 series samples by now, were taken aback when they found a prescription medication bottle in their packages. No NVIDIA-styled Press Deck booklet, or even former-ATI styled Ruby doll, but a medicine bottle, which reads "Verdetrol". The label directed them to insert the blue capsules inside it to the heat vents of the graphics card, when benchmarking, so it "acts as a performance enhancement".
The point in all this? Apparently AMD's Radeon HD 7770 features 1 GHz core clock speed out of the box, making it the first GPU ever to do so, and AMD wants to make a song and dance about it. What's more, AMD will use a special branding called "GHz Edition" to mark all its future SKUs that come with 1 GHz (or more) GPU core clock speed, indicating that AMD has more SKUs in the pipeline with >=1 GHz core clock speed. It doesn't stop with this hysterical medicine bottle thingie, no sir, AMD even set up a teaser site dedicated to "Verdetrol".
verde= zelena
Hahahhahha ta je dobra :D
http://verdetrol.com/
  • spremenil: D3m ()
Jakob_X ::
ce pogledas html source pa pise:
header("X-LOL-Kepler: So Late");
Sem vidu ja. :))
Janac ::
jutri izidhe 7770HD
fireX88 ::
  • spremenil: fireX88 ()
Janac ::
fireX88 je izjavil:
jp
cene in specifikacije:
http://videocardz.com/30579/radeon-hd-7...
testi od nvidie 680
http://videocardz.com/30564/nvidia-gefo...
hvala za link, car:D
fireX88 ::
knda, sj vem da sm 8-)
sm tole malo v zakup uzami...grafe pr nas bojo kakih 200€...zaenkrat.. :)
Janac ::
komi čakam kšne teste, sam 200e bo preveč napihnjeno...
fireX88 ::
sj to bo na začetku...čes čas bo ziher cena padla, še vedno je!
RC14 ::
tele specifikacije od nvidie 680 in ostalih kartic, so en velik nateg.
GTX 680 core clock 1050 MHz, malo morgen,prej bi rekel max okoli 800MHz.
Memory Interface samo 256 bit,
Memory Bandwidth 186 GB/s, hahaha. torej manj od GTX580. čist tko za osvežitev, GeForce GTX 580 ima Memory Bandwidth 192 GB/s
kr neki.
:4770K@4.5GHz @ BeQuiet!Dark Rock Pro2; MSI Z87 GD65 Gaming; 16GB RAM:
::GTX 1060 6GB; SSD Samsung 840 EVO 250GB; SEAGATE 3TB+3TB+1TB; LG 27"IPS::
:::: XFX 850W Black Edition; X-Fi Titanium; Fractal Design ARC R2 ::::
  • spremenil: RC14 ()
69charger ::
No shit sherlock,če bi malce ljudje najprej pogledali pod commente kaj pišejo admini,zgleda so tistega ki je napisal teste bannali zaradi lažnih informacij že na eni drugi strani.
galu ::
Kdaj pa so neki pre-release testi na neki X strani od X uporabnika bili verodostojni?:))
Tako to gre.
Machiavelli ::
RC14 je izjavil:
kr neki.
Ja sam je arhitektura bolj prepustna izkoriščena,tak da 256bit pa 186GB/s je pomoje čist kul,če pogledaš clocke in ostalo bo cca30-40% močnejša od gtx580 kar je 10-15% močnejše od 7970 za nižji znesek not bad :D
Nigaaazz
_koki_ ::
Mater si ti wannabe "2pac" prizadet, pri teh specifikacijah Nvidijinih grafičnih kartic nikjer ni pohabljenih modelov z zaklenjenimi SP, že to ti pove, da niso resnični!
Specifikacije keplerjev, ki so resnične za moje pojme, so že objavljene, upam le, da so resnični tudi datumi izidov, drugače nvidija ne bo veliko keplerjer niti prodala do takrat ko jih boš sploh lahko kupil!
PrimozR ::
Machiavelli je izjavil:
RC14 je izjavil:
kr neki.
Lej, drop it, tista razpredelnica je bila fake, to se je videlo že iz geostacionarne orbite (precej visoka orbita).
Test HD 7770 in 7750:
http://www.anandtech.com/show/5541/amd-...
7770 bo pa dobra zamenjava za mojo 4770 :)
  • spremenilo: FireSnake ()
Mr Hilter ::
FireSnake je izjavil:
Pa mojo 4750 :). Čeprav ne igram igric sem zadnjič za hec navil procesor (AMD 5050E) in grafo, pa je Crysis 2 tekel kot namazan???????
Mr Hilter je izjavil:
ABX ti bo rekel, da je to nemogoče. Ne more ti teči "kot namazana" saj imaš vendar AMD procesor. :P
ABX ::
Pa mojo 4750 :).
Ste sploh prebrali članek?
6850 je hitrejša in stane manj.
  • spremenilo: ABX ()
Tako je. Zakaj kupiti novo, ko pa imate lahko staro. :P
FlyingBee ::
7770 in 7750 sta tud že vzunaj, ampak so rezultati porazni
New Sphincter Kvartet:
ABX ::
Rezultati so OK glede na porabo, cena je porazna.
FlyingBee ::
res je v samem vrhu glede zmogljivost/poraba http://www.techpowerup.com/reviews/AMD/...
je pa visoko tudi HD5450 pa vemo, da nima veze, čeprav ni prav tako primerjat, saj 7770 zmore dosti več in je primerna za igre
imaš prav glede cene na zmogljivost http://www.techpowerup.com/reviews/AMD/...
verjetno so tako naredili, da bo 7850 in 7870 spet Sweet-spot
ABX je izjavil:
Vse sem prebral, brez skrbi!
Hočem hitro in hladno kartico. Trzam tudi na nove tehnologije.
Si sploh prebral članek?
ABX ::
Da, 25W nižja poraba (in temu primerno nižje gretje) ne oprošča razlike v ceni.
Še povzetek članka, ker očitno si bral nekaj drugega.
The problem for AMD today isn't the power/performance curve, it's the price/performance curve. 16 months ago AMD launched the Radeon HD 6850 at $179 amidst fierce competition from NVIDIA. Ignoring the current price of the 6850 for the moment, on average the 7770 delivers 90% of the 6850's gaming performance for 90% of the 6850's launch price. In other words in 16 months AMD has moved nowhere along the price/performance curve - if you go by launch prices you're getting the same amount of performance per dollar today as you did in October of 2010. In reality the 6850 is much cheaper than that, with a number of cards selling for $159 before a rebate, while several more 6870s sell for $159 after rebate. The 7770 is so far off the price/performance curve that you have to believe that this is either a pricing error or AMD is planning on quickly halting 6800 series production.
So pa izjeme da, nekdo ki želi ultra kompaktno kišto brez aktivnega hlajenja recimo.
Če bi imel 256-bitno vodilo bi nategnil HD6850 :D
JC Denton ::
Ma, sem pričakoval malo več, mi pa ustreza nizka poraba. Glede performance/wat se zadeve pričakovano izboljšujejo z vsako serijo. Glede cene pa nebi zaenkrat preveč razpredal, kolikor sem videl se bosta hd 7850 in 7870 prodajali po 249€ in 299€. Če hočemo nižje cne, mora nVidia čimprej kaj poslati na trg. Ampak kolikor poznam njih, tudi oni nebodo prodajali prav poceni, tak da vrjetn ne bomo mogli dolgo gledat na trenutni price/performance. Pomoje se bo s to generacijo p/p mal spremenil(poslabšal).
Čez 2 meseca. Ane Machiavelli. :D
BALAST ::
Se vidi, da letos ne bo kupcev za grafične, cene so enostavno previsoke.
Usrane HD7750 in GTX560 brez TI so preko 160€, v sami zmogljivosti pa na ravni srednjecenovnih 2generacije nazaj.
HD7750 bi morala biti 80€ HD7770 pa 100€
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
Machiavelli ::
7770 oskubljena navita zmazkarija za zasoljeno ceno ?
90-100eur max
120-130eur pa je 6850
nemorš pa dat 160-180eur ceno looool
D3m je izjavil:
čez cca 2-4dni bo že mogoče nekaj prikazano,kar pomeni 4-7 tednov do odgovora :D
Nigaaazz
Janac ::
moja 5770 bolša od 7750 lol
JC Denton ::
Kar je pozitivno pri tej seriji je to, da je GCN res korak naprej od vliw5 in vliw4. 640 unified shaderjev (hd7770) proti 960 us (hd6850) in sta kartici precej blizu, sploh če upoštevamo da ima ena 128 bitno vodilo druga pa 256.
Janac ::
FlyingBee ::
ja, produkt ni slab in pametno (na žalost ni dobro za nas) z višjo ceno, saj ni konkurence z novimi produkti še, pa še lepo pripravi prostor za 7850 in 7870, ki bosta imeli višje cene kot če bi bile 7770 že zdaj 50 dolarjev cenejše
škoda je (že zdaj lahko vidimo), da bosta oba proizvajalca na ta račun imela višje cene midrange produktov kot je bilo do zdaj v navadi in so bile 6870 in 560 kraljice (veliko krivde imajo tudi konzole, ker so igre manj zahtevne in s tem smo prišli do tega, da recimo že 6870 za 170 EUR lahko poganja vse)
ABX ::
Vse ki uporablja staro tehnologijo.
Imaš igre kjer tudi top kartice komaj da dihajo na max nastavitvah.
ABX je izjavil:
Kakor za koga ... če nekaj velja azte tega ne moreš posplošit na vse.
FlyingBee je izjavil:
Malo si zamudil, ker sem jaz zgoraj že podal link ;)
90-100eur max
1) nove tehnologije niso za siromake!
2) Zakaj ne bi mogel nastavit take cene, če pa komot prodaš? Glede na to, da prodajo vse, kar dajo na police bi bilo zelo neumno nižat cene. Sploh, če nimaš konkurence (oziroma je zaspala).
Ampak, ti tega nisi sposoben dojet.
FlyingBee ::
FireSnake, prav imaš in treba je pogledati širšo sliko, ki žal kaže, da bodo kartice srednjega razreda dražje, ker ni konkurence in s tem se bo celoten trg spremenil, kar je za nas nekaj novega, saj smo bili navajeni 3 leta gledat dovolj dobre grafične kartice, za najnovejše igre na high nastavitvah, pod 200 EUR. Zdaj pa so že high-end grafične okoli 500 EUR (prejšnja serija 6950 in 6970 sta bili okoli 330 EUR).
Stojansto: se strinjam, ampak enim to dopovedat ... to je pa težko.
Meni je v interesu, da nVidia izda kartico, enakih ali boljših zmogljivosti in z manjšo ceno, že jutri.
Čeprav ... zeleni in nizka cena ne gresta ravno skupaj ...
Se strinjam z obema. 4-7 tednov čakati na nvidio je predolga. Koliko časa je zdaj odkar je AMD izdal 7900 serijo? 3 mesece?
Machiavelli ::
D3m je izjavil:
em konec Feb. bo komaj 2 meseca od realne dobave,torej ni tako grozno,itak pa vsi špili delajo čist normalno že na 1-2leti starih grafah tak da se nemudi konzole so pa itak še vedno iste lol
Nigaaazz
fireX88 ::
samo da daš kontra in plus nvidi...isti klinca ko x45..žal!
D3m je izjavil:
A si se sprijaznil, da je GTX400/500 serija čisto dovolj, in lahko pozabimo na Keplerja za par mesecev. :D
Machiavelli ::
Ejga jst sem na strani potrošnika,podpiram konkurenco če bi Nvidia prva izdala bi pa podpiral AMD da čimprej izda da cene se mal umirijo,sicer pa rees nevidim logike izdajat kartice katere so komaj 10% hitrejše od prejšne top serije za uber višjo ceno,poleg tega na koncu dneva firma kešira potrošnik pa lih kaj z tem neprofitira....uzamimo kartice srednjega ranga 6950/6970 560/570 so več kot dovolj za vse špile singel displey no 3D,že recimo še ena generacija pred to je dovolj močna za karkoli lol zdj pač mal manipulirajo manjši nm je cenej za firmo,manj šejderov dajo gor spet cenej,vodila in rami so pa zdaj itak poceni,in nato mal navijejo driverje tweekajo in walla prodajo za masten denar.....
Nigaaazz
Machiavelli: eni vsaj prodajajo. Drugi samo spijo :P
Jaz bi dal še več denarja, če bi lahko dobil grafo na 22nm, pa je lahko enako zmogljiva, kot 7770.
Res pa je, da bom z nakupom počakal do izida Diablo III, mogoče celo profitiram kakih 20EUR :D
PrimozR ::
Ampak konkurenco imajo! 6850 je cenejši in zmogljivejši od 7770. Poraba pa zanemarljivo višja (obe tako ali tako potrebujeta 6pin napajanje, 7750 rešuje to, da se napaja samo preko reže).
Kaj pa bi imel od tega, poleg minimalno nižje porabe? Razlike v nižji porabi itak ne bi pokril v MNOGO letih. Torej v tem ni računice.
  • spremenil: PrimozR ()
To, da imajo konkurenco znotraj je jasno.
Odvisno potem od osebnih preferenc, kaj boš vzel.
Jaz raje kupim novejšo stvar, pa dam mal denarja zraven.
V končni fazi: že 4770 zadovolji moje potrebe kar se tiče iger ...
Kar se tiče porabe: ne računam jaz na to, da bi se mi nakup povrnil, ampak želim, da se moje računalo ne greje (pretirano).
In za to sem pripravljen tudi plačati.
Kriza, da mora AMD samemu sebi biti konkurenca. :D
Senitel ::
Ma glej, če rabiš novo grafično: just go for it.
GPU Technology Conference je najavljen za letošnji maj že lep čas. In ja, bil je prestavljen, ampak je tudi bil prestavljen že skoraj eno leto nazaj. Da boste pa pri dveh produktih, ki sta v razvoju okrog tri leta videli predstavitve praktično sočasno od dveh podjetij, pa boljše da pozabite.
V bistvu bi rekel kar: please go for it. Ker imam občutek, da se znotraj AMD-ja kuha nekaj čudnega.
16 / 50
Grafična kartica (strani: 1 2 )
8615915 (14026) Brias
Najboljša grafična kartica pod 200EUR.
246454 (5804) Brias
