Forum » Izdelava spletišč » Kaj je to
Kaj je to
Tody ::
Zgleda da si preveč mutio ;) Ali so ti ukradili domeno ali pa si pozabil plačati zadevo in ti je nekdo zadevo registriral...
Na kratko YOU ARE FU**ED UP !
The Domain "www.mutnik.org" is not at present available. Dear visitor, we would like you to ask it again to try nevertheless later. We accomplish at present a removal into the new computing centre. Yours sincerely the Webhosting team. __________________________________________________________ new IP: 89.163.162.108 please considers to be updated you that the data of the name servers only must. Those can should starting from approx. 2:00 have happened. A restart of PC and/or rout is then helpful. You can see the status of current removal in the customer forum.
Domain Name: MUTNIK.NET
Status:LOCKED
Note: This Domain Name is currently Locked. In this status the domain
name cannot be transferred, hijacked, or modified. The Owner of this
domain name can easily change this status from their control panel. This
feature is provided as a security measure against fraudulent domain name hijacking.
Creation Date: 26-Oct-2005
Expiration Date: 26-Oct-2006
Domain servers in listed order:
claudia.hosting-friends.de
julia.hosting-friends.de
Registrant:
Ajdin Perviz (ajdin.perviz@catv.rol.ch)
Gruenaustrasse 17
Buchs
,9470
CH
Tel. +49.190858952951
Administrative Contact:
Gruenaustrasse 17
Buchs
,9470
CH
Technical Contact:
SQAMPY.net
Stefan Broese (sqampy@gmx.net)
Wickersroeder Str. 1
Hess. Lichtenau
,37235
DE
Tel. +49.190658065223
Fax. +49.5602914157
Billing Contact:
SQAMPY.net
Hess. Lichtenau
,37235
DE
Fax. +49.5602914157
Status:LOCKED
Registrant:
Gruenaustrasse 17
Buchs
,9470
CH
Gruenaustrasse 17
Buchs
,9470
CH
Technical Contact:
SQAMPY.net
Hess. Lichtenau
,37235
DE
Fax. +49.5602914157
Billing Contact:
SQAMPY.net
Hess. Lichtenau
,37235
DE
Fax. +49.5602914157
ManyMan ::
Gruenaustrasse 17
Buchs
,9470
CH
a ta je na novo registriru ali kaj
Gruenaustrasse 17
Buchs
,9470
CH
BluPhenix ::
ManyMan, mi lahko poveš zakaj vedno ko te kaj zanima v zvezi s to tvojo mutnik.com stranjo odpiraš novo temo?
Ja, nekdo je registriral na novo, si pač pozabil, ali pa ignoriral maile registrarja. To se dogaja. Jaz sem tudi imel tak problem enkrat.
Podpisa ni več, ker so me poskušali asimilirati.
| » | KuponlandiaOddelek: Loža | 15806 (9648) | MadMen |
| » | Domena, varna pred DMCAOddelek: Izdelava spletišč | 1893 (1717) | Bistri007 |
| » | SiOL? (strani: 1 2 3 )Oddelek: Novice / Omrežja / internet | 22815 (15278) | goba |
| » | SIOL - zapira stacuno !? :-)Oddelek: Omrežja in internet | 4234 (3102) | FastWIND |
| » | Poziv za zaščito Whois bazeOddelek: Omrežja in internet | 4900 (1912) | Bakunin |
