Forum » Programska oprema » Zelo dober freeware program za pečenje
AVS
AVS Disc Creator Features:
ABSOLUTELY FREE
It is absolutely free data CD/DVD burning software. No trial periods, no feature limitations.
No spyware or adware;
BLU-RAY DISCS RECORDING SUPPORT
Burn your data on the next-generation Blu-ray Discs and take full advantage of the new high-capacity storage technology (25 or 50 GB per Blu-ray Disc). With free AVS Disc Creator it is as easy as common CDs or DVDs.
WIDE RANGE OF SUPPORTED MEDIA TYPES
AVS Disc Creator supports CD-R/RW, DVD+/-R, DVD+/-RW, DVD-RAM, Double/Dual Layer DVD and the latest Blu-ray technology BD-R and BD-RE.
WIDE RANGE OF SUPPORTED CD/DVD DRIVES
Designed and tested for IDE, SATA, SCSI, USB, and Firewire drives. Works easily with most CD/DVD recording drives.
TRUE MULTISESSION SUPPORT
Import previous session and add new files to an existing session - even for DVD formats. It does not matter what software you used to create this disc before.
EASY FILE/FOLDER MANAGEMENT
Easily add, delete, replace, rename, and copy files and directories on CDs and DVDs.
Write files or folders with right-click and selecting the Send To option.
DISC IMAGE SUPPORT
Create, write and even edit disc images (ISO), remove or add files and folders from/to images.
PROJECTS
Organize your burning tasks into projects to simplify everyday work.
MULTILINGUAL SUPPORT
Now AVS Disc Creator interface is available in English, French, German, Spanish and Italian.
DATA VERIFICATION
Verify your recorded discs to make sure no data is lost.
Probajte
ABSOLUTELY FREE
DISC IMAGE SUPPORT
PROJECTS
DATA VERIFICATION
Probajte
| » | Prvi grafenski holografski optični diskOddelek: Loža | 2973 (2755) | msjr |
| » | Prodaja Blu-rayev zrasla, DVD-ji daleč spredajOddelek: Novice / Optične enote / mediji | 6783 (4268) | Mr.B |
| ⊘ | Blu Ray kako zapeči discOddelek: Zvok in slika | 5104 (4769) | telexdell |
| » | Alternativa Nero-tuOddelek: Programska oprema | 2960 (2872) | Carmack |
