Port 80 windows 7 ???
Dinko ::
Imam prplem.. na računalniku imam naložene:
windows 7
AVavst antivirus
problem imam pa v tem da mi je kar nal lepem nehal delovati možnost surfanja po internetu (port 80)
maile lahko prejejmam...
internetna povezava deluje normalno...
vendar z IE ne morem na nobeno stran
z firefoxom tudi ne morem
probal sem ping www.google.com
deluje uredu (26 ms)
pregledal sem vse firewalle, nastavitve....
kaj naj naredim
Dinko
karlos ::
Probaj izključiti Avasta -> Stop On-Access Protection.
Sai Baba: "Dam vam to, kar hočete, da boste hoteli to, kar vam želim dati."
gorenjc ::
Verjetno je problem s firewall-om. Tole je iz avastove strani:
Q: I have installed avast! and I can no longer browse the Web. How can I solve this?
A:
Check your firewall configuration. For the correct operation the Web Shield process (ashWebSv.exe or aswWebSv.exe) needs a permission to access the Internet (TCP port 80) and a permission to act as a server and accept incoming connections from localhost (the local machine) on TCP port 12080.
problem z računalnikom!!
112813 (2612) mjk
Trojanski konj
214570 (4181) KaiCris
Trojan big problem:(
134488 (4281) mini-moris
zajedalski spyware
Oddelek: Operacijski sistemi
213282 (2949) hunter01
FTP problem
Oddelek: Omrežja in internet
81327 (1247) Struzzo
