sql max count
sql max count
boss-tech ::
Spodaj najdem prenočišče z največ gosti. v select sem dal count (število gostov) + naziv prenočišča.
Kako lahko zgoraj pri max dobim še naziv? Ker spodnja koda mi vrže error (Error code -1, SQL state 42Y35: Column reference 'NAZIV' is invalid. When the SELECT list contains at least one aggregate then all entries must be valid aggregate expressions.
Line 2, column 1)
#prenocisce z najvec gosti
select max(cnt),naziv from
select count(naziv)as cnt, naziv from prenocisca
inner join sobe on sobe.pre_id_prenocisce = prenocisca.id_prenocisce
inner join gosti on gosti.sob_id_soba = sobe.id_soba
group by naziv
)f
WarpedGone ::
select naziv
from
select count(naziv) as cnt,
naziv
from prenocisca,
sobe,
gosti
where sobe.pre_id_prenocisce = prenocisca.id_prenocisce
and gosti.sob_id_soba = sobe.id_soba
group by naziv
order by 1 desc
)f
where rownum < 2
Zbogom in hvala za vse ribe
boss-tech ::
Order by ne pusti... ko ga odstranim pa dobim: Column 'ROWNUM' is either not in any table in the FROM list or appears within a join specification and is outside the scope of the join specification or appears in a HAVING clause and is not in the GROUP BY list. If this is a CREATE or ALTER TABLE statement then 'ROWNUM' is not a column in the target table.
WarpedGone ::
Potem pač Order by prestavi nivo višje.
Očitno tvoja baza ne pozna ROWNUM funkcije.
dice7 ::
poskusi s tem
SELECT COUNT(p.naziv), p.naziv FROM prenocisca p
INNER JOIN sobe s ON s.pre_id_prenocisce = p.id_prenocisce
INNER JOIN gosti g ON g.sob_id_soba = s.id_soba
GROUP BY p.naziv
ORDER BY COUNT(p.naziv) DESC
LIMIT 1;
  • spremenil: dice7 ()
Sql poizvedba
Oddelek: Programiranje
111813 (1317) zgubar
Podatkovne baze - SQL enostavne poizvedbe
72526 (2119) galu
SQL poizvedba
164181 (3526) awy
sql select stavek
121903 (1805) zavajon
MYSQL vprašanje
132171 (1786) MrBrdo
