Download iz MYSQL baze s PHP-jem
roky99 ::
Zdravo!
Imam sledeč problem...
V bazo uploadam fajl in nikakor ne znam poštimat PHP skipte da bi mi jo downloadalo. Izpiše mi polno nekih znakov.
Prosim za pomoč, če sem pa še kej pozabu mi pa povejte :)
MYSQL baza
`tbl_upload` (
  `id` int(11) NOT NULL auto_increment,
  `name` varchar(30) collate utf8_slovenian_ci NOT NULL,
  `type` varchar(30) collate utf8_slovenian_ci NOT NULL,
  `size` int(11) NOT NULL,
  `content` mediumblob NOT NULL,
  PRIMARY KEY  (`id`)
) ENGINE=MyISAM  DEFAULT CHARSET=utf8 COLLATE=utf8_slovenian_ci
Skripta za download
<?php
include ("login.php");
$sql = "SELECT id, name FROM tbl_upload";
$res = mysql_query($sql);
if(mysql_num_rows($res) == 0)
echo "V bazi ni datotek. <br />";
else
while(list($id, $name) = mysql_fetch_array($res))
<a href="down.php?id=<?php echo $id;?>"><?php echo $name;?></a><br />
<?php
if(isset($_GET['id']))
    $id    = $_GET['id'];
    $sql = "SELECT name, type, size, content FROM tbl_upload WHERE id = '$id'";
    list($name, $type, $size, $content) = mysql_fetch_array($res);
    header("Content-length: $size");
    header("Content-type: $type");
    header("Content-Disposition: attachment; filename=$name");
    echo $content;
    mysql_close($link);
    exit;
don't drink and drive, just smoke and fly! ;)
  • spremenil: roky99 ()
[php] encoding niza
Oddelek: Izdelava spletišč
174540 (2455) BivšiUser2
Šumniki v php-ju
215165 (3668) JoSmo
MySql Vprasanje - problem dupliciranih kljucev
131907 (1729) KernelPanic
FULLTEXT indeksi - problemi pri osnovnem primeru
Oddelek: Programiranje
61229 (1150) barelyLegal
kako spreminiti vse php fajle in celo bazo v utf-8
161597 (1377) Senzacionale
