BSOD
BSOD
shark_nm ::
Lep pozdrav
Komp mi dela že več kot dve letti čisto normalno, nakar se pričnejo BSOD. Ko zaženem Orthos mi po dveh minutah testiranja ramov pokaže
Type: Large, in-place FFTs - stress some RAM Min: 128 Max: 1024 InPlace: Yes Mem: 8 Time: 15
CPU: 1800MHz FSB: 200MHz [200MHz x 9.0 est.]
3.7.2009 17:15
Launching 2 threads...
Using CPU #0
Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 0 minutes 47 seconds - 1 errors, 0 warnings.
Execution halted.
Tukaj je dump file iz cpuz
http://www.yourfilehost.com/media.php?c...
Torej kaj menite da bi bila napaka? Morda premalo voltaže pri ramih? Za kakeršen koli nasvet bi bil hvaležen.
bluefish ::
Poženi še Memtest.
shark_nm ::
memtest je prišel do 680% brez sesutja.
bluefish ::
daj še prilepi sliko bsod-a.
shark_nm ::
a z dmp fajlom si lahko kaj razbereš ven?trenutno ni problemov, ko bo naslednji bsod pa lahko nalimam.
shark_nm ::
Evo tole izpiše po ponovnem zagonu.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1060
Additional information about the problem:
BCCode: 124
BCP1: 00000000
BCP2: 8592F028
BCP3: B2000040
BCP4: 00000800
OS Version: 6_0_6000
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\Mini071509-01.dmp
C:\Users\Shark\AppData\Local\Temp\WER-31184-0.sysdata.xml
C:\Users\Shark\AppData\Local\Temp\WERB49E.tmp.version.txt
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=...
Blue screen - zakaj?
112091 (1791) BlackCaiman
Stalni Bluescreen in pad sistema
81938 (1829) SLO_Matej
Problem s freezanjem, pomoč!
101630 (1453) Sandman4ever
V normalnem zagonu BSOD (moder ekran); v Safe mode vse deluje
102190 (2030) ZaLoMaT
Pomoč! Urgentno - sistem okužen, sesuva se na 10 - 20 min BSOD
82737 (2459) ___
