VB2010 config file + custom sections
korenje3 ::
A kdo ve kako narediti custom sections v config datoteki?
Private Sub fmysql_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        '        Dim config As System.Configuration.Configuration = ConfigurationManager.OpenExeConfiguration(ConfigurationUserLevel.None)
        Dim config As System.Configuration.ConfigurationSection = System.Configuration.ConfigurationManager.GetSection("appsettings")
        config.CurrentConfiguration.Sections.Add("test", config)
skoraj vse možne kombinacije sem že probal, pa mi ni uspelo, razen v appsettings, ki je default section.
Torej kako recimo naredim section korenje znotraj configuration sectiona, kako potem to prebiram in manipuliram z temi podatki...
[VB] ConfigurationManager
Oddelek: Programiranje
51136 (1048) Looooooka
Spreminanje connectionStringa v app.config C#
61244 (1180) Ericssony
[VB] Komunikacija s serijskimi napravami
412733 (2007) mNeRo
Visual Basic.NET - za začetnika ?
305290 (4409) mHook
VB.net MDI in formi splošno
91977 (1920) strel
