Forum » Programiranje » Pomoč pri programu!
Pomoč pri programu!
Mitja Bonča ::
Delam en program za izpis študentov in nato vnos ocen (izpis iz baze in vnos ocen v bazo)
Pa me zanima, kako se napiše poizvedba, ki točno izpiše iz katerega predmeta so se študenti prijavili:
string ukaz = "SELECT Prijava.IdPrijava, Prijava.Ime FROM Prijava, Predmeti WHERE Predmeti.IDPredmeta='INF' "; - je to prav?
tukaj je cela koda programa Form 1:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Data.SqlClient;
namespace informatikaNet01
public partial class Form1 : Form
SqlConnection povezava;
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
string p = @"Data Source=.\SQLEXPRESS;AttachDbFilename=D:\Informatika\PRO2\Seminarska2\informatikaNET.mdf;Integrated Security=True;Connect Timeout=30;User Instance=True";
povezava = new SqlConnection(p);
private void buttonInf_CheckedChanged(object sender, EventArgs e)
txtTeorija.Visible = true;
txtPraksa.Visible = true;
txtBonus.Visible = false;
lblBonus.Visible = false;
lblBonus1.Visible = false;
txtVnesiŠtudenta.Visible = false;
buttonVnesi.Visible = false;
groupBox3.Text = "Vnesi ocene za Informatiko";
groupBox2.Text = "Prijave za Informatiko";
lblTeorija1.Text = "0 in 40";
lblPraksa1.Text = "0 in 60";
Izprazni();
private void buttonPro1_CheckedChanged(object sender, EventArgs e)
txtBonus.Visible = true;
lblBonus.Visible = true;
lblBonus1.Visible = true;
groupBox3.Text = "Vnesi ocene za Programiranje 1";
groupBox2.Text = "Prijave za Programiranje 1";
lblTeorija1.Text = "0 in 50";
lblPraksa1.Text = "0 in 50";
lblBonus1.Text = "0 in 20";
Izprazni();
private void buttonPro2_CheckedChanged(object sender, EventArgs e)
groupBox3.Text = "Vnesi ocene za Programiranje 2";
groupBox2.Text = "Prijave za Programiranje 2";
lblBonus1.Text = "0 in 25";
Izprazni();
private void buttonMul_CheckedChanged(object sender, EventArgs e)
groupBox3.Text = "Vnesi ocene za Multimediji";
groupBox2.Text = "Prijave za Multimediji";
Izprazni();
private void Izprazni()
txtTeorija.Clear();
txtPraksa.Clear();
txtBonus.Clear();
private void buttonPonovi_Click(object sender, EventArgs e)
Izprazni();
private void buttonPrijavljeni_Click(object sender, EventArgs e)
if (buttonInf.Checked)
string ukaz = "SELECT Prijava.IdPrijava, Prijava.Ime FROM Prijava, Predmeti WHERE Predmeti.IDPredmeta='INF'";
SqlCommand u = new SqlCommand();
u.Connection = povezava;
u.CommandText = ukaz;
u.CommandType = CommandType.Text;
povezava.Open(); //--------------------------------------------> Tukaj mi javi napako: Object reference not set to an instance of an object. Imam bazo in je konektana
SqlDataReader bralec = u.ExecuteReader(); Kaj je narobe?
lblPrijavljeni.Text = "Prijavljeni študenti\r\n";
while (bralec.Read())
lblPrijavljeni.Text += bralec[0] + " " + bralec[1] + "\r\n";
bralec.Close();
povezava.Close();
using System;
using System.Data;
using System.Linq;
using System.Text;
public Form1()
Izprazni();
Izprazni();
Izprazni();
Izprazni();
txtTeorija.Clear();
txtPraksa.Clear();
txtBonus.Clear();
Izprazni();
bralec.Close();
povezava.Close();
- spremenil: Mitja Bonča ()
dejc2 ::
Najprej imaš napako v SQL-u tabeli Prijava, Predmeti nimaš povezan: npr. "SELECT Prijava.IdPrijava, Prijava.Ime FROM Prijava, Predmeti WHERE Predmeti.IDPredmeta='INF' and Prijava.IDPREDMET = Predmeti.IDPREDMET "
http://www.potovalka.si
Mitja Bonča ::
Ja, ok, ampak meni javi napako pri povezava.Open(); nekaj je z povezavo z bazo narobe. Pa sem use naredil kot more biti - vsaj mislim.
Mitja Bonča ::
Ne, imaš narobe, jaz nimam tujega kluča IdPredmeta v mapi Prijava. Zatorej zadnje izenačenje ključev je odveč!
Mitja Bonča ::
btw.. kdo ve to: imam textBox, kamor se vnaša točke (samo številke) in da se jih omeji od 0 do 50! Kako se to izvede?
dejc2 ::
Že želiš, da se uporabijo le številke uporabi regular expression, kot npr tole http://www.c-sharpcorner.com/UploadFile... , če imaš web aplikcijo lahko preverjaš od-do število z javascriptom.
Mitja Bonča ::
Kdo mi zna pomagati, tukaj vidite da imam eno okensko aplikaicjo, ki pobere Študente, ki so se prijavili na izpit ( imena v Prijave za informatiko - v tem primeru). Potem sem naredu kodo za izračun ocene, in končna ocena je 7. Sedaj pa morem to oceno vnesti v bazo, in sicer za določenega študenta.
Tako sem si zamislil: V okence "Vnesi ime študenta" se vnese Ime, ki je že v bazi "Prijava" in ime skupaj z oceno (7 v tem primeru) vnese v bazo "Ocene" - z novim Id-jem ( enim večjim od zadnjega) in oceno.
Mi lahko to kdo pomaga?
GeeDee ::
Znaš uporabljati Debugger? Če ja, potem preveri, če v vrstici "povezava.Open();" povezava ni null.
V vsakem primeru poskusi spodnjo zadevo:
Vrstici ...:
... prestaviti pred vrstico povezava.Open();
Če ti še vedno vrže napako imaš po vsej verjetnosti napačen connection string. Naredi povezavo na bazo v Server Explorerju, tam pa potem lahko pogledaš kakšen ConnectionString VS uporablja.
LpG
Vrstici ...:
LpG
- spremenil: GeeDee ()
Mitja Bonča ::
Vse mi dela... sej z debuggerjem sem odkril napako.
Sedaj morem samo še zadnjo kodo dodati... kar piše v prejšnjem postu! Bi prosil za majceno pomoč!
| » | [c#] kako skriti vsebinoOddelek: Programiranje | 3821 (3005) | def0r |
| » | kako narediti program ki bere drugi programOddelek: Programiranje | 7186 (5499) | imagodei |
| » | c# datagridview in comboxOddelek: Programiranje | 1633 (1521) | OmegaM |
| » | C# - xml import v bazoOddelek: Programiranje | 1952 (1770) | nuclear |
| » | C# PomočOddelek: Programiranje | 1827 (1652) | jizzer |
