Generic host process se povezuje in nalaga
IgorMele ::
Lep pozdrav.
Torej imam problem z Generic host processom, ker se zadeva poveže na nek server in začne nekaj nalagati, sicer to lahko ustavim s firewallom, ampak bi rad popolnoma ustavil ta proces (svchost). Tole pokaže firewall:
File Version : 5.1.2600.2180
File Description : Generic Host Process for Win32 Services (svchost.exe)
File Path : C:\WINDOWS\system32\svchost.exe
Process ID : 0x3E0 (Heximal) 992 (Decimal)
Connection origin : remote initiated
Protocol : TCP
Local Address : 192.168.3.8
Local Port : 3081 (TL1-LV - TL1-LV)
Remote Name : msgr.dlservice.microsoft.com
Remote Address : 8.12.199.125
Remote Port : 80
Ethernet packet details:
Ethernet II (Packet Length: 1468)
Destination: 00-18-39-12-3b-37
Source: 00-11-50-23-1e-4c
Type: IP (0x0800)
Internet Protocol
Version: 4
Header Length: 20 bytes
Flags:
.0.. = Don't fragment: Not set
..0. = More fragments: Not set
Fragment offset:0
Time to live: 53
Protocol: 0x6 (TCP - Transmission Control Protocol)
Header checksum: 0x66c4 (Correct)
Source: 8.12.199.125
Destination: 192.168.3.8
Transmission Control Protocol (TCP)
Source port: 80
Destination port: 3081
Sequence number: 1353760947
Acknowledgment number: 951175116
Header length: 20
Flags:
0... .... = Congestion Window Reduce (CWR): Not set
.0.. .... = ECN-Echo: Not set
..0. .... = Urgent: Not set
...1 .... = Acknowledgment: Set
.... 0... = Push: Not set
.... .0.. = Reset: Not set
.... ..0. = Syn: Not set
.... ...0 = Fin: Not set
Checksum: 0x5f38 (Correct)
Data (1414 Bytes)
Binary dump of the packet:
0000: 00 18 39 12 3B 37 00 11 : 50 23 1E 4C 08 00 45 00 | ..9.;7..P#.L..E......
Zasledil sem že veliko vprašanj na to temo, vendar večinoma errorji tega procesa, računalnik je popolnoma sformatiran, pregledan z antivirusnim in antispyware-om.
Torej če kdo pozna način kako ustaviti to sitnost.
StratOS ::
Hja, imaš default servis vžgan, oz v Automatic :
"Background Intelligent Transfer Service"
Preglej :
Start/Run : services.msc
Najdeš ta servis, daš startup type na Manual ali Disabled (ne priporočam), ne met pa na Automatic.
Service Status : Stopped.
Gre za :
C:\WINDOWS\system32\svchost.exe -k netsvcs
Transfers files in the background using idle network bandwidth. If the service is stopped, features such as Windows Update, and MSN Explorer will be unable to automatically download programs and other information. If this service is disabled, any services that explicitly depend on it may fail to transfer files if they do not have a fail safe mechanism to transfer files directly through IE in case BITS has been disabled.
Lahko da ti je predhodno updatal iz spleta, pa ni zaključilo ipd ...
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
analiza hijack this
172518 (2298) klaudija
Pomoč! Urgentno - sistem okužen, sesuva se na 10 - 20 min BSOD
82723 (2445) ___
neki čudnga svchost.exe
72013 (1851) Dr_M
Težave z računalnikom
52521 (2446) mojsterleo
Neznani programi ?
151601 (1401) mihhec
