Forum » Operacijski sistemi » [Linux][Postfix] naslovnik neznan
'FireSTORM' ::
danes sem probal poslat en mail iz svojega serverja enemu uporanbiku na trieri
in dobil ta error:
mail@triera.si: host mx1.triera.net[213.161.0.26] said: 550
mail@triera.si: Recipient address rejected: User unknown in
virtual alias table (in reply to RCPT TO command)
je to napaka mojega strežnika ali njihovega?
ta mail sem pa dobil nazaj od mailer-daemon mojega streznika
mam filing da je moja greška ampak nevem kaka
uporabljam pa postfix
edit:
še izpis iz maillog:
Dec 13 21:25:07 x postfix/qmgr[2220]: 0E8D52DED46: from=moj@mail.com, size=1023, nrcpt=1 (queue active)
Dec 13 21:25:15 x postfix/smtp[10070]: 0E8D52DED46: host mx1.triera.net[213.161.0.27] said: 450 mail@triera.si: Recipient address rejected: Greylisted, please try again later (in reply to RCPT TO command)
Dec 13 21:25:19 x postfix/smtp[10070]: 0E8D52DED46: to=mail@triera.si, relay=mx1.triera.net[213.161.0.25]:25, delay=14, delays=1/0.04/12/0.25, dsn=4.0.0, status=deferred (host mx1.triera.net[213.161.0.25] said: 450 mail@triera.si: Recipient address rejected: Greylisted, please try again later (in reply to RCPT TO command))
potem pa še to:
Dec 13 21:58:26 x postfix/qmgr[2220]: 0E8D52DED46: from=moj@mail.com, size=1023, nrcpt=1 (queue active)
Dec 13 21:58:27 x postfix/smtp[10385]: 0E8D52DED46: to=mail@triera.si, relay=mx1.triera.net[213.161.0.26]:25, delay=2001, delays=2001/0.02/0.38/0.19, dsn=5.0.0, status=bounced (host mx1.triera.net[213.161.0.26] said: 550 mail@triera.si: Recipient address rejected: User unknown in virtual alias table (in reply to RCPT TO command))
tu niso uporabljeni pravi maili oz. nisem postal pravih mailov, sem ji ponaredil...
in dobil ta error:
edit:
potem pa še to:
Those penguins.... They sure aint normal....
- spremenilo: CCfly ()
416c6573a ::
Ponarejat se ne sme!!!
napaka triere oziroma uporabnik/alias ne obstaja oziroma je oznacen ali pa si ti oznacen na spam listi. pisal je da gre to opozorilo v vednost posiljatelju oziroma na mail REPLY-TO, to je bil pa tvoj mail.
s tvojmu streznikom naj bi bilo vse kul.
Lastnorocno.
'FireSTORM' ::
lol...ponaredil sem maile sam za javnost
uporabljam prave maile, vam pa kažem "ponarejene"
nevem zakaj bi pa naj bil na spam listi
Bojan xxxx ::
Mah, saj ti piše v log fajlu:
uporabi googla in poglej, kaj pomeni greylisting. Skratka, na prvi mail od do tedaj neznanega pošiljatelja bo mailserver odgovoril z "temporary unavailable". Po nekem času (ponavadi nekaj minut) bo pa zadevo spustil naprej.
'FireSTORM' ::
je res...jaz sem za njih "spamer"
torej moram poslat mail skozi mail server od ISPja...
v sendmail mi to ni bil prob nastavit, v postfix mam pa kar nekaj problemov z tem...
kak se to nastavi?
nastavil sem že relayhost = smtp.isp.com
še kaj več moram?
edit:
še eno vprašanje
če ma kdo kak guide kako nastavit na postfix smtp auth
pop before smtp odpade
kak se to nastavi?
še kaj več moram?
edit:
še eno vprašanje
- spremenil: 'FireSTORM' ()
b ::
Pa kaj tle noben ne zna brat?
Prva "napaka" je zaradi greylistinga, koda je 450, poskusi pozneje. Tvoj mail server to tudi stori (ker nisi spammer), nakar dobi napako "recipient unknown" - naslovnik ne obstaja.
Problem je torej v tem, da mail, na katerega posiljas, ne obstaja (vec).
| » | Problem z brezžično povezavoOddelek: Omrežja in internet | 2690 (2448) | solatko |
| » | Težava pri pošiljanju na @siol.netOddelek: Omrežja in internet | 3329 (3119) | Bakunin |
| » | Outlook 2003 pošiljanje pošte in linkiOddelek: Pomoč in nasveti | 2823 (2618) | lojze8 |
| » | [LINUX] Pošiljanje mailaOddelek: Operacijski sistemi | 2370 (2247) | 'FireSTORM' |
| » | Posiljanje E-MAILAOddelek: Pomoč in nasveti | 4468 (4388) | Cuoresportivo |
