Vdor v omrežje ?
Vdor v omrežje ?
bborst81 ::
Lep pozdrav vsem. Tole se mi na routerju pod Security Log izpisuje. Lahko mal pokomentirate, kaj to pomen. Mi kdo vdira v računalnik? Lahko kaj naredim glede tega?
[Fri Feb 29 17:10:45 2008]:[LOG] Clear the secure log
[Fri Feb 29 17:34:56 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 17:36:30 2008]:[FW] **Smurf** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 17:38:44 2008]:[FW] **IP with zero Length** IP/ICMP 99.224.235.9->89.142.97.248
[Fri Feb 29 17:39:59 2008]:[FW] **IP with zero Length** IP/ICMP 213.93.225.73->89.142.97.248
[Fri Feb 29 17:40:09 2008]:[FW] **IP with zero Length** IP/ICMP 213.93.225.73->89.142.97.248
[Fri Feb 29 17:43:25 2008]:[FW] **Smurf** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 17:43:28 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 17:47:39 2008]:[FW] **Smurf** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 17:47:41 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 17:55:16 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 17:57:54 2008]:[FW] **Port Scan Detected** 85.138.58.207 -> 89.142.97.248
[Fri Feb 29 17:57:59 2008]:[FW] **Port Scan Detected** 85.138.58.207 -> 89.142.97.248
[Fri Feb 29 18:00:12 2008]:[FW] **Smurf** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:05:33 2008]:[FW] **IP with zero Length** IP/ICMP 99.224.235.9->89.142.97.248
[Fri Feb 29 18:07:23 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:07:26 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:07:30 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:09:06 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:11:08 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:15:12 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:15:14 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:15:42 2008]:[FW] **IP with zero Length** IP/ICMP 99.224.235.9->89.142.97.248
[Fri Feb 29 18:18:33 2008]:[FW] **IP with zero Length** IP/ICMP 75.137.117.83->89.142.97.248
[Fri Feb 29 18:36:51 2008]:[FW] **Port Scan Detected** 89.142.176.117 -> 89.142.97.248
[Fri Feb 29 18:43:05 2008]:[FW] **Smurf** IP/ICMP 99.224.235.9->89.142.97.248
[Fri Feb 29 18:48:32 2008]:[FW] **Port Scan Detected** 65.55.197.254 -> 89.142.97.248
[Fri Feb 29 18:54:55 2008]:[FW] **IP with zero Length** IP/ICMP 99.224.235.9->89.142.97.248
[Fri Feb 29 19:02:30 2008]:[FW] **Port Scan Detected** 207.46.166.39 -> 89.142.97.248
[Fri Feb 29 19:03:27 2008]:[FW] **IP with zero Length** IP/ICMP 99.224.235.9->89.142.97.248
[Fri Feb 29 19:17:44 2008]:[FW] **Port Scan Detected** 65.55.197.254 -> 89.142.97.248
[Fri Feb 29 19:22:41 2008]:[FW] **Port Scan Detected** 84.120.11.136 -> 89.142.97.248
[Fri Feb 29 19:22:41 2008]:[FW] **Port Scan Detected** 219.151.36.96 -> 89.142.97.248
[Fri Feb 29 19:26:58 2008]:[FW] **Port Scan Detected** 121.19.84.101 -> 89.142.97.248
[Fri Feb 29 19:28:01 2008]:[FW] **Port Scan Detected** 218.16.171.53 -> 89.142.97.248
[Fri Feb 29 19:29:12 2008]:[FW] **Port Scan Detected** 121.19.84.101 -> 89.142.97.248
[Fri Feb 29 19:30:55 2008]:[FW] **Port Scan Detected** 222.91.131.151 -> 89.142.97.248
[Fri Feb 29 19:31:00 2008]:[FW] **Port Scan Detected** 58.44.163.161 -> 89.142.97.248
[Fri Feb 29 19:33:19 2008]:[FW] **Port Scan Detected** 60.208.241.200 -> 89.142.97.248
[Fri Feb 29 19:33:20 2008]:[FW] **Port Scan Detected** 60.208.241.200 -> 89.142.97.248
OmegaBlue ::
Prej bi rekel da posledica gonjenja bittorrenta (ker se izredno ponavlja) ali pa čisto navadno "sranje" ki leti naokoli ;)
bborst81 ::
Pol pa ni panike.
"Port scan" stanje na IPv4 omrežju (strani: 1 2 )
Oddelek: Omrežja in internet
5515321 (14241) AštiriL
Kdo blokira www.computeruniverse.net?
234636 (2973) Tomaž
obtožba DoS napada!? (strani: 1 2 )
6610669 (7460) treker
nadzor prometa po Ip-jih
163535 (3245) birtija
Vdor v ClarkConnect?
Oddelek: Operacijski sistemi
52463 (2275) Nerdor
