AMD Bulldozer
AMD Bulldozer
JC Denton ::
Zgleda da bo naslednje leto tudi AMD presedlal na HKMG.
"Your roadmap this morning laid out 28nm, in 2013 across, almost all of your products. Will you lean toward a more High-k [process], or more SiON [process], or a mix?" The answer to these two questions was both short and firm from Mr. Akrout, "Since you asked twice we are going to get you an answer. All of them are in the High-k metal gate. Across the board
x45 ::
tole je bull . amd ima seja SOI z high k metal na 32 nm. 45 nm je SOI.
x45 ::
Opteron - test - dobra zadeva :):
http://www.anandtech.com/show/5279/the-...
ABX ::
Ni ne.
We have a number of these in our data center and they have been a disappointment. Single threaded performance is low and the memory sharing performance under VMWare is poor. That leaves it only competitive for DB and web servers work which is OK but it doesn't make a compelling case for the architecture as similar Intel offerings perform well in all tasks. AMD still has a small price advantage, but once you add the VMWare licensing and data center costs the percentage difference is negligible.
PrimozR ::
x45 je izjavil:
A lahko še v enem bolj razumljivem jeziku morda?
x45 je izjavil:
DObra zadeva na račun ugodne cene (in visoke porabe), če te zanima HPC. Ostalo je pa bolj ko ne MEH.
  • spremenil: PrimozR ()
ABX je izjavil:
Ni ne.
Da se ti da.
"Typical answers, I debate such results all the time with many IT departments all over the world so called "standardized on and runs bette on" statements. So you have a large number of these new Opteron 6200 series already in datacenter and already got this info out of it, yeah right. Our virtual datacenters with approx 1000 servers exist out of AMD based systems, the only time i thought about swapping to intel after performance/price/power review was when intel released the Nehalem (oh and perhaps the Socket R but can't disclose that yet, neither do I want to swap that fast knowing that abu dhabi is about to go in Beta samples already). In the low price 2s-4s (not talking about the over expensive EX versions) the AMD are still owning the virtualization with there multicore and more memory channels with lower price.
Poor single thread has indeed been an issue for magny cours to a certain extend but not that it is noticable on a normal level of applications (you sound like a superpi user that only looks at theoretical results), poor memory sharing, care that to explain :). I suggest you have a look at general best practices on power settings for virtualized environments before complaining about response and throughput.
These response time result measured here are not noticable in any general application and once adding some kernel overhead from NFS/iscsi or whatever in medium - high load servers forcing these tasks to HT cores will show quite a bit different result in platform performance. Anandtech Vapp results from are nice but are still not a full reflection of datacenter performance and the results are heavy influenced by the webapp which clearly seems to favor the Intel architecture. Neither does have the Vapp testing any iscsi/nfs kernel related tasks which many sites do have (to reduce infrastructure cost)
Vmware licensing cost more for AMD? only for the enterprise edition, the abandoned vmware license version which was introduced again for v4 because of OEM pressure... time to investigate more before buying anything... advanced - enterprise plus has no difference for any core you would select and neither does v5 have."
|HP EliteBook|R5 6650U|
x45 ::
super ugodna cena top plošče ( 990 FX + sb 950 ):
http://geizhals.at/eu/679889
test:
http://www.tweakpc.de/hardware/tests/ma...
Your killing me. Stop it.
Isotropic ::
še en test opterona, jasno se vidi, kako prehiti intela na celi crti (4. graf)
The Opteron 6276: a closer look
PrimozR ::
x45 je izjavil:
test:
Zakaj linkaš trgovinsko stran ene, test pa druge plate? A si resno tako hudo nepismen, da ne ločiš med Extreme3 in Extreme4 (da ne omenjamo barvne slepote, ena plata je praktično popolnoma črna, druga pa modro-bela s črnim PCBjem...)?
Isotropic ::
no ja, saj je tudi tadruga plata sorazmerno poceni, 140e...
ABX ::
Professional troll, ni kaj.
Glede na to da je debata dolga 71 strani za izdelek ki nima nobenega smisla pove vse.
P.S: Izjema je par aplikacij ki zna koristit 8 jeder (nobena igra).
  • spremenilo: ABX ()
Mitja358 ::
No jaz pa sem že pred uradnim izidom odločen, da bom kupil Trinitija za namizni računalnik. Če bo 75xx oz. 76xx na voljo za dual GPU je to v bistvu sedanja 6000 serija ne? :D
Mitja358 ::
AMD "Trinity" APU Models Further Detailed
P.S. A ni bilo rečeno, da bo podpora za 2133 MHz RAM-e?
  • spremenil: Mitja358 ()
Isotropic ::
Isotropic je izjavil:
x45 ::
sicer je teško verjet kOko moderatorji spijo ali pa še slabše PRISTRANSKI SO .
Še ena o zadnji poravnavi intel - AMD:
to pomeni da je INTEL kriv ( že spet ) samo mu ne morejo dokazat in jo je poceni izmuznil... ( tokrat ).
Škoda da se AMD ne ukvarja bolj z zmogljivostn kavalitetnim dizajnom FX cpu jev tolk kot s Tožbami. Povprečen IT paglavc tule gor je tolk napalamuden od intela da morjo skori bit 20 % večji pr amd ju da bo kdo vsaj rekel B od boljši je...
  • spremenilo: x45 ()
WTF je napalamuden??? Google ne najde nič???
Eh, x45 ima kar velike težave z izražanjem oz. s sestavljanjem razumljivih stavkov. Da pa bi to moral še pravilno napisati, pa je že čista znanstvena fantastika.
Tu imaš en dokaj sveži test, kjer je lepo prikazano, da razni popravki (patch/hotfix) bistveno ne pripomorejo k hitrosti izvanjanj ukazov. Testirali so FX-8150:
http://www.tomshardware.com/reviews/win...
V določenih operaciah je Buldožer z nameščenim(i) popravkom(ki) celo nazadoval.
Kateri procesor se splača izbrati za ceno do 200 $ (okoli 150 €):
http://www.tomshardware.com/reviews/gam...
trnvpeti ::
opeter je izjavil:
in kaj je sklep/povzetek? katerega se splaca?
ABX ::
To sem že jaz linkal. Samo so si pokrili ušesa in kričali "la la la la la".
Dejstvo je, da za igre i3 pokopa bilo kateri AMD cpu.
ABX ::
trnvpeti je izjavil:
opeter je izjavil:
Za igre:
Pentium < i3 < i5
ABX je izjavil:
A že spet s tem moriš! Dej linkaj spet i3 vs. FX-8150
  • spremenil: D3m ()
ABX je lepo napisal ...
Na zadnji strani je nazorno opisano:
Interestingly, the best gaming value in AMD's FX family is its affordable FX-4100. Neither the FX-6100 nor the FX-8120 offer an advantage over this $110 model. Otherwise, things look bleak for AMD enthusiasts hunting for a new gaming rig. You can make the argument that the frame rates offered by FX and Phenom II processors are sufficient, but that's a tough stand to take in light of the competitive benchmarks. Let's be clear; in GPU-bound games, you wouldn't be able to tell the difference. But, to be perfectly frank, Intel's processors are the obvious choice in titles that do demonstrate reliance on host processing power. It simply doesn't make sense to spend more for less. And, in many games, high-end AMD processors demonstrate a quantifiable performance deficit compared to the Core i3-2100. For $190, a stock Core i5-2400 gets you more gaming prowess than any AMD CPU can hope to deliver right now, even overclocked.
AMD je trenutno slaba alternativa.
Kurac slaba alternativa. Govorite, kot da je defekten.
M-XXXX ::
D3m je izjavil:
Za tak denar in take obljube... Da je!
Absolutno. Trenutno AMD v nobenem cenovnem segmentu ne more konkurirati in ni primerljiv z Intelom, sploh, če kupiš ločeno grafično.
Edina svetla točka je Llano, ampak to je bolj slaba tolažba.
Če rabiš surovo CPU moč, trenutno vzameš Intel, ki mu ni para.
Počakajmo na Trinity in Piledriver, a dvomim, da se bo kaj (v smislu CPU zmogljivosti) močno spremenilo.
  • spremenil: opeter ()
todman74 ::
Imam Phenom X4 9550 in 9800 Gt grafo....torej, če zamenjam svoj zanič procesor z i3, bom dobil v igrah več FPS-ev, kot katerikoli AMD gepl, z najnovejšimi super duper grafami noter. Očitno bom prišel ceneje skoz, kot sem mislil....:)
mr1two ::
V bistvu bi jaz na tvojem mestu grafično menjal. 9800gt ni ravno state of the art ta trenutek :). en primer
Vsaka grafa za 150e ali manj je boljši vložek(rabljena 5850,460,6850) kot pa plata+cpu+ram(blizu 200 prideš z i3,h61+usb3 in 8gb) za igre.
69charger ::
Z 9800gt se da čisto lepo igrati na nekih srednjih nastavitvah ala 1440 resolucije in medium grafične nastavitve. Več dobiš trenutno z dobrim procesorjem saj je napredek iz AM2 -> 1155 očiten. Ravnokar sem sprobaval eno čisto novo kištico z Celeron G530 in moram rečt da žal Athlon X3 popuši.
trnvpeti ::
in g630 je dovolj zmogljiv do vsaj 6850?
todman74 ::
Hvala, mi je precej jasno kako stvari stojijo, ampak čakam na odgovore s strani "kolegov" @opeter, ABX in M-XXX.
ABX ::
Tu ni debata v nadgradnji ali zamenjavi obstoječe opreme. Ampak zato da poenostavimo debato, ker očitno nekaterim tudi to dela preveč težav za njihov IQ, se govori o nakupu novega CPU-ja.
Ima AMD CPU smisla za igre? Ne nobenega. Bilo kateri model izbereš, Intel ima cenejšega ki gre hitreje.
Še hujše, Imaš AMD Phenom serijo in bi rad novejši AMD CPU? Nima smisla, vsi so počasnejši.
todman74 ::
ABX je izjavil:
Iz tvojih prispevkov lahko nek "laik" razbere, da je i3 z integrirano grafiko hitrejši, kot FX-8150 z AMD 7970 grafo notr....hudo zavajujoče...
ABX ::
Ne samo ti lahko ker si troll.
Kaj ima tu veze GPU? Govorimo samo in izključno o CPU-ju. i3, tako kot bilo kateri AMD CPU ,lahko ima tisti GPU ki ti srce poželi.
in i3 + 7970 je hitrejši od FX-8150 z 7970 za manj denarja. Ok zdaj, ali še kaj ni jasno?
ABX je izjavil:
Nimam kaj dodat.
x45 ::
ni vse tako črno belo :
http://www.tweaktown.com/articles/4348/...
razlika je en fps za dražji intel 2600 k.
ali pa to:
nižje navit buldi vs 2600k je 1 fps HITREJŠI:
http://www.tweaktown.com/articles/4353/...
x45 ::
fireX88 ::
zopet si naredil napako, ker bodo rekli da je to le en izmed mnogih testov.... če pa že gledate procesorje samo za igranje ste pa res eni debili, žal drugega vam nemorem rečt..
pa 1fps je 0 zame!
pa še to, ko sem kupoval pc sem seveda po formu vprašal kaj bi bilo boljše, in mi je en lepo odgovoril: Vse je v glavi!!! negleda kaj boš kupil (v mojem pirmeru je pc star nekaj več kot 4 leta) boš naredil preskok v hitrosti/odzivnosti/zanesljivosti!!
x45 ::
pa tule še to:
http://www.legitreviews.com/article/175...
core i3 pa res nima kaj iskat tukaj.
pa TOLE:
CONCLUSION:
Z vsemi bonbončki platforme am3+ in ugodno plato 990 fx + sb 950 je tole pač boljši nakup.
pc MARK PRO:
IN JA tole je test z znanimi komponentami ki jih ima večina doma:
DDR3 1866 in ati 6950 grafa
fireX88 ::
ABX je izjavil:
potem takem je tudi i3 napram i7 boljši nakup, s tem da ima i3 recimo 10~20 manj fpsjev (če jih ma recimo i7 okoli 70) je potem to za NORMALNE LJUDI zadovoljivo in seveda ne za geeke ki hočejo imeti 120+ fpsjev a ekran imajo samo 60Hz...
x45 ::
Za igrce je igralni plošček najboljši nakup.
ABX ::
x45 je izjavil:
ali pa to:
No no, poklikaj malo naprej in če GPU ni omejitev je i7 za 100% hitrejši.
x45 je izjavil:
pa tule še to:
pa TOLE:
Končno en pameten link, me presenečaš (brez sarkazma, da ne bo pomote).
fireX88 je izjavil:
ABX je izjavil:
Tvoj denar, tvoja izbira. Jaz sicer zagovarjam navit i5 za igre. Ampak če ti denar leze iz riti tudi i7 je dobra izbira. Ker ne razumem, je zakaj plačat več za počasnejši CPU (AMD).
Počasnejši CPU? Nekam čudno predstavo imaš, kaj je počasen CPU.
fireX88 ::
ABX je izjavil:
nism mislu da bi šel kupit i7, ampak sem ti dal takšen primer (oz vsaj podoben) kot si ga dal ti...2 jedra napram 8im oz 2 jedra napram 4im...mislim what what??
ABX ::
x45 je izjavil:
Če te ne zanima tehnologija in ti je ok igrat 5 let staro zadevo, potem da. Konzola je pravi nakup zate.
Če pa gledamo nakup CPU za aplikacije, potem se zadeva še bolj zakomplicira. Vsak program se obnaša drugače in je nemogoče priporočat en CPU.
todman74 ::
ABX je izjavil:
Kaj si že študiral, da si prišel do tako "bistroumne" ugotovitve....da vidim, kje "delajo" takšne "genije"....
In mimogrede, prejle sem špilal Skyrim, tekoče 40+ FPS, z AMD mašino, medium nastavitve, na resoluciji 1680x1050.....seveda si ti trdil v eni, že zaklenjeni "temi", da to ni možno, da moraš za to igro imeti Intel in to dobesedno.
Nemogoče priporočat CPU?
Se pravi če hočem poganjati nekatere programe moram kupiti točno določen CPU, ker drugače mi AMD ne more odpreti Chrome, medtem, ko ga Intel lahko????
WTF???
ABX ::
todman74 je izjavil:
ABX je izjavil:
40 FPs ni tekoče.
http://frames-per-second.appspot.com/
Še 60 FPS ni perfektno. Če bi danes kupoval monitor/TV, bi definitivno zbral takega z 120Hz inputa.
_koki_ ::
A ti veš kaj pomeni 40+ fps, da je 40fps minimum, kar je zagotovo dovolj za normalen gameplay brez zatikanj! Zatikanje oko zazna pri manj od 24fps...
Spet si dal ta link. Se mogoče norca delaš? Si mogoče kaj prebral za kaj je ta stran?
71 / 128
