[c++] g++ linux ne prevede se mi koda
Tutankhamun ::
#main.cpp
#include "map"
using namespace std;
template < typename psr > class CdrParseUnit
public:
	CdrParseUnit (psr *p) : m_psr (p), m_data (NULL), m_inUse (NULL) {}
	virtual ~CdrParseUnit () {}
public:
	virtual void Connect (void *data, bool *inUse)
		m_data = data;
		m_inUse = inUse;
		if (inUse != NULL)
			*m_inUse = false;
	virtual	void *GetData (bool inUse) { *m_inUse = inUse; return m_data; }
	virtual int Parse () = 0;
protected:
	psr	*m_psr;
	void	*m_data;
	bool	*m_inUse;
template < typename psr > class HeadPsr200 : public CdrParseUnit < psr >
public:
	HeadPsr200 (psr *p) : CdrParseUnit < psr > (p) {}
	virtual int Parse () { return this->m_psr->Parse (this); }
template < typename psr > class CRecordParse
public:
	CRecordParse (psr *p) : m_psr (p)
		m_units[200] = m_head200 = new HeadPsr200 < psr > (p);
	~CRecordParse ()
		for (arr::iterator iter = m_units.begin(); iter != m_units.end(); ++iter)
			delete iter->second;
private:
	psr		*m_psr;
protected:
	typedef map<long,CdrParseUnit< psr >*> arr;
	arr	m_units;
prevajam pa tako:
g++ -Wall -c main.cpp
rezultat pa je tak:
main.cpp: In destructor ‘CRecordParse< psr >::~CRecordParse()’:
main.cpp:48: error: expected `;' before ‘iter’
main.cpp:48: error: ‘iter’ was not declared in this scope
Visual studio mi pa prevede...
AMD Phenom QUAD 9950 Black Edition, 8GB
BigWhale ::
> arr::iterator
Do tega lahko 'dostopas'. Morda ti kak include manjka. :)
Tutankhamun ::
Vem da je tm neki narobe, sam nevem kaj. Lej če pa predelam to datoteko, tko da par stvari zbrišem pa se prevede..
#include "map"
class CRecordParse
public:
	~CRecordParse ()
protected:
	typedef map<long,long*> arr;
	arr	m_units;
Js mislm da je zarad teh template-ov neki narobe...
Gundolf ::
typename arr::iterator
Aja, tako napisi v tisti zanki, kjer je napaka, pa bo delalo. Prevec templejtov na kupu je lahko prevec, da bi kompajler vedel kaj vse je subclass in kaj je member spremenljivka tega ali onega classa.
  • spremenil: Gundolf ()
Tutankhamun ::
Hvala...
Zdej pa dela.
[PHP] Composer ne najde/vključi razreda izven vendor mape
Oddelek: Programiranje
51833 (1672) krenpac
C++ programi
73116 (2712) ERGY
Vodenje videoteke v C++
52186 (2006) Tutankhamun
[JAVA] zaustavitev niti (threadov)
223681 (3681) morbo
Qt Designer -> KDevelop C++ Error
352457 (1987) 'FireSTORM'
