Forum » Kaj kupiti » Pomoc pri nakupu PC-ja
Solar ::
Kupujem pa me zanima mnenje.
Namen racunalnika za splosno uporabo
Cene so v kunah,pa odbiti je treba davek
procesor............................ AMD Athlon 64 3000+, 1800 MHz, 512 kb c., socket 939, BUS 2000 MHz, BOX (Venice core)---734,00
maticno plosco ..................... MBO EPOX, s. 939, 9HDAI Pro, VIA K8T800 Pro, BUS 2000 MHz, serial ATA, RAID, 5.1 zvuk, DDR 400, LAN, ATX 2---471,00
ram ..........................................RAM, 512 MB, DDR, PC-3200, 400 MHz, OEM ---287,00
DVD-rom ................................ DVD pisač, DVD±RW & DVD±R & DVD-Ram NEC ND-4571, LabelFlash 16x, 8x dual layer 8.5 GB, bulk, NERO---310,00
graficno kartico ......................... VGA AGP SAPPHIRE ATI Radeon 9550 LR, 256 MB, tv-out, DVI---406,00
disketno enoto .......................... FDD 1, 44 MB, 3, 5"---53,00
ohisje...........................................Midi Tower, AOPEN Component Pro KA45A02, 350 W, ATX 2, crno---297,00
misko ........................................ Miš LOGITECH G1 Optical, USB + PS/2---187,00
hard disc 160 GB .......................HDD MAXTOR 160 GB, serial ATA-II, 7200 o/min., 8 MB cache---497,00
Tiskalnik ...................................Printer ink-jet CANON Pixma IP1500, 4800 dpi, USB--- 380,00
monitor 17'..................................Mon. 17" XENON, M7000DF, 30-70 kHz, 0.23 mm, srebrno-crni, flat---699,00
GrimReaper ::
Plata ima VIA čipovje (not very good), pa kartica 9550 tudi ni nevem kaj, samo to je odvisno kaj boš počel z računalnikom, za igre sigurno rabiš vsaj 7300GT, raje 7600GS.
Solar ::
Kaj pa kaksna od teh plosc
aMBO EPOX, s. 939, 9NPA3J, nForce 4, BUS 2000 MHz, serial ATA, RAID, 7.1 zvuk, DDR 400, 1Gbps, ATX 2......520 kun
MBO EPOX, s. 939, 9NPA+ Ultra, nForce 4 Ultra, BUS 2000 MHz, serial ATA II, RAID, 7.1 zvuk, DDR 400, 1Gbps, FireWire, ATX 2....680,00
MBO EPOX, s. 939, 9NDA3I, nForce 3 250, BUS 2000 MHz, serial ATA, 5.1 zvuk, DDR 400, LAN, ATX 2....467,00
MBO ASROCK, s. 939, A8X-M, ALI M1689, BUS 2000 MHz, serial ATA, RAID, 7.1 zvuk, DDR 400, LAN, ATX 2....456
MBO ASROCK, s. 939, 939S56-M, SIS 756, BUS 2000 MHz, serial ATA, RAID, 7.1 zvuk, DDR 400, LAN, mATX....395,00
MBO ASROCK, s. 939, 939NF4G-VSTA, nVidia GeForce 6100, BUS 2000 MHz, VGA, serial ATA II, RAID, 7.1 zvuk, DDR 400, LAN, mATX....488,00
MBO ABIT, s. 939, NF 95, nVIDIA C51G, BUS 2000 MHz, serial ATA II, RAID, VGA, 5.1 zvuk, DDR 400, LAN, mATX ....543,00
MBO ABIT, s. 939, KN8, nForce 4, BUS 2000 MHz, serial ATA, RAID, 7.1 zvuk, DDR 400, 1Gbps, Firewall, ATX 2....639,00
GrimReaper ::
Prvi dve sta dobri, samo sedaj moraš še grafično zamenat, ker imata PCI-E, Radeon 9550 pa je AGP.
Solar ::
Katera od teh bi bila dobra
VGA PCI-E SAPPHIRE ATI Radeon X550 , 256 MB, tv-out, DVI...457,00
VGA PCI-E, ATI Radeon X550, 256 MB, tv-out, DVI....480,00
VGA PCI-E CLUB 3D, ATI Radeon X300 SE, , 128 MB, tv-out, DVI....355,00
VGA PCI-E LEADTEK, WinFast PX6200 TC TDH, Geforce 6200, , 128 MB, tv-out, DVI....339,00
- spremenilo: Solar ()
Vse so bolj tak.
Med temi je najboljša 128bitna X550 če je katera od teh 128bitna.
Melanholija ::
dobra ni nobena tako kot je mtosev reku jst bi uzev 7300gt al pa 7600gs mogoče 6600gt jo dobiš za 10k in je to velik bolši nakup
Solar ::
Tale graficna ni 10k ampak 60k
VGA PCI-E LEADTEK, WinFast Duo PX6600 GT TDH, 2x Geforce 6600 GT SLI, , 256 MB, tv-out, DVI....2.175,00
Graficno rabim za bolj nezahtevne igre,seveda pa iscem nekaj najboljsega za majhen denar
kikicar ::
ma ja rabljena je ze za 10k nova pa pride cca 25k
klik
klik
klik
klik
cca 25k
!! Kje pa si ti to videl? tukaj sem dodal linke do štirih različnih spletnih trgovin, ki prodajajo grafične 6600gt agp ali pci-e in nobena ni ispod 30k nova! Ne vem pa kje si zasledil ceno 10k za rabljeno!
duleman prej poglej cenike preden kaj pišeš da ne bodo ljudje mislili da jih v trgovinah nategujejo...
klik
klik
klik
klik
cca 25k
- spremenil: kikicar ()
GrimReaper ::
Tisti je dal gotovo pridržano ceno na 20k.
Najcenejša na Bolhi je za 18k, povprečje je bolj 25k.
Melanholija ::
ja jst vem za 2 msi kartice ki so se prodale ena za 10 in ena za 15 k tak da nevem no!
| » | PC za delo s Fotoshopom in Autocadom (igric ne špilam)Oddelek: Kaj kupiti | 1857 (1857) | Liker |
| » | Nakup računalnika za 185kSIT, komentar prosimOddelek: Kaj kupiti | 2047 (1887) | ZLOky |
| » | Priporočila za nov nakup (strani: 1 2 )Oddelek: Kaj kupiti | 8004 (5945) | KandazaR |
| » | MamaplataOddelek: Kaj kupiti | 1850 (1711) | SSH |
| » | Kateri rač. kupiti??Oddelek: Kaj kupiti | 1277 (1162) | migič |
