Forum » Mobilne tehnologije » Android - deljenje internetne povezave preko USB (pc -> telefon)
c0dehunter ::
Enako vprašanje sem že postavil na xda-developers, pa bom vseeno vprašal tukaj, pa bom kar prilepil vprašanje:
Odgovori so lahko v slovenščini
Hey,
I would like to use my PC internet connection on Magic (CyanogenMod, 2.1) via USB. I have found a good program to do this (PdaNet) and it works good.
But (), at the same time I would like to disable any other source of internet (3g, grps) on my phone so the only possible connection is through PC internet.
For this I have found another widget (Toggle Data), but after I activate it the PC connection doesn't work too.
Can anyone suggest me how to fix this?
I do not agree with what you have to say,
but I'll defend to the death your right to say it.
| » | nigerijci še vedno harajo po bolhiOddelek: Loža | 10093 (9018) | sarma832 |
| » | Prodajam Renault Megane l 2003 in dobim zanimivo ponudboOddelek: Loža | 8547 (7077) | Go-ahead |
| » | Spet nek afrsiki nateg?Oddelek: Loža | 3818 (2422) | Tic |
| » | BAPCo razkrinkanOddelek: Novice / --Nerazporejeno-- | 2632 (2632) | kuglvinkl |
