Forum » Programska oprema » Tezave z aplikacijo v windows XP
OmegaM ::
Pozdravljeni.
Imam windows aplikacijo katera laufa na Windows 2000 SP4 brez problema.
Celotna zadeva je taka da se zazene v win 2000 brez explorerja ter laufa tocno dolocena aplikacija, in to je to.
Sedaj pa bi rad dal aplikacijo na windows xp vendar mi laufa veliko pocasneje, vendar sem ugotovil da popolnoma normalno deluje, ko je odpret explorer, ko ga spet zaprem spet deluje (zelo PRE)pocasi.
Ne vem kaj bi to lahko bila za finta, a mi lahko se kdo kaj svetuje?
Hvala in LP
Hvala in LP
Ni nam lahko, bo pa boljše!!!
OmegaM ::
Res nihce ne bi vedel, gre za printanje. In ful pocasi nalaga preden mi sploh printat, torej ko nastavim v Group Policy Custom User Interface na enabled, takrat se to pojavi, sicer sem nekaj nasel na spletu samo ne vem tega uporabit, ne razumem.
Found the following truly wonderful posting from Christian Kaiser:
Create a dummy window of the "PrintTray_Notify_WndClass" class and
check
whether it is faster.
I read this once:
// (from the Newsgroup microsoft.public.win32.programmer.gdi)
// running in an environment without Explorer, WINSPOOL will take 2
seconds for each ENDDOC() as it notifies
// this window about a change, and the window does only exist is
EXPLORER
is present. According to someone
// in the newsgroup, WINSPOOL tries 20 times with a timeout of 100ms.
Thus
let's make sure such a window is present!
_hWndPrinterNtfyTraySimulation = CreateWindow(
TEXT("PrintTray_Notify_WndClass"),
TEXT(""),
WS_POPUP,
0,0,10,10,
NULL,
NULL,
hInstance,
NULL);
Christian
To sem nasel, ampak ne znam si s tem pomagat ker ne vem kje naj to uporabim
Hvala
check
I read this once:
EXPLORER
Thus
TEXT(""),
WS_POPUP,
0,0,10,10,
NULL,
NULL,
hInstance,
NULL);
Christian
Hvala
| » | C programiranje (strani: 1 2 3 )Oddelek: Programiranje | 32934 (23230) | amacar |
| » | VS C++Oddelek: Programiranje | 2565 (1597) | Vesoljc |
| » | Win32 API in C++Oddelek: Programiranje | 1953 (1824) | Monster |
| » | OpenGL orr v ansi cOddelek: Programiranje | 2157 (1945) | igor12 |
| » | Odpiranje dat.exe v VBOddelek: Programiranje | 3834 (3627) | webblod |
