Forum » Kaj kupiti » SSD za sistemski disk
MooM ::
Kaj mi zna kdo pomagat. 2 meseca že imam crucial m4 128. Kostantno cca enkrat na teden dobivam bsode. Vsebina je sledeča? Mogoče zna kdo to dešifrirat in nakazat rešitev? Hvala.
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\Nova mapa\Nova mapa\Nova mapa\052212-21372-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.17803.amd64fre.win7sp1_gdr.120330-1504 Machine Name: Kernel base = 0xfffff800`02c08000 PsLoadedModuleList = 0xfffff800`02e4c670 Debug session time: Tue May 22 12:46:25.703 2012 (UTC + 2:00) System Uptime: 1 days 16:03:53.746 Loading Kernel Symbols ............................................................... ................................................................ ............................................... Loading User Symbols Loading unloaded module list .......................... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 7A, {fffff6fc40054e90, ffffffffc00000c0, 6e659be0, fffff8800a9d2000} *** WARNING: Unable to verify timestamp for win32k.sys *** ERROR: Module load completed but symbols could not be loaded for win32k.sys Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+3717a ) Followup: MachineOwner ---------
MooM ::
verjetno je tu več informacij:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\Jani\Desktop\Nova mapa\Nova mapa\Nova mapa\052212-21372-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.17803.amd64fre.win7sp1_gdr.120330-1504 Machine Name: Kernel base = 0xfffff800`02c08000 PsLoadedModuleList = 0xfffff800`02e4c670 Debug session time: Tue May 22 12:46:25.703 2012 (UTC + 2:00) System Uptime: 1 days 16:03:53.746 Loading Kernel Symbols ............................................................... ................................................................ ............................................... Loading User Symbols Loading unloaded module list .......................... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 7A, {fffff6fc40054e90, ffffffffc00000c0, 6e659be0, fffff8800a9d2000} *** WARNING: Unable to verify timestamp for win32k.sys *** ERROR: Module load completed but symbols could not be loaded for win32k.sys Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+3717a ) Followup: MachineOwner --------- 0: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* KERNEL_DATA_INPAGE_ERROR (7a) The requested page of kernel data could not be read in. Typically caused by a bad block in the paging file or disk controller error. Also see KERNEL_STACK_INPAGE_ERROR. If the error status is 0xC000000E, 0xC000009C, 0xC000009D or 0xC0000185, it means the disk subsystem has experienced a failure. If the error status is 0xC000009A, then it means the request failed because a filesystem failed to make forward progress. Arguments: Arg1: fffff6fc40054e90, lock type that was held (value 1,2,3, or PTE address) Arg2: ffffffffc00000c0, error status (normally i/o status code) Arg3: 000000006e659be0, current process (virtual address for lock type 3, or PTE) Arg4: fffff8800a9d2000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address) Debugging Details: ------------------ ERROR_CODE: (NTSTATUS) 0xc00000c0 - This device does not exist. BUGCHECK_STR: 0x7a_c00000c0 CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT PROCESS_NAME: System CURRENT_IRQL: 0 LAST_CONTROL_TRANSFER: from fffff80002cf4582 to fffff80002c871c0 STACK_TEXT: fffff880`03140848 fffff800`02cf4582 : 00000000`0000007a fffff6fc`40054e90 ffffffff`c00000c0 00000000`6e659be0 : nt!KeBugCheckEx fffff880`03140850 fffff800`02cae01f : fffffa80`047453b0 fffff880`031409c0 fffff800`02eb9540 fffffa80`047453b0 : nt! ?? ::FNODOBFM::`string'+0x3717a fffff880`03140930 fffff800`02c947a9 : 00000000`00000000 00000000`00000001 ffffffff`ffffffff fffffa80`03c01c50 : nt!MiIssueHardFault+0x28b fffff880`03140a00 fffff800`02cbade0 : 00000000`00000001 fffff880`0a9d2000 00000000`00000000 fffff6fc`40054e68 : nt!MmAccessFault+0x1399 fffff880`03140b60 fffff800`02cbafd0 : fffffa80`05f1b060 00000000`00000001 fffffa80`00000000 fffff800`02cb7e0b : nt!MiInPageSingleKernelStack+0x134 fffff880`03140c70 fffff800`02cbaf5f : 00000000`00000000 00000000`00000001 fffffa80`03cd1ae0 00000000`00000080 : nt!MmInPageKernelStack+0x40 fffff880`03140cd0 fffff800`02cbaca4 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`03cd1a00 : nt!KiInSwapKernelStacks+0x1f fffff880`03140d00 fffff800`02f1de6a : b6559f75`f45df775 ba55a61d`9f7cf957 bba43f5c`271d51dd ea57a7fd`ea165541 : nt!KeSwapProcessOrStack+0x84 fffff880`03140d40 fffff800`02c77f06 : fffff800`02df9e80 fffffa80`03cf5b50 fffff800`02e07cc0 ee7df777`b253d469 : nt!PspSystemThreadStartup+0x5a fffff880`03140d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16 STACK_COMMAND: kb FOLLOWUP_IP: nt! ?? ::FNODOBFM::`string'+3717a fffff800`02cf4582 cc int 3 SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+3717a FOLLOWUP_NAME: MachineOwner MODULE_NAME: nt IMAGE_NAME: ntkrnlmp.exe DEBUG_FLR_IMAGE_TIMESTAMP: 4f76721c FAILURE_BUCKET_ID: X64_0x7a_c00000c0_nt!_??_::FNODOBFM::_string_+3717a BUCKET_ID: X64_0x7a_c00000c0_nt!_??_::FNODOBFM::_string_+3717a Followup: MachineOwner ---------
ST-777 ::
@MooM, morda se tvoj SSD ne razume preveč dobro z matično ploščo, ko je na AHCI. Preklopi na IDE.
Sicer nimaš OCZ-ja, lahko pa da ti bo pomagalo tole, kar je nekdo zapisal za OCZ Vertex 4: " Will not boot Windows 7 with Asus Z77 board while in AHCI mode, constant blue screens at Windows startup." http://www.newegg.com/Product/Product.a...
s51as ::
Jaz od takrat ko sem nadgradil firnware in bios nimam nobenega BSODja več. To je že cele 2 dni...
It's just me myself and I
pirlo ::
En nasvet bi rabil
. Je po vgraditvi SSD in inštalaciji Win7 x64 treba naredit kake tweake v sistemu?
TOP ::
Pomoje je tukaj bolj težava nastarni Asusa,ker podobne težave sem že zasledu z temi Sata kontrolerjem na Asus plati in ko so nekateri zamenjali plato za Gigabyte so te težave,čudežno izginile.Morda,ker si nadgradil SSD,lahko da tudi teh težav ne boš več imel,drugače bi bilo zanimivo probat na kaki drugi plati.
ST-777 ::
s51as ::
Zanimivo, ko se je meni sesulo sem pisal na tech support od OCZja in so mi svetvali naj nadgradim Firmware SSDja (pri tem sem izgubil vse podatke) in posodobim BIOS matične plošče. Včeraj sem potem malo še testirap pa poganjal razne reči in je bilo vse vredu, bo pa seveda čas pokazal ali je težava odpravljena.
MooM ::
Firmware SSDja je najbonejši in je bil upgradean takoj ob izidu. Sem pa sedaj še updateal BIOS. Upam, da bo pomagal.
dr.Akula ::
En nasvet bi rabil. Je po vgraditvi SSD in inštalaciji Win7 x64 treba naredit kake tweake v sistemu?
Tule imaš dva videa, po teh sem se jaz ravnal (nekaj je že Intel toolbox sam naredil):
ni podatka
error7891 ::
Neki me zanima. Če pride pri SSD disku do BSOD-a, ali se podatki izgubijo? Kaj pa če se ravno takrat neki kopira na disk?
darkolord ::
Če pride pri SSD disku do BSOD-a, ali se podatki izgubijo?Zaradi BSODa ne. Če je pa šel disk v franže pa dobiš zaradi tega BSOD, potem pa ja.
RejZoR ::
To ni čist res. V igri je disk cache, ki gre običajno v primeru BSOD-a v maloro. Pri HDD-jih je sicer maksimum 64MB kar ni veliko podatkov, SSD-ji pa imajo tud po 512MB cacha. To je pol giga podatkov, kar ni malo.
OldSkul ::
Kaj pravte na tole: http://www.amazon.de/gp/product/B005OK6...
180EUR za 256GB samsung 830 ssd
fireX88 ::
mislim da okol 10€...
Skyman ::
jz dal vceraj preko amazona 7€ pa se ene par centov zravn narocu pa zarnice H7,res ima veliko veze z SSD diskom tako da se opravcujem. Samo mislim da pa je tle 2 letna garancija,in ne 3 kot jo samsung ponuja poglej malo v tej smeri glede garancije.
- spremenil: Skyman ()
TOP ::
Garancija mora biti 3 leta,ker večina SSD ima 3 leta razen OCZ in Intel če se ne motim imajo 5 let.
lojzeboy ::
Kaj pa tale OCZ? Ali se splača za nezahteven sistem kot zagonski disk (55€ plus 3€ poštnine)? Drugi disk bo 2TB WD? Najbolj me zanima zanesljivost, hitrost mi ni tako zelo pomembna.
ST-777 ::
@lojzeboy, o zanesljivost OCZ Petrol 64GB lahko prebereš tukaj: http://www.newegg.com/Product/Product.a...
jurre ::
glede na to, da imate tukaj kar dosti izkusenj z SSDji me zanima, ce se je komu ze zgodilo, da prenosnik ne zazna novega SSDja? Danes sem vstavil SDD OCZ Agility 3 256gb v prenosnik Lenovo T420 namesto obstojecega HDDja. Ob zagonu prenosnik javi, da ne zazna diska. V BIOSu lahko nastavim na "compability" ali "AHCI", v obeh primerih je enako.
SSD sem priklop preko SATA to USB adapterja na delujoc racunalnik, windowsi ga zaznajo in naredijo disk 1, ter v disk managementu javijo da ga je treba inicializirat. Ko kliknem OK mi javi da "naprava ni pripravljena"?
Poskusil sem narediti inicializacijo v command promptu z diskpartom, pa ga sploh ne najde. Disk list najde disk 0 in disk 1 (v managementu kaze disk 0 HDD, disk 1 ssd) in ne glede na to ali katerega izberem mi pokazejo particije od HDDja. Ce diskpart pozenem preko winPE-ja na novem prenosniku s tem SSDjem, mi ga sploh ne zazna - najde samo DVD pogon.
SSD je nov, danes odprt iz skatle, prenosnik pa je tudi nov. SSD zanic?
- spremenil: jurre ()
ST-777 ::
@jurre, o podobnih težavah poročajo tukaj: http://www.newegg.com/Product/Product.a...
"I tried to install windows 7 on it in my laptop. Several reboots and resets later, I got it installed. But then the problems continued even after installing the SATA, Chipset and motherboard drivers." ... "No notice of the drive in BIOS of my laptop."
Nisem pa vsega podrobno bral, morda je kdo od uporabnikov tega SDD OCZ Agility 3 256gb zapisal rešitev, poglej na link.
Tilen ::
Moj OCZ Vertex 3 - ~4000 ur.
All good. Power On Count je nizek, ker se ob nadgradnji FW ta številka resetira.
Performance enak kot prvi dan :
- spremenil: Tilen ()
d0rK ::
Ne me ustrelit če je že odgovorjeno:
Zelo me mika Samsungov 830 SSD, 128GB. Prebral par zanjih postov in vidim da ni problema če stvar priklopim na Sata2 [Asus P5K-E], itak verjetno konec leta kupim Sandy mašino s Sata3. Zanima me, če je velikost kul za OS, programe in zelo slučajno kakšno igro ali dve? Koliko je uporabnega prostora na 128GB SSDju? Trenutno imam particije 30gb za OS, 20gb za Programe in 20GB za igre. Vse ostalo bo na Samsungovem Green večjem disku.
Vprašanje 2, je 830 še aktualen in dober disk ali se dobi kaj boljšega za enak denar [109evrov brez poštnine] ?
ST-777 ::
ST-777 ::
Še nekaj v zvezi z zanesljivostjo. V članku na mojmikro.si so takrat, ko so testirali Samsung 830, zapisali: "Samsung se je odločil za isto pot kot Intel in med zapisovanjem po SSD disku sproti izvaja tudi procese za čiščenje in optimizacijo, s čimer žrtvuje nekaj zmogljivosti na račun visoke zanesljivosti delovanja."
Mare3 ::
Katerega naj vzamem:
Samsung SSD 830 Serie 128GB 2.5" SATA 6Gb/s
http://www.hoh.de/hardware/ssd-laufwerk...
ali
Crucial m4 SSD 128GB 2.5" SATA III
ali
Anney ::
Po želji, Če bi jaz bi samsunga, trenutno ima moj samsung 64GB 3000h in dela s polno paro, vsak dan se na njem prepiše cca 15gb.
AgiZ ::
Kot jaz sedaj nekaj casa spremljam SSD-je vidim sledece potencialne zmagovalce (cene v nemciji):
Crucial m4 128GB (3 leta garancije) - 106€ - ze kak mesec enaka cena
OCZ Vertex 3 120GB (3 leta garancije) - 106€ - v enem mescu se je cena spustila za ~25€
OCZ Vertex 4 128GB (5 let garancije) - 127€ - v enem mescu se je cena spustila za ~20€
Samsung 830 128GB (3 leta garancije) - 109€ - v enem mescu se je cena spustila za ~30€
Intel SSD 330 Series 120GB - 121€ - ze kak mesec enaka cena
Kot jaz berem je OCZ Vertex 4 zelo dobra izbira. Trenutno je sicer cena se relativno visoka, ampak stalno pada. Sam sem najbolj zainteresiran zanj, saj ima edini 5 let garancije (intel 520 imajo tudi 5, ostali kot izgleda vsi 3) in tudi po performancah je zelo hiter.
Sam se malo pocakam da vidim ce se bo trend padanja cen nadaljeval v naslednji mesec, nakar ga bi verjetno kar kupil.
ST-777 ::
69 % uporabnikov je na newegg.com z OCZ Vertex 4 zelo zadovoljnih, kar je veliko. Previdno, če imaš Z77 chipset. Eden od njih je zapisal: "Unstable. Constant blue screens when in AHCI mode on Z77 chipset with Windows 7." http://www.newegg.com/Product/Product.a...
TOP ::
Ja tile OCZ Vertex 4 zgledajo po testih sodeč zelo dobri,edino poraja se,da se ne bi ponovila zgodba,kot Vertex 2.
