AMD Phenom II Uporabne informacije, izkušnje, testi, navijanje, plošče .....
25 / 102
PrimozR ::
Mene pa zanima nekaj glede TDP-ja.
Če naprimer imamo procesor AMD Phenom II X4 920 in 940BE. Oba imata 125W TDP. Se pravi da procesorja isto potrošita energije (v tem primeru 125w) ali pa imajo porabo razvrščeno po skupinah, npr. 30-45w, 45-65w, 65-90w, 90-125w. In če procesor 940BE porabi okoli 120w spada pod 90-125w skupino. 920 pa potem porabi npr. 105w in še spada pod 125W TDP?
Ali pa 920 in 940BE porabita isto?
Prodajajo se proci s parimi TDPji ja, recimo pri AMDju 140W (tistih par 9950k), 125 W, 65 W, 45 W, itd. Kaj je med 125 in 65 ne vem, ampak skoraj ziher je kaj. Torej če porabi več kot 45 W, ima TDP 64 W. Če porabi manj, ima TDP 45 W. Dejanska poraba je le okvirno povezana s TDPjem, pa še to pod full load.
SIcer pa 920 zaradi nižje frekvence porabi (malo) manj.
Mitja358 ::
Aha, hvala
M-XXXX ::
Wikipedia:
The Thermal Design Power (TDP) (sometimes called Thermal Design Point) represents the maximum amount of power the cooling system in a computer is required to dissipate. For example, a laptop's CPU cooling system may be designed for a 20 W TDP, which means that it can dissipate (either via an active cooling method such as a fan, a passive cooling method via natural convection, via heat radiation or all three modes of heat transfer) 20 watts of heat without exceeding the maximum junction temperature for the chip. The TDP is typically not the most power the chip could ever draw (such as by a power virus), but rather the maximum power that it would draw when running real applications. This ensures the computer will be able to handle essentially all applications without exceeding its thermal envelope, or requiring a cooling system for the maximum theoretical power, which would cost more and achieve no real benefit.
Since the definition of "real applications" and the safety margins vary between manufacturers, TDP values between different manufacturers cannot be accurately compared. While a processor with a TDP of 100 W will almost certainly use more power at full load than a processor with a 10 W TDP, it may or may not use more power than a processor from a different manufacturer that has a 90 W TDP. Additionally, TDPs are often specified for families of processors, with the low-end models using significantly less power than those at the high end of the family.
Mitja358 ::
Wikipedia:
Hvala, sem skužil.
M-XXXX ti si moderator pri OC-LABu?
Mitja358 ::
Ker či lahko pripravil test AMD Phenom II X3 720 BE. Da bi malce navil (da bi videli če gre res skoraj na stock voltaži navit stabilno za 800MHz+), bencmarko.....
Brane2 ::
Misliš, če delata vsak na svoji nazivni frekvenci ? Takrat bo verjetno 920 porabil manj. 940ka je preprosto rečeno "bolje zapečen" čip, ki je sposoben dela na malo višji frekvenci. Ker je poraba odvisna od frekvence, bo takrat porabil praviloma nekaj več.
Če pa bi spustil frekvenco 940BE na nivo 920ke, bi porabila približno toliko kot 920ka, vendar bi ji zato lahko znižal napetost dela in mogoče dosegel nižjo porabo.
Stvari tu IMHO niso 100% definirane in verjetno odvisne tudi od serije in procesa proizvodnje a mislim, da zgornje drži v večini primerov.
Mitja358 ::
aha.
M-XXXX ::
Nope, teste piše,...
Jaz bi že, sam robo dobit je večji problem:D
Mitja358 ::
aja, no sem mislil da si še moderator.
Ja no drug teden bo že za dobavit. Upam da ga lahko stestiraš, ker vidim na OC-labu2 da tudi tebe mika navijanje le-tag :D
ncc2000 ::
Kolikor jaz razumem tehnične podatke o PH2 920 in 940 imata skoraj identično porabo (IxU, ne tpd), ne glede na stock razliko v freq.
Na prvo žogo se mi sicer zdi nelogično, ker gre za identično osnovo, freq. pa s porabo ima vezo, ampak jaz tako to berem. Narobe?
cekr ::
Zanima me, kako je s spremenljivo frekvenco po stopnjah. Je možno, da bi se ob prostem teku frekvenca avtomatsko zmanjšala tudi pod 800MHz?
Mitja358 ::
Pri Athlonih je minimum 1GHz. Pol pa maš 1.8, 2.0, 2.2, 2.3, 2.4, 2.5....
PrimozR ::
Z nižjo napetostjo bi porabo znižal precej, saj se poraba spreminja linearno v odvisnosti od frekvence ter kvadratno v odvisnosti od napetosti.
Pa Mitja, obstaja gumb popravi ;)
Mitja358 ::
Kje sem se zmotil?
PrimozR ::
Double in triple postanje.
cekr ::
Mogoče se nisem prav izrazil. Mislil sem na funkcijo varčevanja, ki jo ima Phenom in prilagaja frakvenco glede na potrebo. Vsaj kar sem spremljal je frekvanca 800Mhz najnižja. Včasih bi pa lahko vse delovalo še s precej manjšo frekvenco. Vsaj v prostem teku, ko samo kaj gledam.
DJ MartiNi ::
Funtech ima na ceniku tri AM2+/AM3 CPUje:
-AMD Phenom II X3 710 AM3 135,00
-AMD Phenom II X3 720 AM3 158,00
-AMD Phenom II X4 810 AM3 191,00
Ryzen 7 7800X3D/MSI B850 Edge Ti Wifi/2x16GB G.Skill Ripjaws S5 6000/RX 7900 XT
Ryzen 7 5700X/ASRock B550 PG Velocita/2x16GB G.Skill Ripjaws V 3600/RX 5700 XT
AMD FX-8350/ASRock 970 Extreme4/2x4GB Kingston HyperX Beast 2400/R9 270X
tilinho20 ::
Na ceniku, ja. :D
PaX_MaN ::
Je že kaka tvrdka izdala plato z osmimi SATA priključki? Ali pa ima kakšno tako ploščo napovedano v bližnji prihodnosti?
kikibeck ::
Ja sej je že AM3 od gigabyta z FX790 chipsetom
PaX_MaN ::
Uau, ena cela!
Druga jih ima pa celo 10 >:D
Valvoline ::
Z vklopljenim CNQ se odzivnost sistema izredno poslabša. Pr intelovim speedstep je nekaj podobno. Vsak naj ga sproba vklopit in izklopit pa bo sam vidu. Katastrofa.
Odzivnost pri cem?
Pri meni ni nikakrsne razlike, ne na AMD ne na Intelu.
nove plate z podporo ddr3: Gigabyte GA-MA790FXT-UD5P AM3 in asus_m4a79t_deluxe-am3-ddr3 podpirata phenome 2 z am2+ podnožjem?? al je treba počakat na Ph2-am3 podnožje?
očitno bo pametno z novim računalnikom počakat na izzid še novega čipka + dodat 2 meseca.
rgv45vg4t335 ::
Če imata plati DDR3 RAM in če imajo Ph2 920 in 940 samo DDR2 krmilnik ?
O bog, vse se da povedati v dveh stavkih in vseeno je to vir neskončne zmede. Ajde, gremo še stotič: AM3 CPU-ji bodo delali tudi v AM2+ platah ker imajo dvojni (DDR2 in DDR3) kontroler. AM2+ CPU-ji ne delajo v AM3 DDR3 platah, ker imajo ti CPU-ji samo DDR2 kontroler.
MSI K9A2 Platinum@260MHz, Athlon X2 4850e@3GHz, 4GB RAM@1000MHz
Radeon HD 4850
TOP ::
Sepravi Phenom2 940BE in 920 ne bosta delal na AM3 platah sem prav razumel.
rgv45vg4t335 ::
Radeon HD 4850
dzinks63 ::
Prav si razumel, na am3 ploščah bodo delali le prihajajoči am3 procesorji. Ta sedanja X4 (920-940BE) katera sta sedaj v prodaji, ne bosta delala z novimi am3 platami in DDR3 ramom. Tako da če misliš nabavit platformo z DDR3 rami, počakaj na taprave am3 procesorje, ker tale sedanja dva (x4 920, 940BE) sta le za stare plošče z ddr2 ramom.
rgv45vg4t335 ::
Če IT-ju čakaš na 'ta pravo' stvar se lahko to čakanje zavleče v nedogled. Vedno je za vogalom nekaj bistveno boljšega, smo še teden, samo še mesec ...
Komur se zdi nujno, obvezno in 100% neizogibno imeti DDR3 naj se raje vpraša če bo napram DDR2 sploh kaj profitiral. Do zdaj so neki preliminarni testi kazali, da pri Ph2 praktično sploh ni razlike oz. se razlika opazi šele če vse skupaj močno naviješ. Če razliko v ceni DDR2/DDR3 in razliko v ceni AM2+/AM3 plošče investiraš v boljšo grafično kartico, najbrž dobiš precej zmogljivejšo mašino. Oz. če obrnem drugače; mi lahko kdo razloži, zakaj je zanj Ph2 z DDR2 RAM-om prepočasen?
No, baje bo 910 zunaj v ponedeljek in bomo lahko takoj brali mali bolj resne AM3 benchmarke.
Radeon HD 4850
razlika med ddr2 in ddr3 ni velika, ~40€, na splošno in zelo grobo rečeno. + koliko bo še podražitev glede am3 procesorjev. meni osebno se to ne zdi prevelika razlika, da ne bi šel (prešel) na ddr3.
koliko bomo pa profitirali na moči pa bomo vidli drug teden.8-)
TOP ::
Ne nemislim jaz kupovat AMD to za prijatelja sprašujem.Če maš sedaj AM2+ plato potle se splača kupir Phenom2 drugače ne,ker je isto sranje kot da kupiš Intel 775
PrimozR ::
Ma splačalo bi se kupiti AM3 plato, če bi imela SSR2 in DDR3 reže. Je res, mashup plate so bedne, a te palte poznam z Intel paltform, kjer so na taki plati delovali vsi procesorji od prvih (LGA 775) Pentiumov pa vse do zadnjih Core 2 Quadov. Tukaj pa lahko kupiš to plato, DDR2 RAM (oz. ga uporabiš od prej) in novega AM3 Phenoma, ko bo pa prišel ven hitrejši model, kupiš tega, kupiš še (takrat mogoče cenejši) DDR3 RAM, ker DDR2 kontrolerja ne bo več. Torej, ali se skeširaš zdaj in si praktično popolnoma future proof, ali pa kupiš AM3 proc in si future proof samo s procem, komponento, ki je itak najverejtneje, da jo boš menjal (ob RAMu).
Brane2 ::
Eh, ene nikoli ne bo izučilo. "Future proof" ne obstaja. Vsaj od začetkov Socket A naprej ne.
Odkar sem žvajznil prve Opterone 240, ni nobena plata pri meni videla več ko en CPU.
Ko je prišel čas za menjavo, sem vedno menjal CPU + plata, dostikrat tudi RAM.
Kaj ti pomaga to, da ostajaš na DDR-2 recimo, če si pred parimi leti nafilal plato s takrat najcenejšimi 256MB palčkami, sedaj pa so recimo 1GB smešno poceni ? Ni ravno logično...
PrimozR ::
Če imaš že zdaj 4 ali celo 8 GB RAMa in ti to zadostuje tudi čez pol leta, ne bi pa se branil hitrejšega CPUja? Sicer v tem primeru to odpade zaradi manjka DDR2 kontrolerja, ampak ja...
Brane2 ::
In tebi je pol leta "future proof" ? :))
x45 ::
Test Denaba 720 BE AM3 cpu ja z DDR2 in DDR3 :
http://www.techpowerup.com/84225/Phenom...
Scori so že malo boljši z DDR3, samo glede na razliko v ceni bi še kr lepo DDR2 vzel.
Cena cpu ja pa je zelo ugodna.
  • spremenilo: x45 ()
x45 ::
Cene plošč AM3 pa so naravnost ugodne :), nisem pričakoval tako ugodnih cen takoj na začetku in to vedno bolj kvaliteten gigabyte:
http://www.fudzilla.com/index.php?optio...
http://geizhals.at/eu/?cat=mbam3
focus-ford ::
Pa daj ne omenjaj tale šrot od Gigabyta,ki ni naredu še nikoli kvalitetne plate.Še MSI mi je zdržal dlje od Gigabyta da od DFI sploh ne govorim,ki še sedaj lepo dela.Drugač pa Asus so dobre plate,čeprav sem dobil informacjo da je Asus odkupil Gigabyt,ne vem pa če res.
Vanadium ::
Gigabyte - jetra pol USB je pocrkal na bratovi plati
x45 ::
Čudno, mel dve do zdaj prvo 754 pin prodal izpravno po letu in pol. Druga dela bp navita že pol leta...
Verjetno kake stare plate ?
TOP ::
Mel sem zadbjo izvedbo za 775 P45-UD3P po 14 dneh je crknila in s sabo vzela še napajalnik,sedaj je že 14 dni na servisu,primeni nikoli več to je šrot od plat,z Asusom še nikoli težav pa sem jih veliko dal skoz za 775.
x45 ::
aja intel plata... :D, kolko si mel navito?
po enih testih se določeni deli pri GA plati dost manj grejejo kot pr Asusu, bil test za P35 plošče ne dolgo nazaj.
lol. torej če ne kupiš 1600 MHz ddr3 ramov lahko pričakuješ performance drop napram 1066 ddr2^^:))
bomo še počakali na par testov...
pirlo ::
Ne vem kaj imate toliko proti gigabytu. Sem mel že 2 plati, ena je bila za p4 druga pa sedaj 780g pa dela super. Zaenkrat :D
PrimozR ::
ja, Intel plata, kamor vsi večji proizvajalci vlagajo precej več denarja za razvoj. In je zato crkovanje še toliko bolj čudno.
in ne, Asus ni kupil GBja, skupaj sta ustanovila še eno firmo a sta se kmalu skregala in razšla.
x45 ::
men tudi .
x45 ::
malo slabo si pogledal v tem drugem testu je ddr3 že hitrewjši samo se ne splača glede na ceno....
Kr lepo 940 BE in DDR2 top ram to je best buy.
je hitrejši, ampak ni bil testiran samo 1600MHz? me zanima kaj bo če dajo not ddr3 1066MH (ki pa je še vedno dražji kot ddr2 1066)...
vseeno pričakujem slabše rezultate kot na ddr2 1066MHz.
dzinks63 ::
Kdor bo kupoval Phenome II X4 925, 945,... se naj potrudi in nabavi novo ploščo am3 in dobre ddr3 rame poleg, bo zadevo vsaj pošteno izkoristil in imel možnosti za še nove prihajajoče nadgradnje. Za manj zmogljive X3 in X2 pa recimo da so stare plošče z ddr2 še vedno dobre.
25 / 102
