Forum » Pomoč in nasveti » požarni zid
požarni zid
jan01 ::
Kaj če bi hijackthisov log prilepil?!
Poskusi s SDFix
Uporabljaj kake prave firewalle npr outpost, comodo, jetico,...
Poskusi s SDFix
Restart your computer
After hearing your computer beep once during startup, but before the Windows icon appears, tap the F8 key continually;
Instead of Windows loading as normal, a menu with options should appear;
Select the first option, to run Windows in Safe Mode, then press "Enter".
Choose your usual account.
In Safe Mode, right click the SDFix.zip folder and choose Extract All,
Open the extracted folder and double click RunThis.bat to start the script.
Type Y to begin the script.
It will remove the Trojan Services then make some repairs to the registry and prompt you to press any key to Reboot.
Press any Key and it will restart the PC.
Your system will take longer that normal to restart as the fixtool will be running and removing files.
When the desktop loads the Fixtool will complete the removal and display Finished, then press any key to end the script and load your desktop icons.
Finally open the SDFix folder on your desktop and copy and paste the contents of the results file Report.txt back onto the forum with a new HijackThis log
malavasic ::
evo log
Logfile of HijackThis v1.99.1
Scan saved at 22:15:37, on 5.3.2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
d:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\wuauclt.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\MSN Messenger\usnsvc.exe
C:\Program Files\WinRAR\WinRAR.exe
D:\Zacasno\Temp\Rar$EX00.328\HijackThis.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O17 - HKLM\System\CCS\Services\Tcpip\..\{20B58F7C-6893-4EEA-ADD8-E44388E1B7BE}: NameServer = 193.2.1.66 193.2.1.72
O17 - HKLM\System\CS1\Services\Tcpip\..\{20B58F7C-6893-4EEA-ADD8-E44388E1B7BE}: NameServer = 193.2.1.66 193.2.1.72
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - d:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
l.p
Running processes:
l.p
| » | problem z računalnikom!!Oddelek: Pomoč in nasveti | 2785 (2584) | mjk |
| » | Optimizacija Win XPOddelek: Operacijski sistemi | 3515 (3254) | jan01 |
| » | Težave Firefox-omOddelek: Pomoč in nasveti | 2540 (2413) | mikes |
| » | Trojan big problem:(Oddelek: Strojna oprema | 4453 (4246) | mini-moris |
| » | VirusOddelek: Pomoč in nasveti | 3792 (3717) | koyotee |
