kako raztegniti omenjene datoteke
dulem ::
Imam program xxx velik približno 8gb., z 5 datotekami.
ESI_DVD1_2007.md0
ESI_DVD1_2007.md1
ESI_DVD1_2007.md2
ESI_DVD1_2007.mdf
ESI_DVD1_2007.mds
Kako jih lahko razpakiram?
Dule
bluefish ::
datoteko *.mdf mountaš.
dulem ::
Če jo mountam z poweriso mi pokaže samo datoteko z končnico ESI_DVD1_2007.mdf ostalih 3 pa ne. Ali lahko dobim malo bolj natančne informacije.
Dule
DimmniBurek ::
Mountaš samo *.mdf, ti bo že sam naredil kar je treba. Če ne pa probaj sDeamon tools 4.08HE ali novejši
There Is No Stronger Drug Than Reality
dulem ::
Poizkusil sem tudi z Deamon toolso. Vse mi lepo pokaže kaj je gor. ko pa hočem program zagnati (setup.exe) mi napiše, da to ni veljaven Win32 program.
Dule
bluefish ::
poglej če je še kakšeen s končnico *.msi.
dulem ::
Ni samo to kar je napisano v prvem postu,
Dule
madog ::
For image files containing just .mds and .mdf, it's sufficient to rename the .mdf to .iso. Burn this file as image file in Toast.
For image-files containing an .md0-file, You need "Split and Concat"
http://download.com.com/3000-2179-10212...
Here's how:
(Leave the .mds-file alone - You don't need it, but it's not in the way either).
Rename the other files, for instance:
if Your file batch looks like this:
File.mds - (8kB)
File.mdf - (3,99GB)
File.md0 - (69,9MB)
rename them to
File.mds - (8kB)
File.iso.001 - (3,99GB)
File.iso.002 - (69,9MB)
Of course, the .mdf is the first - and main - file, so it should be named 001.
Open Split and Concat,
click on "concat", and locate and choose the two .iso files (click the first and shift-click the other to select both). Click "open".
Now, Split and Concat should present You with a nice progress bar, so sit back and relax.
When finished (it takes no more than a few minutes), check the size of the new .iso-file to see that it's roughly the same as the size of the old .mdf and .md0 combined.
If it's the same size as just one of the old files, double-check the renaming-process.
When successful, burn in Toast!
Hope I explained it well enough... I've had two successful tries out of two, so it looks like it's the way to go.
Good luck!
Kaj vse najde GOSPOD GOOGLE !!!!!!
.wtf
121835 (1587) StratOS
Kako posneti BIN & CUE datotek ??
275133 (4439) shemenko
Deamon Tool - vprašanje
52535 (2402) MP3zor
.mdf file z Nerom?
Oddelek: Programska oprema
104072 (3967) garg
Kako odpreti datoteko z končnico .mdf ?
102732 (2676) Mirč
