Samael ::
Zanimivo Zanflare C4 Multifunctional Battery Charger je DISCONTINUED :)
Koliko časa je to sploh bilo na trgu? Slabo leto, mogoče manj?
Jaz sem prav zadovoljen, da sem takrat dva stegnil za tisto super mega zanimivo ceno pod 14USD :)
gregor ::
ni več kod, ugodnih cen in več noben ne kupuje tega ;)
se pa sedaj dobi pri Nealu - BLF GT lučka za "samo" 230 usd ;)
https://m4dm4x.com/blf-gt-free-cap-for-...
  • spremenil: gregor ()
Koliko pa je bila v štartu?
koyotee ::
90€ z DHL dostavo v prvi skupini ;((
Rear DVD collector!
JTD power!
Hehehehe
gregor ::
za vse ljubitelje xiaomi telefonov ;)
Xiaomi FZ101 Portable Zoom Flashlight
http://budgetlightforum.com/node/60785
Specifications:
- Model: FZ101
- Material: aluminum alloy
- Input: 5.0V 1.0A
- Interface: USB Type-C
- Battery Capacity: 2600mAh
- Power: 10W Max.
Main Features:
- Lightweight Mini Design:
With its mini size, it is portable for you to bring it outside. The body is made of premium aluminum alloy with strong and sturdy design.
- 672 Lumens Brightness:
The max brightness is 672 lumens, meeting your needs of night camping, running, observation or exploration perfectly.
- 2600mAh Large Capacity Battery:
Comes with a 2600mAh large capacity battery, bringing you a brightness endurance for 2375mins.
- USB Charging Port:
With the USB Type-C charging port, providing great convenience for you.
- Unique SOS Mode:
It is unique with the SOS mode. Press the function button to send a distress signal.
knap ::
ZANFLARE T1 350lm Rechargeable 18650 Tent Lamp
http://budgetlightforum.com/node/60913
matobeli ::
matobeli je izjavil:
Evo, spet naročil lučko. In to LANTERNO! Končno dobil tako kot sem želel. 18650, warmwhite, regulacija... celo usb polnjenje.
Zanflare T1
https://www.gearbest.com/outdoor-lanter...
Z kuponom hišnega GB zastopnika pride nekaj manj kot 15eur in ena baterija je celo zraven!
Mogoče bi kar še eno naročil.
Že uporabljam 2komada zadnjih 5dni na kampiranju.
Odlična mala lučka, sveti lepo rumeno (in tudi belo), močna je dovolj za šotor ali mizo, imam večino časa nekje na 30% ker je drugač kar preveč.
Magnet je dovolj močen da ne odpade kar tako, overall build quality pa je tudi na nivoju zanflare.
Edino navadit se je treba da moraš za izklop držat 2sec mali gumjast knofek na spodnji strani, ki se ga sicer lepo najde, ampak če ga samo pritisneš bo zasvetila rdeča.
Druga zadeva pa je hendlanje, ker je zgoraj kapacitivni knof ki ga hitro pritisneš po nesreči.
Baterija zgleda kot da ima realno kapaciteto.
Skratka, priporočam nakup. Sicer cena v group buy ni blazno ugodna (jaz sem dal malo pod 15eur z poštnino).
Če najdem kakšen tepih jo malo poslikam.
gregor ::
V group buy bo ta lučka stala 99 usd.
Ne vem kako se vam zdi cena, ampak meni to ne deluje ravno ugodno, poceni...
koyotee ::
Daleč od ugodnega, bi morala bit še vsaj 20€ cenejša.
Rear DVD collector!
JTD power!
knap ::
klasika zadnjih mesecev, ni več pametnega za primerno, ugodno ceno...
čakamo na božič, novo leto :D, očitno je to še edino upanje, da bodo cene padle na raven, ki je bila v lanskem letu oz začetku tega leta...
koyotee ::
Pizda tok je bla BLF GT ne pa še ena generična xhp70 svetilka s čudno razporejenimi lumni ;((
Rear DVD collector!
JTD power!
Tsunamii ::
Je kaksna 'takticna' luč ala Klarus 12GT ( katera ima takticni gumb zadaj za direktn strobo..) ..lahko je tudi na vecje baterije..samo da lahko pritrdim na orozje ter seveda obvezn gumb zadaj .. ? Omenjeno luč mi namreč se zdaj niso povrnili stroske in sem preklemano jezen..vendar rabim novo se letos!
perci ::
Xt12s se dobi za 50 eur.
Mam 3 in sem zlo zadovoljen.
koyotee ::
Tsunamii je izjavil:
Strobo pa orožje mi pa ne gre skupaj ;((
Rear DVD collector!
JTD power!
hunter01 ::
koyotee je izjavil:
Potem najbrž nisi airsofta igral. Vsaj ne nočnega. =)
Ko si navajen na temo in se začne bliskat po gozdu ti ni nič jasno :)
Tsunamii ::
hunter01 je izjavil:
koyotee je izjavil:
True :))
Sem pozabil omenit da je to airsoft oz rabim za repliko 8-)
Perci ne kupim vec Klarusa ... ker sem slabe volje..dal 50€ in nisem dobil povracila denarja niti menjave ( po parih dnev je zadeva crknila..in se ne da menjat driver..nic..) so rabim nekaj drugega..lahko je mocnejsa v lumnih in na vecje baterije. Vseeno...samo da ima taktični gumb za direkten strobo ! 8-)
hunter01 ::
Pred leti, ko sem se sam ukvarjal z identičnim problemom, kot ga imaš ti sedaj, mi ni uspelo dobiti primerne svetilke. Od takrat je bilo sicer celo morje novih svetilk na trg dodanih, tako da upam, da najdeš primerno! :)
koyotee ::
Kaj pa če ma samo strobe?
Rear DVD collector!
JTD power!
Tsunamii ::
koyotee je izjavil:
Rabim seveda tudi da orenk posveti..vsak kot Klarus 12GT. Slednja je imela 2 gumba zadaj..enega za strobo drugega za osvetlitev - lusna throwka drugace.
gregor ::
Here we go again ;)
Kdor ni nabavil BLF GT, predraga, prevelika...
Morda pa se vam bo bolj dopade:
MINI BLF GT :D
http://budgetlightforum.com/node/60960
knap ::
morda bo celo MICRO GT :)
koyotee ::
Škoda ker ni 26650 in zgleda kot kaka c8 :)
Rear DVD collector!
JTD power!
gregor ::
na misel mi pride emisar 1ds, ne vem pa kakšna bo razlika v velikosti...
kumer ::
zanimiva zadeva je tale blf gt mini oz micro
če je blf gt stal cca 100 usd, potem lahko pričakujemo da bo mini stal 30 usd ;)
in če bo group buy upam, da se ne bo ponovilo dolgotrajno čakanje (več mesecev) da zadevo proizvedejo
gregor ::
nisi dosti zgrešil...
group buy je že aktiven:
http://budgetlightforum.com/node/60983
cena za blf mini gt bo 40 usd, ni ravno poceni, če primerjamo z blg gt
ampak ker je blf lučka, jo je seveda potrebno nabavit :);)
nove slike:
boste nabavili? :D
koyotee ::
Ne ker ni nič posebnega :)
Rear DVD collector!
JTD power!
Samael ::
Jaz sem ponovno na lovu za solidno AA/14500 lučko do 11USD.
Eno Utorch UT01 sem že pred časom podaril, eno pokvaril, tako mi je ostala še ena, cena pa zdaj ni tako ugodna.
Če ne najdem UT01 ali kaj vsaj približno primerljivega za solidno ceno, bom šel najbrž na budget Sofirn SF10 / SF12 ali, ko bodo aliexpress akcije na malo boljšo Sofirn SP10A / SP10B.
Če v prih. dneh opazi kdo kaj v tem formatu do 11USD prosim sporoči tu :)
Zdajle, ko naokrog skačem bolj lahkotno oblečen, se mi zdijo mala ampak še vedno preklemansko zmogljiva 14500 lučka koristenjša kot karkoli na 18650 baterijo.
14500 lučka & budget star Xiaomi R4 pro ponoči:
Samael ::
Ta reč BlitzWolf(R) 15W 2A Foldable Portable Dual Usb Sun Power Solar Cell Panel Charger ima izredno dobre ocene in za razliko mnogih malih sončnih polnilcev v ustreznih vremenskih razmerah menda celo nafila telefon, baterijo itd.. v nekem doglednem času. Dva USB izhoda, dodatki, vodoodporno ...
S kodo 6897bf znižano na 17.99USD, kar se mi zdi izredno dobra cena. Poštnine ni.
matobeli ::
Zgleda res dost OK, sem ga že gledal. Dimenzije celic res ustrezajo 15W. Kar bi celo v najboljši možni osvetlitvi (ekvator ob 12h) dalo ven celo 3A, kar pomeni da je 2A (10W), realna zmogljivost.
Nasploh me BlitzWolf še ni razočaral.
P.s. a se tudi v BG kode kaj spuščaš? GB ravno BW nima v ponudbi, pa tako fine kable in polnilce imajo.
  • spremenilo: matobeli ()
Samael ::
Če naletim na kaj fajnega v sklopu s to temo in se mi zdi, da bi znalo zanimati tudi druge, prilimam, to je pa to :) Saj veš, kode so takšne in drugačne prisotne ves čas, medtem ko si nihče nas tu ne želi masovnega spama s tem :) Če nabašem na kaj, kar se mi zdi res res solidno, bom, kot vedno prilimal tu :)
V osnovi se mi zdi, da ima BG dražje cene/manj popustov kot GB, pa hkrati (vsaj v sklopu mojih lastnih interesov) tudi več brand quality zadev, pri čemer tu pa tam dajo na kaj kvalitetnega popust, ki je res konkreten, ne pa zgolj prenapinjena cena navidezno za nekaj drobiža znižana.
  • spremenilo: Samael ()
Samael ::
@matobeli
Blitzwolf 2018 midyear sale
www.banggood.com/collection-6140.html
m3k ::
@Samael
Utorch UT01 APP only cena - morebitne točke ;)
Mirko tipka na radirko ////
Samael ::
Saj tam okoli $15USD z raznoraznimi popusti je večino časa :) Bom pogledal, ko bom doma, koliko lahko to še s točkami dol zbijem. Hvala.
mat xxl ::
Sam še vedno iščem kak ovitek ali nekaj takega za spravilo BLF Q8, katera me res še vedno, kar nekaj po nakupu navdušuje z svojimi 5000 lumni.
Verjetno je normalno, da luč po ene 10 minutah svetenja na maximumu, kar sama zmanjša svetilnost za ene 30% ?
Torej , če kdo ve za kak zaščitni ovitek, ali torbico za v avto, naj svetuje.
gregor ::
jaz imam tega in je super...
https://www.aliexpress.com/item/Genuine...
več slik pa je tukaj:
https://imgur.com/a/WY6pj
gregor ::
očitno bomo kmalu imeli 100 variant blf gt lučk
poleg BLF GT in BLF GT MINI sedaj še:
The BLF GT70 "Giggle Monster" is coming! 7,500lumens, 1,500m throw!
http://budgetlightforum.com/node/61334
LUMINTOP BLF GT XHP35 HI CW/ NW 2000lm 2km Thrower Flashlight
http://budgetlightforum.com/node/61216
o ceni 100 usd pa lahko samo sanjamo ;)
mat xxl ::
Ja žal BLF Q8 z svojimi 5000 lumni in ceno pod 80 usd ostaja še vedno best buy ......
barakus ::
Je kdo zasledil kakšen popust za skilhunt H02 ali H03?
gregor ::
mat xxl je izjavil:
še vedno je na voljo z kodo za 46,50 usd
gregor ::
barakus je izjavil:
tukaj je flash sale
https://www.gearbest.com/led-flashlight...
ceneje pa nisem našel
v "dobrih časih" se jo je dobilo za 25 usd...
barakus ::
gregor hvala
knap ::
začela se je predprodaja BLF GT MINI
https://m4dm4x.com/wp-content/uploads/2...
cena $39.95
bo kdo nabavil?
specing ::
Kaj naj bi bila razlika z Emisar D1(S?)?
Koliko nizko je do sedaj prišla cena Manker E03H Nichia čelke?
gregor ::
jaz imam emisar d1s
https://zeroair.wordpress.com/2017/12/2...
zato se (še) nisem odločil za nakup
nisem tudi gledal kakšne so razlike, večjih razlik verjetno ni
emisar ima precej hrapavo površino, se hitro vidijo sledi rok, gt mini ima verjetno bolj gladko površino...
še slike d1s:
https://imgur.com/a/JstwT
Brainstorm ::
Je mogoče kdo naročil v group buy Haikelite SC26 CREE XHP35 HD/HI 2050Lm 26650/26350
http://budgetlightforum.com/node/61314
mat xxl ::
gregor je izjavil:
mat xxl je izjavil:
Hvala 100 x za to kodo, sem ker sem z prvo tako zadovoljen še eno naročil, pride 41,80 eur.......
Blf Q8 za ta denar z 5000 lumni je zakon ! Samo še kako dobro torbico ali škatlico iščem, ker te, ki jih ponujate mi ne sedejo preveč...., sicer pa kartonska embalaža bo tudi za silo za v avto....
gregor ::
ja, Q8 je zelo dobra lučka za ta denar
seveda gre za flood lučko
če kdo išče throw lučko pa ni primerna, tukaj je emisar d1s ali sedaj blf gt mini boljša izbira
oz še precej ceneje se dobi convoy c8 - klasika, ki jo vsi imamo ;), še vedno imam kakšne 3 v omari :D
skozi moje roke pa jih je šlo že ogromno
ali ti zgoraj omenjena FLYYE torbica ni všeč, ja pa že boljša kot pa da nimaš nič oz imaš v kartonski škatli
gregor ::
q8 holster
tukaj je še ena varianta:
Nitecore Holster TM11 TM26 TM15
ali pa morda tole:
https://www.aliexpress.com/item/OneTigr...
nisem pa gledal dimenzij, preveri če se odločiš, da nabaviš kaj od tega...
koyotee ::
gregor je izjavil:
No ja, q8 s 450m dosega ni ravno samo flood :)
Rear DVD collector!
JTD power!
144 / 351
