Forum » Programska oprema » Program ne dela na 64-bit. Kako da bo deloval?
kirekire ::
Zanima me, ali lahko vsposobim program, ki dela samo na 32-bit OSjih in mi na 64-bit noče delat. Je kakšna možnost, da ga vsposobim?
32bitni programi delajo na 64bitnih windowsih. ne delajo pa 16bitni. nekje drugje imas problem, ker preverjeno delajo. za kaj vec bos rabil napisal tocno o cem se gre.
kirekire ::
daj mtosev ne pametuj, igra je 32 bitna.....
No, pa je kakšna možnost da bi igra delovala na Windows Visti 64bit?
R-S-LoVe ::
Virutal PC
Fear Is The Path To The Dark Side, Fear Leads To Anger,
Anger Leads To Hate, Hate Leads To Suffering!
ocitno ti: copy and paste iz Microsoft.com: Can I run 32-bit programs on a 64-bit computer?
Most programs designed for a computer running a 32-bit version of Windows will work on a computer running 64-bit versions of Windows. Notable exceptions are many antivirus programs, and some hardware drivers.
Drivers designed for 32-bit versions of Windows do not work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows. If you are unsure whether there is a 64-bit driver available for your device, go online to the Windows Vista Compatibility Center.
"In lahko sploh dam npr. XP-32bit na 64-bit comp ? "
tvoj komp ni 64biten ampak podpira 32bit in 64bit.
| » | Updejtan win osem na deset in tezave z ExcelomOddelek: Pomoč in nasveti | 3015 (2805) | Han |
| » | 32 or 64 bit OS?Oddelek: Operacijski sistemi | 8680 (7594) | Hayabusa |
| » | 64 ali 32 bitni systemOddelek: Pomoč in nasveti | 3099 (2440) | jype |
| » | Win XP, Win 8, 32 bit, 64 bitOddelek: Pomoč in nasveti | 3245 (3092) | Xserces |
| » | 32, 64 in 86 bitna različicaOddelek: Operacijski sistemi | 9075 (8215) | OmegaM |
