Izgube električnega dela pri prenosu
sword ::
Ja, treba je spisat še zadnja maturitetna poročila za laboratorijske vaje pri fiziki ... Eno izmed vprašanj, na katera naj bi odgovoril, je tudi, kolikšna je ocena izgube električnega dela pri prenosu v Sloveniji (v odstotkih).
Ve morda kdo iz glave? Sicer sem nameraval klicati v torek na Elektro Ljubljana, ker pri iskanju na internetu nisem mel veliko sreče.
Rippy ::
Hm nekaj sem ti našel na wikipediji glede tega
Transmitting electricity at high voltage reduces the fraction of energy lost to Joule heating. For a given amount of power, a higher voltage reduces the current and thus the resistive losses in the conductor. For example, raising the voltage by a factor of 10 reduces the current by a corresponding factor of 10 and therefore the I^2R\,\! losses by a factor of 100, provided the same sized conductors are used in both cases. Even if the conductor size is reduced x10 to match the lower current the I^2R\,\! losses are still reduced x10. Long distance transmission is typically done with overhead lines at voltages of 115 to 1,200 kV. At extremely high voltages, more than 2,000 kV between conductor and ground, corona discharge losses are so large that they can offset the lower resistance loss in the line conductors.
Transmission and distribution losses in the USA were estimated at 7.2% in 1995 [2], and in the UK at 7.4% in 1998. [3]
As of 1980, the longest cost-effective distance for electricity was 4,000 miles (7,000 km), although all present transmission lines are considerably shorter.
Electric power transmission @ Wikipedia
Torej okoli 7% :D ?
  • spremenil: Rippy ()
sword ::
Morda. Pod 10% naj bi bilo gotov, ne vem pa, kakšne so razlike med državami. Če ne bo drugega podatka, bom uporabu tega :)
Pyr0Beast ::
Zanimivo je tudi furanje DC napetosti po daljnovodih ki se celo splača (AC-DC-AC ali pa DC-AC) :)
Rippy ::
Tukaj je sicer en plus in minus...smo majhna država ampak imamo tudi rahlo stare transformatorje :)
T0RN4D0 ::
Eh kompliciraš z _oceno_ izgub. Če te kot dijaka vprašajo za oceno nečesa pa res ne moreš narobe odgovorit, sploh pri enih vajah ki jih bo profesor prelistal pogledal nahitro če zadeve štimajo in od oka prbil eno oceno. Lahko napišeš 10% pa bo dobro.
(")_(") world domination.
sword ::
Hvala za pomoč. Na elektru nisem preverjal, sem se odločil napisati 7-9% :)
A. Smith ::
Nizkonapetostni kabli in prostozračni vodi povezujejo TP s priključnimi mesti odjemalcev, kjer so vgrajeni števci. Razlika med med proizvedeno oz uvoženo elektriko in seštevkom s števci registriranega odjema, so izgube prenosa in transformacije, ki v SLO znašajo okrog 7 %. Izgube segrevajo vodnike in transformatorje ter predstavljajo odpadno toploto.
Instalacijski vodniki povezujejo električni razdelilnik oz števec z vtičnicami in drugimi trošili. Tudi v hišnih instalacijah nastajajo izgube v vodnikih med števcem in trošili, ki znašajo 1,0-1,5 %, s števcem registriranega odjema elektrike.
klik
"Be professional, be polite,
- General James Mattis
Prekinjena nula v hišnem razdelilcu (strani: 1 2 )
6820138 (18116) starfotr
Solarne nevihte (strani: 1 2 3 )
11227355 (21832) Marat
Electric fusion (inertial electrostatic confinement fusion - IEC) (strani: 1 2 )
8210580 (7022) A. Smith
Jakost, ki te ubije
3112254 (8889) Pyr0Beast
