Konstantno pisanje po disku in škrtanje.
aambro ::
Imam WinXP SP2, inštalirane na 160GB WD disk, ki je razdeljen na dve particiji. Moti me konstantno škrtanje diska (na vsako sekundo). Ugotovil sem da škrta takrat, ko piše po disku. Ko si sklopim večino programov in vklopim Filemon (http://www.microsoft.com/technet/sysint..., vidim, da je zadeva, ki je kriva za pisanje naslednja:
15:53:28 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 14417920 Length: 32768
15:53:28 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 12288 Length: 4096
15:53:28 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 0 Length: 4096
15:53:29 System:4 IRP_MJ_WRITE* C:\$Directory SUCCESS Offset: 4096 Length: 4096
15:53:29 System:4 IRP_MJ_WRITE* C: SUCCESS Offset: 111292416 Length: 8192
15:53:33 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 14450688 Length: 24576
15:53:33 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 8192 Length: 4096
15:53:33 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 4096 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 9150464 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 11243520 Length: 8192
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 13357056 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 13983744 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 14639104 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 14860288 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 24281088 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$Mft SUCCESS Offset: 26730496 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 14475264 Length: 28672
15:53:38 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 12288 Length: 4096
15:53:38 System:4 IRP_MJ_WRITE* C:\$LogFile SUCCESS Offset: 0 Length: 4096
15:53:40 System:4 IRP_MJ_WRITE* C:\$Directory SUCCESS Offset: 4096 Length: 4096
15:53:40 System:4 IRP_MJ_WRITE* C:\$Directory SUCCESS Offset: 0 Length: 4096
15:53:41 System:4 IRP_MJ_WRITE* C:\$Directory SUCCESS Offset: 4096 Length: 4096
15:53:42 System:4 IRP_MJ_WRITE* C:\$BitMap SUCCESS Offset: 4096 Length: 4096
Zanimivo je, da imam doma tri računalnike, vse zinstalirane enako, vendar je to pisanje vidno le pri dveh, na enem pa ne. Imam 1GB rama in okoli 10GB prostega prostora na C:, 2GB pagefile.sys. Poskusil sem naslednje:
- Spremenil velikost pagefile.sys
- izklopil indeksiranje po diskih
- izklopil system restore
- izklopil Task Scheduler
Nimam instaliranih antivirusnih programov.
Kolikor sem prebral na netu ( TUKAJ), so datoteke $Logfile, $Directory, $Bitmap ipd metapodatki NTFS sistema.
Ali ima kdo kak nasvet ali idejo - zakaj se na enem PCju to ne dogaja, na dveh pa. Edina bistvena razlika pri tistem, ki se ne dogaja, je, da je trdi disk SATA.
Problem je identičen TEMU, kjer tudi niso našli rešitve.
JOKER ::
Lahko ti odgovorim glede škrtanja ....
Mislim, da bo disk počasi "pobralo". :\
Jaz sem imel z tem škrtanjem prav tako težave (dolgo nazaj lahko celo najdeš temo na SloTechu), kjer sem dobil odgovor, da bo disk počasi šel u maloro.
Zadeva je bila hvalabogu pod garancijo in res, ko sem comp odnesel na servis so mi nemudoma zamenjali disk.
Lep pozdrav
________________________________________________________
Ka te češ ....
aambro ::
Meni sta tudi že dva diska v preteklosti šla v maloro in sta škrtala, ampak je bol zvok bolj kovinski. Ta zvok o katerem govorim je zvok, ki nastane le ob pisanju. Je pa res, da če potipam disk, da se ob škrtanju rahlo strese bolj, kot se drugi, ravno tako WD (200GB, 120GB). Mogoče pa bom uveljavljal garancijo.
Če bi kdo preveril s filemonom če ima enake zapise vsake par sekund, bi mu bil hvaležen.
C in funkcije ter #define
Oddelek: Programiranje
464889 (3250) misek
Disk - stalno brska
Oddelek: Operacijski sistemi
121785 (1469) cekr
[baze] Povezava do slike ali BLOB?
102023 (1820) BlueRunner
[NALOGA][Java] Branje vsebine datoteke vzvratno
71913 (1855) SkIDiver
Kaj nardi ta skripta?
141376 (1287) Monster
