dual boot xp/ubuntu
dual boot xp/ubuntu
lebang1 ::
Prvo sem si namestil windows xp, in potem na drugo particijo še linux kubuntu...
Pa ko zaženem računalnik lahko izbiram kaj naj zaženem, pa je tam pod default nastavljen linux...
Kako bi nastavil da mi gre samo kar v winowse?
misek ::
Zaženi kubuntu in nato spremeni privzet sistem v datoteki /boot/grub/menu.lst. Sedaj je nastavljen Linux. Poglej pod default vrstico. Če ima vrednost 0 se zažene prvi sistem, 1, drugi, itd.
  • spremenil: misek ()
lebang1 ::
Ja, samo imam en problem, da ko nastavim na 1 potem dokumenta ne morem shranit...
Kaj naj naredim?
Sedaj imam tako:
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 10
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
#hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=9e1b4f70-0fcf-48a3-9a8f-03e424d71dfd ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=9e1b4f70-0fcf-48a3-9a8f-03e424d71dfd
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Ubuntu 8.10, kernel 2.6.27-7-generic
uuid 9e1b4f70-0fcf-48a3-9a8f-03e424d71dfd
kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=9e1b4f70-0fcf-48a3-9a8f-03e424d71dfd ro quiet splash
initrd /boot/initrd.img-2.6.27-7-generic
quiet
title Ubuntu 8.10, kernel 2.6.27-7-generic (recovery mode)
kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=9e1b4f70-0fcf-48a3-9a8f-03e424d71dfd ro single
title Ubuntu 8.10, memtest86+
kernel /boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda1
title Microsoft Windows XP Professional
root (hd0,0)
savedefault
makeactive
chainloader +1
(Naj spremenim še kaj razen tisto 0 pri default)?
misek ::
Mislim, da moraš uporabiti vrednost 4, potem se bodo zagnali Windowsi. Pa pri editiranju te datoteke moraš biti root (sudo vi /boot/grub/menu.lst).
lebang1 ::
Ali lahko malo bol pojasniš kako "moraš biti root (sudo vi /boot/grub/menu.lst). "
Ker ne vem dosti o linuxih....
Ko si linux inštaliral si moral vpisati geslo za uporabnika root. Je tako ?
Torej:
1. pojdi v konzolo ali terminal
2. napiši su
3. vpiši geslo
4. odpri datoteko (kubuntuja nikoli nisem uporabljal, ampak mislim, da je prava datoteka grub.conf v /boot/grub/grub.conf, menu.lst naj ne bi direktno spreminjal).
5. spremeni kar imaš spremeniti (default 4)
6. shrani
lebang1 ::
ok...
1. grem v terminal
2. napišem su
3 napišem geslo... ki se mi ne izpisuje na zaslonu in mi potem napiše authentication failure
4 grub.conf ne obstaja , menu.lst še vedno ne morem spremenit...
(ko kliknem shrani mi napiše da ustvarjanje varnostne kopije spodletelo in če želim nadaljevati... kliknem da... pa se mi napiše da ni bil shranjen ker ni bilo možno pisati.)
need help...
Su pomeni super user. S tem pridobiš pravice za spreminjanje sistemsih datotek, ki jih kot navadni uporabnik ne moreš.
Če ne veš pravega gesla, potem ne moreš spreminjati datoteke.
lebang1 ::
Pa vem geslo...
razen če napišem su mojeime
in potem gelo ... se ne napiše da je napačno....
samo še vedno ne morem spremenit nastavitve na 4....
(lahko da delam kaj narobe...?)
No Can Do ::
poskusi s:
sudo passwd - nato vpišeš svoje geslo, nakar te vpraša za novo UNIX (root) geslo, dvakrat vpišeš in je to to
potem pa vpišeš su in unix geslo pa si root in spremeniš datoteko
This user may use sarcasm and cynicism
in a way you are not accustomed to.
You might suffer severe mental damage.
No, če lahko s sudo spremeni geslo za roota, potem pa bi lahko tudi shranil tisti file.....
lebang1 ::
pizda.... tolk se pa že dolgo nisem je*bal z kakšno stvarjo....
Sm pregledu use forume pa povsod piše spremeni na 4 in shrani.... pa pička jim če ne morem shranit....
no potem sem le našel eno rešitev....
tako da noter napišeš: sudo aptitude install startupmanager
In potem: gksudo startupmanager
pa maš tam potem kot v windowsih in spremeniš da se ti prvo zaženejo windowsi....
Hvala vsem za pomoč!
CoolMike ::
Morda bi kateremu od vas pomagal ta članek, kako si naredimo boot menu, če imate kakšen komentar ga le post-aj
http://mihagapiha.net/~wordpress/?p=19
misek ::
lebang1, saj počasi bo. Se boš že sproti naučil, kako urediti zadeve pod Linuxom. Nekje je pač treba začeti.
btw: To bi lahko bil en primer, kako (ne)enostavno je začetniku pri uporabi Linuxa. Če ti nekdo drug vze administrira, namesti aplikacije, itd., potem navaden uporabnik samo uporablja to aplikacijo. Če pa mora delati vse sam, potem se zgodba začne tako kot tukaj. Moje skromno mnenje.
Kako v Ubuntuju vklopiti nov kernel?
Oddelek: Operacijski sistemi
171514 (1388) Mitja358
Kako instalirati Linux in xp?
62719 (2640) Blinder
GRUB
122184 (1923) ank
gnu grub
81601 (1554) Loaded
Mandrake 8.0 help
161801 (1621) simon
