[Visual basic] Open file dialog in preklic
roli ::
Torej po tem vodiču se učim programiranje in sem naletel na en problem. Namreč vse OK glede prikazovanja dialoga in to problem je kaj se zgodi, ko pritisnem na cancel v dialogu.V vodiču (link zgoraj) je napisano kaj bi moral naredit vendar to nekako ne deluje. Visual basic mi v primeru, da naredim to javi tale warning:
Warning Access of shared member, constant member, enum member or nested type through an instance; qualifying expression will not be evaluated. C:\Users\Roli\Documents\Visual Studio 2005\Projects\menus\menus\Form1.vb
Napaka se nanaša na: DialogResult.Cancel
Še koda vsega skupaj:
    Private Sub OpenToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OpenToolStripMenuItem.Click
        Dim filename As String
        Dim DidWork As Integer = OpenFD.ShowDialog()
        OpenFD.InitialDirectory = "C:\"
        OpenFD.Title = "Open file"
        OpenFD.Filter = "Text Files (*.txt)|*.txt"
        filename = OpenFD.FileName
        If DidWork = DialogResult.Cancel Then
            MsgBox("Cancel Button Clicked")
        Else
            MsgBox(filename)
        End If
        MessageBox.Show(filename)
    End Sub
http://www.r00li.com
  • spremenil: roli ()
mHook ::
"Napako" imaš pri Dim DidWork.
Poskusi z
Dim DidWork As DialogResult
zavajon ::
Pa še bi bilo dobro, da propertije nastaviš preden kličeš ShowDialog()
roli ::
Aha!
Hvala za pomoč!
Visual Basic
Oddelek: Programiranje
314266 (3292) cekr
VB.net Excel v Tif
121516 (1415) saule
[VB2005Pro]Zapiranje in še Eno uprasanje
81441 (1374) UltraTX
[VB] Komunikacija s serijskimi napravami
412733 (2007) mNeRo
[VB] Open
71947 (1786) Monster
