Dump kode fx-a v temi "javascript pomoc ..."
BluPhenix ::
<html>
 <head>
  <title>Obrazec.htm</title>
 </head>
 <body>
 <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<script type="text/javascript">
   function emailnaslov(str){
	  var at="@"
	  var dot="."
	  var lat=str.indexOf(at)
	  var lstr=str.length
	  var ldot=str.indexOf(dot)
	  if (str.indexOf(at)==-1){return false}
      if (str.indexOf(at)==-1 || str.indexOf(at)==0 || str.indexOf(at)==lstr){return false}
      if (str.indexOf(dot)==-1 || str.indexOf(dot)==0 || str.indexOf(dot)==lstr){return false}
      if (str.indexOf(at,(lat+1))!=-1){return false}
      if (str.substring(lat-1,lat)==dot || str.substring(lat+1,lat+2)==dot){return false}
      if (str.indexOf(dot,(lat+2))==-1){return false}
      if (str.indexOf(" ")!=-1){return false}
      return true
   function dodajVrstico()
      var table = document.createElement("table");
      var tbody = document.createElement("tbody");
      var tr = document.createElement("tr");
      var td = document.createElement("td");
      var text = document.createTextNode("(Obvezni vnos)");
      td.appendChild(text);
      tr.appendChild(td);
      tbody.appendChild(tr);
      table.appendChild(tbody);
      table.setAttribute("border", "0");
      document.body.appendChild(table);
   function preveri(obr){
      var test = false;
      var emailID=obr.txt_email;
	  var izpis = "";
	  if((obr.txt_ime.value == "") || (obr.txt_priimek.value == "") || ((obr.txt_email.value==null)||(obr.txt_email.value=="")) || (echeck(obr.txt_email.value)==false))
	     if(obr.txt_ime.value == ""){
		    dodajVrstico();
	     if(obr.txt_priimek.value == ""){izpis = izpis + '\n  - priimek'}
	     if((obr.txt_email.value==null)||(obr.txt_email.value=="")) {
		    izpis = izpis + '\n - E-mail'
		    if(emailnaslov(obr.txt_email.value)==false){ izpis = izpis + '\n - Napacen E-mail naslov'
         alert("Vnesi naslednje podatke : " + izpis);
      else {
      return true;
</script>
  <form onsubmit="return preveri(this)">
   <table>
    <tr>
     <td width="200">Ime :</td>
     <td><input name="txt_ime" type="text"></td>
    </tr>
    <tr>
     <td>Priimek :</td>
     <td><input name="txt_priimek" type="text"></td>
    </tr>
	<tr>
	 <td>Rojstni datum :</td>
	 <td>
      <select name="txt_roj_dan" onblur="addFirstEntry();" tabindex="23" onchange="spremembe=1;"> <option value="1"> 1 </option> <option value="2"> 2 </option> <option value="3"> 3 </option> <option value="4"> 4 </option> <option value="5"> 5 </option> <option value="6"> 6 </option> <option value="7"> 7 </option> <option value="8"> 8 </option> <option value="9"> 9 </option> <option value="10"> 10 </option> <option value="11"> 11 </option> <option value="12"> 12 </option> <option value="13"> 13 </option> <option value="14"> 14 </option> <option value="15"> 15 </option> <option value="16"> 16 </option> <option value="17"> 17 </option> <option value="18"> 18 </option> <option value="19"> 19 </option> <option value="20"> 20 </option> <option value="21"> 21 </option> <option value="22"> 22 </option> <option value="23"> 23 </option> <option value="24"> 24 </option> <option value="25"> 25 </option> <option value="26"> 26 </option> <option value="27"> 27 </option> <option value="28"> 28 </option> <option value="29"> 29 </option> <option value="30"> 30 </option> <option value="31"> 31 </option> </select> <select name="txt_roj_mesec" onblur="addFirstEntry();" tabindex="26" onchange="spremembe=1;"> <option value="1"> 1 </option> <option value="2"> 2 </option> <option value="3"> 3 </option> <option value="4"> 4 </option> <option value="5"> 5 </option> <option value="6"> 6 </option> <option value="7"> 7 </option> <option value="8"> 8 </option> <option value="9"> 9 </option> <option value="10"> 10 </option> <option value="11"> 11 </option> <option value="12"> 12 </option> </select> <select name="txt_roj_leto" onblur="addFirstEntry();" tabindex="29" onchange="spremembe=1;"> <option value="1886"> 1886 </option> <option value="1887"> 1887 </option> <option value="1888"> 1888 </option> <option value="1889"> 1889 </option> <option value="1890"> 1890 </option> <option value="1891"> 1891 </option> <option value="1892"> 1892 </option> <option value="1893"> 1893 </option> <option value="1894"> 1894 </option> <option value="1895"> 1895 </option> <option value="1896"> 1896 </option> <option value="1897"> 1897 </option> <option value="1898"> 1898 </option> <option value="1899"> 1899 </option> <option value="1900"> 1900 </option> <option value="1901"> 1901 </option> <option value="1902"> 1902 </option> <option value="1903"> 1903 </option> <option value="1904"> 1904 </option> <option value="1905"> 1905 </option> <option value="1906"> 1906 </option> <option value="1907"> 1907 </option> <option value="1908"> 1908 </option> <option value="1909"> 1909 </option> <option value="1910"> 1910 </option> <option value="1911"> 1911 </option> <option value="1912"> 1912 </option> <option value="1913"> 1913 </option> <option value="1914"> 1914 </option> <option value="1915"> 1915 </option> <option value="1916"> 1916 </option> <option value="1917"> 1917 </option> <option value="1918"> 1918 </option> <option value="1919"> 1919 </option> <option value="1920"> 1920 </option> <option value="1921"> 1921 </option> <option value="1922"> 1922 </option> <option value="1923"> 1923 </option> <option value="1924"> 1924 </option> <option value="1925"> 1925 </option> <option value="1926"> 1926 </option> <option value="1927"> 1927 </option> <option value="1928"> 1928 </option> <option value="1929"> 1929 </option> <option value="1930"> 1930 </option> <option value="1931"> 1931 </option> <option value="1932"> 1932 </option> <option value="1933"> 1933 </option> <option value="1934"> 1934 </option> <option value="1935"> 1935 </option> <option value="1936"> 1936 </option> <option value="1937"> 1937 </option> <option value="1938"> 1938 </option> <option value="1939"> 1939 </option> <option value="1940"> 1940 </option> <option value="1941"> 1941 </option> <option value="1942"> 1942 </option> <option value="1943"> 1943 </option> <option value="1944"> 1944 </option> <option value="1945"> 1945 </option> <option value="1946"> 1946 </option> <option value="1947"> 1947 </option> <option value="1948"> 1948 </option> <option value="1949"> 1949 </option> <option value="1950"> 1950 </option> <option value="1951"> 1951 </option> <option value="1952"> 1952 </option> <option value="1953"> 1953 </option> <option value="1954"> 1954 </option> <option value="1955"> 1955 </option> <option value="1956"> 1956 </option> <option value="1957"> 1957 </option> <option value="1958"> 1958 </option> <option value="1959"> 1959 </option> <option value="1960"> 1960 </option> <option value="1961"> 1961 </option> <option value="1962"> 1962 </option> <option value="1963"> 1963 </option> <option value="1964"> 1964 </option> <option value="1965"> 1965 </option> <option value="1966"> 1966 </option> <option value="1967"> 1967 </option> <option value="1968"> 1968 </option> <option value="1969"> 1969 </option> <option value="1970"> 1970 </option> <option value="1971"> 1971 </option> <option value="1972"> 1972 </option> <option value="1973"> 1973 </option> <option value="1974"> 1974 </option> <option value="1975"> 1975 </option> <option value="1976"> 1976 </option> <option value="1977"> 1977 </option> <option value="1978"> 1978 </option> <option value="1979"> 1979 </option> <option value="1980"> 1980 </option> <option value="1981"> 1981 </option> <option value="1982"> 1982 </option> <option value="1983"> 1983 </option> <option value="1984"> 1984 </option> <option value="1985"> 1985 </option> <option value="1986"> 1986 </option> <option value="1987"> 1987 </option> <option value="1988"> 1988 </option> <option value="1989"> 1989 </option> <option value="1990"> 1990 </option> <option value="1991"> 1991 </option> <option value="1992"> 1992 </option> <option value="1993"> 1993 </option> <option value="1994"> 1994 </option> <option value="1995"> 1995 </option> <option value="1996"> 1996 </option> <option value="1997"> 1997 </option> <option value="1998"> 1998 </option> <option value="1999"> 1999 </option> <option value="2000"> 2000 </option> <option value="2001"> 2001 </option> <option value="2002"> 2002 </option> <option value="2003"> 2003 </option> <option value="2004"> 2004 </option> <option value="2005"> 2005 </option> <option value="2006" selected="selected"> 2006 </option> </select>
	 </td>
	</tr>
    <tr>
	 <td>Ulica, Hišna številak :</td>
	 <td><input name="txt_naslov" type="text"/></td>
	</tr>
    <tr>
	 <td>Pošta</td>
	 <td><input name="lkp_post_fkeyi_ref" id="lkp_post_fkeyi_ref" onchange="spremembe=1;" type="hidden"> <input name="lng_zip" id="lng_zip" tabindex="50" onchange="spremembe=1;lookup_check(1996,'lng_zip',document.getElementById('lng_zip').value,'lng_post_pkeyi,lng_zip,txt_city','lkp_post_fkeyi_ref,lng_zip,txt_city','','lookup_part_data2','lkp_post_fkeyi_ref','lng_zip', '')" onkeydown="lookup_key(this.onchange,this.value.length,event)" size="5" type="text"><span id="lookup_part_data2" style="display: none;"> ../lookup/lookup.cfm?layout=1088&view=1996&l_fild_pkeyi=lkp_hotel_fkeyi_ref&l_fildi_f=txt_hotel_pkeyc1,txt_hotel&l_fildi_q=txt_hotel_pkeyc1,txt_name&search= </span><label> <input name="txt_city" id="txt_city" tabindex="55" size="20" onchange="spremembe=1;lookup_check(1996,'txt_city',document.getElementById('txt_city').value,'lng_post_pkeyi,lng_zip,txt_city','lkp_post_fkeyi_ref,lng_zip,txt_city','','lookup_part_data2','lkp_post_fkeyi_ref','lng_zip', '')" onkeydown="lookup_key(this.onchange,this.value.length,event)" type="text"></label></td>
	</tr>
	<tr>
	 <td>E-mail :</td>
	 <td><input name="txt_email" type="text" /></td>
	</tr>
	<tr>
	 <td>Telefon :</td>
	 <td><input name="txt_telefon" type="text" /></td>
	</tr>
	<tr>
	 <td>GSM :</td>
	 <td><input name="txt_gsm" type="text"  /></td>
    </tr>
	<tr>
	 <td>Izobrazba :</td>
	 <td><input name="txt_izobrazba" type="text"  /></td>
    </tr>
    <tr>
     <td valign="top">Zakaj bi postal promotor?<br>Predstavi se in navedi<br><b>vzrok, želje in cilje</b>.</td>
     <td><textarea name="txt_opis" rows="5" cols="50"></textarea></td>
    </tr>
    <tr>
	 <td colspan="2"><p align="right"><input value="Pošlji" type="submit"></p></td>
    </tr>
   </table>
  </form>
 </body>
</html>
Podpisa ni več, ker so me poskušali asimilirati.
Java
Oddelek: Programiranje
91689 (1057) 123mg
PHP izpisovanje vrstic
61119 (982) Miha 333
urejanje - python
51687 (1464) ktka
[C++][Naloga_polja]MIN in MAX polja, izpis za x.100 stevil
223333 (3144) snow
Binarni sistem
Oddelek: Šola
135376 (5195) Sergio
