Kako dobiti referer?
poweroff ::
Zadeva je takale...
imam eno skripto, ki ob kliku odpre pop-up.
Ta pop-up je nek PHP script. Vendar je problem v tem, da tu ne dela HTTP_REFERER. Torej ne morem ugotoviti od kje je bil ta pop-up pognan.
Rešitev naj bi bila taka, da bi pop-up pognal s parametrom, v stilu popup.php?referer=*****.
No, vprašanje je, kako to narediti.
JavaScript koda je tale:
var win = null;
function NewWindow(mypage,myname,w,h,scroll){
LeftPosition = (screen.width) ? (screen.width-w)/2 : 0;
TopPosition = (screen.height) ? (screen.height-h)/2 : 0;
settings = 'height='+h+',width='+w+',top='+TopPosition+',left='+LeftPosition+',scrollbars='+scroll+',resizable';
refererlocation = document.location.href;
mypage = mypage + '?mainreferer=' + refererlocation;
win = window.open(mypage,myname,settings);
win.window.focus();
Link naredim takole:
< a href="popup.php" onclick="NewWindow(this.href,'emailme','350','450','no');return false" > Popup < /a >
Samo zadeva ne dela!
Kakšna ideja kako rešiti ta problem?
Ziga Dolhar ::
Hmmmm.
Vržeš notri <?=$_SERVER['HTTP_REFERER']?> ;)
poweroff ::
Ja, saj ravno to ne dela.
Če kliknem na navaden link dela, če pa kliknem na link, ki požene pop-up, pa ne dela.
Ziga Dolhar ::
Argh, površno branje, sorry.
JavaScript popup
Oddelek: Izdelava spletišč
92825 (2646) *pety*
Problem v javascript
101105 (1025) TinLADEN2
resolucija
61547 (1438) poweroff
Javascript/PHP vprasanje
52880 (487) rasta
mysql help
82483 (2279) poweroff
