[C#] Dodajanje stringov v .txt file
maticm ::
hočem shranjevati v txt file in delam takole!
using (StreamWriter sw = new StreamWriter("k:\\TestFile.txt"))
// Add some text to the file.
sw.WriteLine(temp);
// Arbitrary objects can also be written to the file.
sw.WriteLine(DateTime.Now);
Problem je v tem, da mi vedno prepisuje zadnjo temperaturo temp...jaz pa želim, da se dodaja v ta isti txt file.
program se cikla tako da vedno kličem isti del za shranjevanje v txt datoteko (napisan zgoraj).
  • spremenilo: snow ()
MaCoFaCo ::
using (StreamWriter sw = new StreamWriter("k:\\TestFile.txt", true))
maticm ::
to sm iskal 1 uro
tnx
[c#] iz class v class
Oddelek: Programiranje
51206 (1080) darkolord
[c#] shrani text, tabele, slike
251967 (1573) Kemalito
[C#] Podatki objekta v .txt file
91017 (941) Cvenemir
[C#] Zapis texta v nek file
61400 (1298) gnomee
C# iz form2 v form1,textboxi
132258 (1884) Keki
