Kaj je to fora samsung diskov
kmetek ::
640gb vem da je hin, kaj pa 1tb 103sj?
  • polepsal: KoMar- ()
axee ::
Disk ima nekaj prostih razarviranih sektorjev, da jih omogoči ko se začnejo pojavljati slabi, tako da podatke nadomesti na nov sektor (realocira). Ko teh rezervnih sektorjev zmanjka disk podatke ne "rešuje" na sveže in delujoče sektorje, ampak podatki ostanejo na slabih sektorjih, kar pomeni da niso berljivi, pokvarjeni itd.
Če ima disk samo nekaj realociranih sektorjev in le ti ostanejo v istem številu lahko disk uporabljaš naprej ampak dve opozorili:
1. Pogosto glej da se ti ne zvišujejo (ki se radi), to je najpomembnejša stvar. Lahko pa boš uporabljal še kar nekaj let.
2. Pozanimaj se pri prodajalcu koliko realociranih sektorjev je potrebno da disk vrneš v garancijo. Tako zamenjaš disk in si zaziher.
kmetek ::
Največja fora tega 103SJ je, da je v uporabi komaj 10 dni, kupljen pri nas.
je kakšen dober program za testiranje diskov?
  • spremenil: kmetek ()
kmetek ::
Ravno ga skeniram in ima 0.1% damaged blocks. Garancija?
hudiča čisto nov 8-O
z xs foruma:
"the numbers generally ain't representing 1:1 ratio between error decimal number or decrease rate to number of errors,
each manufacturer has it's own attributes.
what your Raw Error Read Rate means, is that currently the drive is operating great, 99 out of 100 when the threshold is 51 yet the drive probes recall that it had reached 12 before that.
that can mean it is generally that the drive has some hardware issues.
it generally represent that the drive is not functioning well,
the drive has read errors from the surface.
Description
Quote:
Read Error Rate S.M.A.R.T. parameter indicates the rate of hardware read errors that occurred when reading data from a disk surface. Any value differing from zero means there is a problem with the disk surface, read/write heads (including crack on a head, broken head, head contamination, head resonance, bad connection to electronics module, handling damage). The higher parameter's value is, the more the hard disk failure is possible.
Recommendations
This is a critical parameter. Degradation of this parameter may indicate imminent drive failure. Urgent data backup and hardware replacement is recommended.
B8 - End-to-End error
Quote:
This attribute is a part of HP's SMART IV technology and it means that after transferring through the cache RAM data buffer the parity data between the host and the hard drive did not match.
generally, a drive can work with smart failures, it doesn't mean a drive has ended it's life,
just make sure following it ans seeing if the drive keep on loosing it's quality,
don't place any sensitive information (generally) on the drive and you can even try formatting it and rechecking it to see what happens. "
jan01 ::
Poskeniraj s najnovejšim samsungovim programom za testiranje(prejšnje verzije imele napake in prikazale kot pokvarjen disk...
kmetek ::
hehe
še tole :|
PRED ERRORJEM
SEDAJ Z ERRORJI
da je taka razlika jao jao....nekako bom izgubil zaupanje v Samsunge ;((
jan01: tole ? ESTOOL300g_CDROM.zip (Size : 1.76 MB)
  • zavaroval slike: bluefish ()
e-marko ::
Sam sem že izgubil zaupanje v Samsunge. Od treh 640GB mi dela samo še eden in še pri tem mi kaže RAW read error rate in Soft read error rate nezdrave številke. Gre se za modele HD642JJ. Sedaj imam že nekaj mesecev WD Black in je vse ok. Da starega 250GB Hitachija sploh ne omenjam. Star je več kot tri leta in pol ampak prede kot mačka. Sicer je počasen proti tem novejšim ampak zaenkrat še zanesljiv.
...somebody, somewhere...
kmetek ::
Ja ne vem, tegale 640gb bom moral itaq poslat preko RMA v Nemčijo, ali kdo ve točno kam se pošilja?
Tegale 103SJ 1TB bom pa v ponedeljek šel zamenjat na PCHAND 8-O
OMFG?
bluefish ::
kmetek ::
Hvala......Je najbolje, da se formatira vsebina itd?
jan01 ::
In kaj pravi test s samsungovim programom?
Dami ::
5 komadov f1 1tb (šlo že naprej v prodajo sicer) po 2letih še vedno delajo. 10 f2 1.5tb (7 novih, 3 stari) tud delajo brez problema. Hitrost mi ni važna, so pa neslišni (razn rekalibracija vsake tok časa) in ne rabijo hlajenja. Ne kupim druga več ko samsunge.
kmetek ::
jan01: nisem še skeniral ničesar s samsung toolsi :p
bluefish je izjavil:
http://www.samsung.com/global/business/...
Nikakor, da mi rata postopek RMA čez spraviti.
bluefish ::
To pomeni?
kmetek ::
Erm, da nikakor se ne morem registrirat pod RMA registration...bom probal še end user.
dela :)
bluefish ::
Jasno da ne, tisto je za distributerje ipd. Izpolniti moraš tule: http://www.samsunghddvalue.com/WebRMA/W...
kmetek ::
Kewl na Nizozemsko moram sendat :)
cortez ::
Lep pozdrav !
Tudi sam imam probleme z Samsungom G2 zunanjim diskom. Kako poslati RMA, ker mi noče sprejeti kode, ki mi jo da SeaTools.
A ste zraven poslali tudi račun(će ste ga meli) ter vso dodatno opremo in kako ste zaščiti disk (baje da komlicirajo) ?
Jst nisem registriral disk, ko je blo še vse pod samsungom; a mi pol še zmeraj velja 3 letna limited garancija od Samsunga ?
fosil ::
Zakaj pa ne uveljavljaš pri trgovcu/uvozniku?
Tako je!
RejZoR ::
SeaTools je za Seagate diske, ne za Samsung. Al si mislil kaj drugega?
cortez ::
Ne, je že prov Seatools. Sam moreš dat drugo kodo not, da ti sprejme.
Kupu sem v tujini, tako da se mi ne da z njimi ubadat. Če gre vse OK. dobim nov disk v roku 14dni, trgovec je pa sam umesni člen, ki mi bo podalšal rok.
kmetek ::
Seagate ima Samsung RMA sedaj čez...
Strestirate nov HDD pred uporabo?
303172 (2342) MrStein
HDD garancija
366490 (5905) Xserces
HDD - neizbežne napake pri branju (URE)
286106 (5461) MrStein
Opozorilo za disk
398188 (7491) fr4nc
trdi disk ?
326640 (5927) alkoo
