Težava z inštalacijo openldap-ja
nekdo321 ::
Open ldap (ne do konca) sem inštaliral po naslednjih navodilih:
http://www.proscrutiny.com/howtos/OpenLDAP.html
Ko pridem do tega :
env \
CC=gcc CPPFLAGS="-I/usr/local/include/" \
LDFLAGS="-L/usr/local/lib/" \
./configure --with-ssl --with-tls --enable-wrappers --enable-hdb --enable-ldbm
dobim
configure: error: Berkeley DB version mismatch
isto se zgodi če napišem samo ./configure
Kaj naj naredim?
  • spremenilo: nekdo321 ()
jure1825 ::
export LD_LIBRARY_PATH="BerkelyDB Directory path/build_unix/.libs"
nekdo321 ::
Zdaj imam pa težavo z zagonom
/usr/local/libexec/slapd -h 'ldap://127.0.0.1:3890/ ldaps://127.0.0.1:6360/' -d 255
@(#) $OpenLDAP: slapd 2.3.27 (Oct 23 2006 19:23:10) $
root@Ldap-server:/root/openldap-2.3.27/servers/slapd
daemon_init: ldap://127.0.0.1:3890/ ldaps://127.0.0.1:6360/
daemon_init: listen on ldap://127.0.0.1:3890/
daemon_init: listen on ldaps://127.0.0.1:6360/
daemon_init: 2 listeners to open...
ldap_url_parse_ext(ldap://127.0.0.1:3890/)
daemon: bind(7) failed errno=98 (Address already in use)
slap_open_listener: failed on ldap://127.0.0.1:3890/
slapd stopped.
connections_destroy: nothing to destroy.
Kaj naj naredim?
nekdo321 ::
Zdaj sem uspel inštalirati openldap in ga startam zdaj pa ne vem kako naj dodam .ldif?
Uporabljam bazo bdb
Dnsmasq problem
Oddelek: Omrežja in internet
131471 (1098) BlaY0
ubuntu slapd pomoč
Oddelek: Operacijski sistemi
101028 (859) korenje3
Težava z zagonom ldap serverja
81555 (1501) kopernik
Group Policy; kako nastavit GPO za OU?
383405 (3077) Microsoft
freesco
72287 (2113) mile
