Forum » Programiranje » VB2010 config file + custom sections
korenje3 ::
A kdo ve kako narediti custom sections v config datoteki?
skoraj vse možne kombinacije sem že probal, pa mi ni uspelo, razen v appsettings, ki je default section.
Torej kako recimo naredim section korenje znotraj configuration sectiona, kako potem to prebiram in manipuliram z temi podatki...
Private Sub fmysql_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
' Dim config As System.Configuration.Configuration = ConfigurationManager.OpenExeConfiguration(ConfigurationUserLevel.None)
Dim config As System.Configuration.ConfigurationSection = System.Configuration.ConfigurationManager.GetSection("appsettings")
config.CurrentConfiguration.Sections.Add("test", config)
| » | [VB] ConfigurationManagerOddelek: Programiranje | 1136 (1048) | Looooooka |
| » | Spreminanje connectionStringa v app.config C#Oddelek: Programiranje | 1244 (1180) | Ericssony |
| » | [VB] Komunikacija s serijskimi napravamiOddelek: Programiranje | 2733 (2007) | mNeRo |
| » | Visual Basic.NET - za začetnika ?Oddelek: Programiranje | 5290 (4409) | mHook |
| » | VB.net MDI in formi splošnoOddelek: Programiranje | 1977 (1920) | strel |
