Samael ::
Akhm ... :) Tole je sploh zabaven del. En mnogih. Ampak se je nekdo potrudil in tako lepo razloži da je treba samo enih 10x prebrati, 20x poizkusiti, uštekati zaporedje klikov ob ostalih dveh modes, dvanajsih svetlobnih kombinacijah itd ... in potem iti dalje, na ostale nastavitve.
(lahko pa seveda pustiš vse tako kot je, ampak potem pač ne izkoristiš opcije superiornejšega UI-ja).
In my opinion, only a TRUE flashlight geek might appreciate the way this sequence is set up. For the average person, who might only own one or two LED flashlights, this promises to be a tad hairy! So follow me closely on this one.
To access the 'blinking' modes when set to Ramping... you MUST get to TURBO mode first. So, perform a DOUBLE-CLICK (from anywhere) for turbo, then DOUBLE-CLICK again. Strobe is where you'll be at this point. Now, you can get to the other FOUR blinky modes if you want...BUT...just like when ramping, if you snooze...you lose!
Here's the deal. Let's say you want Beacon #1, which is the FOURTH mode in the chain. You need to get to Strobe, then click through 'Police Strobe' and 'Bike Flash', and you need to do it QUICKLY! If you pause on ANY of them, the one you pause on, is locked-in, and you CANNOT get to the next one unless you start over again!! So, what you would need to learn, is how many 'clicks' it takes to get to the mode you want. Think of it as licking a Tootsie Pop! So, Beacon 1 is THREE clicks from Strobe. Bike Flash is TWO clicks from Strobe. Got it?
Now, just to make it interesting... once you're 'locked-in' to any blinking mode OTHER than Strobe... you can actually GO BACK to the previous mode, by performing a HOLDING PRESS! (but as soon as you see it activated, release the button) Isn't that interesting??
https://lightsngear.com/incredibly-brig...
Saj ti pravim, lahko da sem samo jaz glede tega (ne mislim zgolj to kar sem kopiral, tisto je zgolj delček vseh klikov, preštevanja itd) nekoliko "lesen" in rabim čas in potrpežljivost, vsekakor pa to res ni lučka za vsakogar in je, če nisi v tem, najboljše vse skupaj pustiti pri miru oz. se držati klasičnega Convoy 3 + 2 & memory mode UIa :)
  • spremenilo: Samael ()
perci ::
Pa dej no....jaka muda vsi ti mode-i. Bedarija. Rabim tri jakosti + ramping in to je to.
koyotee ::
perci je izjavil:
Wrong, rabiš ramping in turbo :D
Rear DVD collector!
JTD power!
Samael ::
Mimogrede, glede na to, da nas ima kar nekaj tu Q8, a se je že kdo dejansko v detajle spopadel z vsemi UI nastavitvami in uredil lučko v vseh detajlih, ki jih ponuja, po lasni meri? Tako iskreno? :)
firbec ::
Samael je izjavil:
jest niti slučajno NE. Mene že moti tista zelena ledica, ko sveti pri uganjeni lampi. Imam feeling, da mi kuri baterijo :|
in preden sem prebral da s 4x klikom na gumb ledico ugasneš, tega nisem vedel.
Kje so še ostale nastavitve, na tistih navodilih je tega za diplomsko spisat.
Jest furam on/off, pa dimm, drugega nič.
Luč je pa bomba
Samael ::
firbec je izjavil:
Lučke ni treba "zakleniti" ali celo odviti pokrova, da ugasne tista ledica. Še en manj drastičen način je (kopiram iz linka zgoraj), samo osvojiti ga je treba :p
...you’ll start with the light OFF. Now press and hold the switch until ‘moonlight’ appears. The SECOND it comes on, click the switch again. If you did it fast enough, the flashlight will be OFF as well as the green indicator. . If you WEREN’T quick enough, the flashlight will be ON, and the indicator will be OFF… in which case you’ll need to try again.
firbec je izjavil:
Samael je izjavil:
Luč je pa bomba
Jaz isto. Pritisnem enkrat za vklop (in potem za izklop), držim pritisnjeno, da nastavim svetlost. In to je to.
firbec ::
jest pa Okapi sva važna, ker imava Q8, kje se pa nama da ubadat z miljon nastavitvami, v končni fazi svetlobo, k jo rabiš, prtegneš, kaj čš komplicirat :))
looser ::
Nice wheels, indeed.
gregor ::
Samael je izjavil:
Seveda, sem celo šel v šolo za to lučko, imajo na kitajskem BLF Q8 akademijo ;)
Nimam časa, da bi se ukvarjal z tisoč nastavitvami, glavno da sveti :D
Nova klarus lučka:
http://budgetlightforum.com/node/63885
KLARUS 360X3
All-new 360º "Switch Ring" Tactical Flashlight XHP70.2
iz 3200 lm na 400 lm, to pa je res čudno, kaj niso mogli še npr 1000 lm dat zraven...?
Tsunamii ::
Bo kakšna naslednica Klarusu XT12GT ? Lusna trowka je. Pustmo da mi pije zivce, ker ena od 3 je bila fuč. Zdaj bi rad kupil zamenjavo..in ne vem al čakam zamenjavo al kar kupim XT12GT ..
Je pa butasto da iz 3200lm pade na 400lm... Isto ima tudi XT12GTjka.. iz 1600lm na 400lm ;((
  • spremenil: Tsunamii ()
Aar2rk ::
Zanflare F1 za 13,34€
polpo ::
Aar2rk je izjavil:
S kodo SDDeal35 je še 2$ manj :)
perci ::
topla je
Groot ::
Eno vprašanje za znalce tukaj. Je kakšen problem če v Sofirn C8A vtaknem baterijo, ki ima 10A? Nekje sem namreč prebral, da je priporočljiva baterija s 6A
Podobno me zanima za Zenflare F1, katero baterijo najbolj priporočate?
  • spremenilo: Groot ()
Samael ::
Ne, prav nobenega problema ni. Vse 18650 baterije delajo pri F1 in C8A lučki in več A ne spremeni ničesar. Več amperov (konstantni električni tok) pomeni samo, da bodo pri polno moči delale tudi lučke, ki vlečejo več toka iz baterije kot ti dve. Teh lučk ni prav dosti.
Najbolj optimalne (pa ne da bo lučka kaj bolj svetila, le glede na kapaciteto/ceno) so pa omenjene tri (GA, 35E...) mislim da eno stran nazaj, ampak kot pravim, lučki delata na vse 18650 baterije.
edit. baterija, ki si jo linkal je super, pa tudi cena ni napačna
Samael ::
Mimogrede, mini High 94 CRI BLF Sofirn C01 AAA lučka za 6.5USD je ta moment na aliju na voljo. Če jo bo kdo kupil, jo daj v košarico, ampak ne plačaj (izberi "Other payment methods", kar pomeni, da bo nakup ostal ampak ne bo še plačan) in kontaktiraj trgovca in povej, da si z BLF foruma, da prilagodi ceno. Mislim, da bi to moralo zadoščati, ker ni bil klasičen group buy, ampak so zbirali imena zgolj, da so videli če je dovolj interesa, da gredo v to.
Ne gre za klasično BLF "the more - the marrier" lučko in ne pričakuj kakšnega posebnega outputa. Njena posebnost je fantastična HIGH CRI Yuji 5mm ledica - zadnja tega tipa (sofirn jih je kupil kolikor se je pač dalo, zdaj so pa discontinued).
Design goals for a high CRI 5mm twisty AAA flashlight
- true unicorn light: fantastic value because of high quality and low price
- high reliability based on robust design (design goal: as bomb-proof and torture-proof as Fenix E01)
- preferably "fully potted electronics driver board" (similar to Fenix E01 )
- high-CRI output (thanks to the Yuji 5mm LEDs)
- small (71 mm x 14.2 mm)
- light-weight
- cheap (Sofirn stated 6 USD)
- constant-current
- no (visible) pwm flickering
- simple operation (single mode
- preferably true battery vampire which also works with on a drained battery with a voltage lower that 0.9 Volts
- long runtime (first regulated, and with depleted battery also long unregulated runtime) (design goal is at least the runtime of a Fenix E01)
- waterproof (IPX8)
- tailstand capability
- runs on plain AAA batteries (alkaline, NiMH, or L92 lithium primaries)
- preferably a polished aluminum reflector for at least some throw to increase to usefulness of the ~10 lumen light output
BLF tema: http://budgetlightforum.com/node/61138
V kontekstu svetlobe ni za pričakovati nek hud output. Tu jo mnogo malih lučk nese. Je bolj lučka za na ključe, popolna recimo če v temi iščeš ključe (tu HIGH CRI pride do izraza :-), bereš knjigo v šotoru, itd.
Nekaj, kar nihče tu v resnici ne rabi, je pa za 6,50 USD luštno imeti :P
Samael ::
Samael je izjavil:
Tole zgoraj se sliši čisto narobe :P
Moral bi zapisati:
Je bolj lučka za na obesek, popolna recimo če v temi iščeš ključe (tu HIGH CRI pride do izraza - razen če jo izgubiš skupaj s ključi :-)
Groot ::
Samael je izjavil:
Super hvala ti
bauci ::
Sem narocil ročno svetilko F1. Ker prvič kupujem ročno svetilko me zanima kako močno baterijo 18650 naj kupim in ali se ta baterija lahko polni na navadnem polnilcu za polnilne baterije (ala Eneloop) ali moram kupiti posebni polnilec oz. ali se da baterijo polniti preko USB kabla v ročni svetilki?
perci ::
Kupi nekaj čez 3000mAh iz zaupanja vrednega vira, npr. nkon.nl. Ne kupovat Ultrafire in podobnih fire baterij iz AE.
F1 ima vgrajen polnilec, tako, da lahko polniš direktno prek usbja.
firbec ::
@bauci, welcome to the club ;)
če sprašuješ zgolj za F1, ne potrebuješ polnila, ker lahko baterijo te lučke filaš s pomočjo USB kabla
potrebuješ torej le 18650 baterijo, lahko jo nabaviš pri nas (Conrad, Bolha), iz tujine pa jo boš dobil iz kot je Perci omenil nkon.nl ali še ceneje iz AE https://www.aliexpress.com/item/6PCS-20... tega je ogromno, zato se na ta link ne oziraj preveč, je zgolj za pomoč. Perci, sem jih kar nekaj naročil iz AE, niti z eno baterijo nisem imel problemov, je pa res pa nobena ni Ultrafire 8-O
bauci, boš pa slej ko prej potreboval polnilec, ker če boš to temo začel spremljati bolj redno, boš postal zbiratelj 18650 lučk, kot nas je že kar nekaj tu gor :D
18650 baterija se na navadnem polnilcu ne more polniti, ker je že fizično večja in je ne boš spravil not, je pa tudi polnilcev za 18650 je malo morje, mislim da se ne bom zlagal, če rečem, da je za navadne uporabnike najbolj dostopen LiitoKala polnilec https://www.gearbest.com/chargers/pp_66... ali https://www.banggood.com/Liitokala-Lii-...
drugače pa dobrosošel med lučkarje ;)
Samael ::
bauci je izjavil:
...ali se ta baterija lahko polni na navadnem polnilcu za polnilne baterije (ala Eneloop) ali moram kupiti posebni polnilec oz. ali se da baterijo polniti preko USB kabla v ročni svetilki?
Če je polnilec le za NiMH polnilne baterije (ala Eneloop), potem na njemu ne moreš polniti litijevih. Če je univerzalni za oba tipa baterij (tako NiMH kot li-ion) jih lahko. Načeloma je označeno na samem polnilcu kateri tip baterij lahko polniš.
Ostalo ti je odgovoril perci :)
darkolord ::
Če ne ve kaj kupuje, 18650 iz AE ni ravno priporočljivo kupiti, ker lahko dobiš svašta.
Pri nas je še Batte-Trade, kjer so dobre baterije, cene pa niso prav dosti višje od nkon, še posebej če kupiš samo nekaj kosov.
bauci ::
Hvala za nasvete. Sam sem razmisljal, da bi baterijo in polnilec kupil kar pri nas v trgovini Delko.
Sem se pa za nakup odločil, ko sem prebral te strani in se res bojim, da bom "padel notr" in že iščem kakšen dober izgovor za ženo zakaj rabim 10 lučk :).
firbec ::
bauci, Delko je ok, samo se boš pač znebil več E
drugače pa ženi tole zbirko od našega prjatla pokaži :))
VIP58 ::
Pri Delku 50€ za polnilec in par baterij ne bo dovolj. Je pa res da jih dobiš takoj :))
Polnilec, če kupuješ univerzalnega, naj ima najmanjši polnilni tok vsaj 300 mA, za AAA baterije, še bolje je 200 mA.
Too much of everything is just enough.
bauci ::
Firbec, to pa je zbirka :).
Se zavedam, da bo pri Delku drazje. Bom na podlgi vaših nasvetov še malo poguglal, saj tut svetilke ne bom dobil jutri.
Še to. Ali ima kdo povezavo do www strani, kjer so razložene vse "skrivnosti" o tem kaj kakšna stvar pri lučki pomen - izrazov in funkcij je pri posameznih lučkah cel kup pa nisem siguren, da vse prav razumem.
VIP58 ::
bauci ::
Super. Hvala.
Samael ::
bauci je izjavil:
Evo, slovarček izrazov http://flashlightwiki.com/Terminology :)
Še ena misel na hitro - aktivno sodelujoči v tej temi uporabljamo en kup raznoraznih polnilcev. Nekateri celo več nji. Ampak skorajda vsakdo ima doma pri bajti vsaj enega LiitoKala Lii - 500. Zakaj? Ker je relativno enostaven in poceni (tam okoli 15USD), polni skorajda vse standardne tipe baterij (tako litijeve kot tudi NiMH) in ima soliden, informativni LCD zaslon + funkcijo discharge test (ki omogoča preveriti kondicijo/kapaciteto polno napolnjene baterije).
bauci ::
Sem ravnokar narocil LittoKala polnilenec in dve baterije 18650 na Aliexpress. Hvala vsem za nasvete.
firbec ::
bauci, lansko leto tega časa sem nekje v tej temi resno spraševal, kaj za vraga potrebujete toliko lučk, kaj z njimi počnete vsi ???
Tako se je začelo. Danes ti raje ne povem, koliko si jih lastim :))
In tudi zate vidim, da si dobro startal. Pripravi se na akcije, bližajo se prazniki :D
gregor, oglasi se še ti, predstavi bauciju kakšno noviteto na legendarnem tepihu ;)
Groot ::
VIP58 je izjavil:
Že pred časom sem kupil en LiitoKala univerzalni polnilec, ki pa ima najmanjši polnilni tok 500 mA. Kaj to pomeni za polnjenje manjših baterij, glede na to, da sam priporočaš nižje vrednosti?
Samael ::
To je najbrži lii 100 ali lii 200 ane :)
500mA pomeni, da bodo baterije manjšega formata (AAA/10440) pri polnjenju pod večjo obremenitvijo in pregrevanjem, kar ni najbolj zdravo za baterijo in vpliva na življensko dobo baterije. Načeloma naj se ne bi zgodilo nič drastičnega, le življenska doba baterije bo krajša.
Jaz običajno polnim AAA/10440/AA/14500 baterije na 300mAh, ker sem prelen, da bi ven vlačil Nitecore D4 za 150mAh.
Samael ::
Lumintop Tool AA/14500 2.0 127m EDC Flashlight na BG S kodo AC18 samo 14,70USD
Package included:
1 x Lumintop Tool AA 2.0 LED Flashlight
1 x O-ring
1 x user manual
1 x Diffuser
1 x Warranty card
1 x Spare DIY Magnetic Tail
Naročeno! :)
Zdaj pa samo še kakšen link za primerno 14500 baterijo potrebujem? Nimam še nobene.
perci ::
Tsunamii ::
Fantje, če bo kakšna spet dobra akcija kot je bila letos za Klarus XT12GT ( 55€ sem dal s popusti..) bi vas prosil za opozorilo oz kuponcek s popustom 8-) Hvala :)
perci ::
xt12s se dobi za 50 eur, če te zanima
Tsunamii ::
perci je izjavil:
Me mika .. in bi o kupil..sam ni throw.ka. Sem upal da naredijo naslednico GTjke..sam ocitno ne se. Rabim da mi sveti na daleč in priročna za repliko..pac takticna lucka :D
perci ::
LOL, pa kolk daleč vi vidite, ljudje. xt12s ima kao 400m throwa :). A mate vaše lampe na Dragunova našraufane :).
Tsunamii ::
perci je izjavil:
:)) Hehe. Poglej si video recenzijo za XT12s .. je pac floodka. Nima usmerjenega snopa. Poglej si video recenzijo XT12GT in bos videl ocitno razliko. Ja..glej. Folk imas nocne in termalne zadeve. Zato je za nas pomebno da jih odkrijemo. Ta s varjanta nima niti priblizno 400m ..niti GTjka nima 600m ..
gregor ::
Bauci, dobrodošel med lučkarji.:D
Vsakemu novemu lučkarju običajno povem to:): vsak pravi lučkar mora imeti convoy s2+ in convoy c8 oz c8+ (novejši model)...
Pa polnilec litokala 500.
Se hecam, seveda vsak nabavi, kar želi.
Kode za nižje cene se dobijo...
Moj legendarni tepih ;) je čez poletje, do sedaj počival. V prihodnje bo nekaj veš akcije. Nekaj že imam naročeno. Ko dobimo, gre tepih spet v akcijo.
Do takrat pa so tukaj moje stare slike:
Convoy S2+ desert tan
https://imgur.com/a/zvHpd
Convoy S2+ red
https://imgur.com/a/HV8lt
Emisar D4
https://imgur.com/a/2hZd5
BLF Q8
https://imgur.com/a/gSrkT
BLF Q8 holster - FLYYE INDUSTRIES
https://imgur.com/a/WY6pj
Zanflare F1
https://imgur.com/a/pp4cG
Convoy BD06
https://imgur.com/a/e3hkU
Nitecore TIP SS Tropical
https://imgur.com/a/PX9Br
Convoy C8
https://imgur.com/a/gcD7S
Convoy C8 holster, Convoy S2+ holster
https://imgur.com/a/g2md8
Nitecore EC4S
https://imgur.com/a/wgOM5
Convoy C8 silver
https://imgur.com/a/xIyiy
Astrolux K1
https://imgur.com/a/JDYrR
Nitecore TINI
https://imgur.com/a/o47op
BLF GT
https://imgur.com/a/LJWHM
BLF GT (SHORT TUBE)
https://imgur.com/a/dC4Un8U
WUBEN T046R
https://imgur.com/a/Q3svxDj
Emisar D1S
https://imgur.com/a/JstwT
Gregor's Flashlights - 12.4.18
https://imgur.com/a/39fwe
Veliko več slik pa je na zgornjih linkih.
Aar2rk ::
Pri Litokala 500 me moti, da se ne da polnit večjih NiMH D baterij. Ampak taka je itak večina.
hunter01 ::
@gregor
dodaj https://flashlight.nitecore.com/product... na seznam za v prihodnje, če bo kaka ugodna cena. Super lučka, UI z 2 gumboma je top.
radmannsdorf ::
Iščem kabel za svetilko/paralizator, model Police 1101.
Ker me Aliexpress verifikacija debetne kartice heca, ne morem naročit s tam. S Poljske je predraga poštnina.
Ima kdo tak kabel za prodat, oz. ve kje bi se ga dalo dobiti v Sloveniji?
Je pa konektor malo manjši kot za brivski aparat. Ne, ni tak kot za stare radijske sprejemnike(tisti je bil še večji).
https://www.aliexpress.com/item/100V-24...
gregor ::
hunter01 je izjavil:
@gregor
saj to je problem, da za NC ni kod za nižje cene oz so kode zelo omejene...
ja pa to tudi precej star model, z "samo" 460 lm
koyotee ::
EC21 se je dobilo za okoli 22$, par let nazaj ;((
Rear DVD collector!
JTD power!
gregor ::
ja, vem :'(
________________
že nekaj časa razmišljam o nabavi tretje emisar lučke, imam že D4 in D1S
Emisar D4S 26650 High Power LED Flashlight
ima kdo od vas poznavalcev kakšno idejo ketero ledico izbrat
https://intl-outdoor.com/emisar-d4s-266...
Led & Tint
Neutral White - Nichia 219CT 90CRI, 5000K
Cool White - SST20 6500K
Neutral White - SST20 5000K
Neutral White - SST20 4000K 95CRI
Cool White - XP-L HI V3 1A, 6500K ( +$15.00 )
Neutral White - XP-L HI V2 3A, 5000K ( +$15.00 )
Neutral White - XP-L HI V2 5D, 4000K ( +$15.00 )
Cool White - XP-L HD V6 1A, 6500K ( +$15.00 )
Neutral White - XP-L HD V6 3D, 5000K ( +$15.00 )
OTF lumen output and candela at start-up
XP-G2 S4 : 3300lm / 40,000cd
Nichia 219C : 3000lm / 20,000cd
XP-L HI : 4300lm / 45,000cd
XP-L HD : 5100lm / 27,000cd
SST-20 6500K: 4200lm / 58,000cd
SST-20 5000K: 4000lm / 55,000cd
SST-20 4000K 95CRI: 3000lm / 41,000cd
pomembna mi je kvaliteta svetlobe in ne največ lm, ker za par sekund mi je čisto vseeno če imam 3000 lm ali 5000 lm
kaj bi vi vzeli?
danes so bili na seznam dodani:
teh ledic ne poznam, so za kaj?
155 / 351
