Forum » Strojna oprema » quadro
quadro
đuričđuro ::
zanima me kk se nvidiino kartico spremeni v quadro
Prenesel v pravi oddelek -- moderator
- spremenil: OrkAA ()
Oxford ::
Pojdi na stran www.guru3d.com, oglej si njihov forum in pa naštudiraj malo program Riva tuner. Primeren je za softmodanje Nvidia kartic v Quadro.
Toda vedi, da quadro niso vsemogočne. Njihova moč v profesionalnih CAD programih se pokaže šele pri gromozanskih sestavih, kjer pa potrebuješ še en vagon pomnilnika in hiter procesor. Verjemi, da ti bodo SolidWorks, ProEngineer ali Catia delovali povsem spodobno na 6600-tki ali 7800-tki. V igrah pa se quadroti ne obnesejo superiorno.
Živ.
A kdo ve kaj in zakaj se priklopi na spodnaj označen priklop? Nevem ali je samo za ventilator, kar bi bilo malce čudno ali je to nek 3D video izhod za (zgornji levi dodatek)
hvala
hvala
- spremenil: Machete ()
GTX970 ::
http://www.pny.com/File%20Library/Suppo...
#5
Additional Power Requirements
NVIDIA Quadro 6000, K5000, 5000, K4000, and 4000
In order for the NVIDIA Quadro graphics boards noted above to operate correctly, the auxiliary power
connector cable(s) which are supplied must be utilized. These 'Y' cable have two 4-pin connectors that
attach to power supply taps, and a 6-pin connector that plugs into a matching receptacle on your graphics
board.
Connectors for auxiliary power cables are keyed. Always verify the orientation of cable and connector and
never force the cable into the connector.
tu je priklopljen kabel:
http://www.nvidia.com/object/product-qu...
http://www.slashgear.com/nvidia-quadro-...
PNY Stereo Board Connector for Quadro 4000
QSP-STEREOQ4000-PB - PNY Stereo Board Connector for Quadro 4000 Graphics Board
http://www.scan.co.uk/products/pny-ster...
#5
board.
- spremenilo: GTX970 ()
| » | PRO-ji 3d rendrov!!! Potrebujem vaš nasvetOddelek: Kaj kupiti | 8911 (8140) | GenZNPC |
| » | Mašina za arhitektko (strani: 1 2 )Oddelek: Kaj kupiti | 19462 (17723) | JesusChrist |
| » | Nakup PC-ja za Adobe CS,3D modeling,AutoCADOddelek: Kaj kupiti | 2006 (1788) | Loocas |
| » | Nov delovni PCOddelek: Kaj kupiti | 5687 (4652) | antonija |
| » | Koliko uporabnikov Slo-tech-a..uporablja Profesionalne CAD/CAM programe tipa SolidworOddelek: Strojna oprema | 3393 (2933) | HyperGL |
