Forum » Programiranje » LINQ to XML
LINQ to XML
Lualah ::
XML izgleda:
< weather >
< cc >
< lsup >6/25/09 1:30 AM Local Time< /lsup >
< bar >
< d >steady< /d >
< /bar >
< /cc >
Rad pa bi dostopal do d elementa v tem xmlu. Sedaj imam takole ampak do d ja ne morem dostopati, ampak samo do lsup. kako lahko dostopam do d.
Hvala
< weather >
< cc >
< bar >
< d >steady< /d >
< /bar >
< /cc >
public string lsup { get; set; }
public string d{ get; set; }
(from place in xmlDoc.Descendants("cc")
select new WeatherProperty
lsup = place.Element("lsup") != null ? place.Element("lsup").Value : "-1",
Hvala
| » | c# seminarskaOddelek: Programiranje | 3650 (3323) | tuned |
| » | metoda #get, #set ---> c#Oddelek: Programiranje | 1629 (1513) | fokz8 |
| » | C# LinkedListOddelek: Programiranje | 1597 (1448) | PoPon2 |
| » | C# get/setOddelek: Programiranje | 1438 (1374) | japol |
| » | VC# Zapis podatkov na diskOddelek: Programiranje | 2915 (2171) | matej_jack |
