LINQ to XML
LINQ to XML
Lualah ::
XML izgleda:
< weather >
< cc >
< lsup >6/25/09 1:30 AM Local Time< /lsup >
< bar >
< d >steady< /d >
< /bar >
< /cc >
Rad pa bi dostopal do d elementa v tem xmlu. Sedaj imam takole ampak do d ja ne morem dostopati, ampak samo do lsup. kako lahko dostopam do d.
public string lsup { get; set; }
public string d{ get; set; }
(from place in xmlDoc.Descendants("cc")
select new WeatherProperty
lsup = place.Element("lsup") != null ? place.Element("lsup").Value : "-1",
Hvala
Ericssony ::
Poglej si primer tukaj.
c# seminarska
Oddelek: Programiranje
113650 (3323) tuned
metoda #get, #set ---> c#
121629 (1513) fokz8
C# LinkedList
91596 (1447) PoPon2
C# get/set
51438 (1374) japol
VC# Zapis podatkov na disk
422915 (2171) matej_jack
